Old 02-22-2010, 09:35 AM   #16
charlie264
charlie264's Avatar
Oddometer: 8,504
Originally Posted by jsrider
You're looking at the wrong kit. Part number is HCSHIM02. $90 US retail. Looks like Amazon has them for $75.
Originally Posted by unaweep
http://www.cyclebuy.com/shopping/hot...ts_100.htm#Hot Cams_Valve_Shim_Kit_-_Larger_Image
$70 + shipping.
charlie264 is online now   Reply With Quote
Old 02-23-2010, 10:22 AM   #17
Hipster
Hipster's Avatar
Oddometer: 1,815
Anyone the actual Hotcams part number for the 10mm shim kit? I want to use my Amazon gift card to order the kit and the cyclebuy link lists their own part number for this item.
Hipster is offline   Reply With Quote
Old 02-23-2010, 10:56 AM   #18
pfb
Riding, not skiing.
pfb's Avatar
Oddometer: 5,519
Hotcams HCSHIM23
On Amazon here
950 Adventure 950 Super Enduro 450 XC-W Six Days
pfb is offline   Reply With Quote
Old 02-23-2010, 11:21 AM   #19
Hipster
Hipster's Avatar
Oddometer: 1,815
Thank you!
Old 02-23-2010, 10:12 PM   #20
dezracer
dezracer's Avatar
Oddometer: 642
Originally Posted by Pete640
Difference with the KTM vs HD shims is the HD ones are in 0.025mm increments and the KTM are 0.05mm Bit of a bugger considering the valve clearance for the intakes is 0.05mm. Kinda makes it hard getting it just right dont it??? I was quoted $AU 9.80 per shim at my local KTM dealer - got the whole 8 from HD for $AU32.00 - and they're spot on bang in the middle of tolerence. Thanks HD
Pete
What do you mean "got the whole 8"? Is that all you need in the kit. If I wanted to secure the shims BEFORE I take the bike in for a valve check (I could see my dealer not having the right ones) is there a grouping I should have? HD looks to have a wide range but I wont need them all. Or would I? Thanks in advance
2007 990 Adventure
Suspension by Super Plush
Rekluse Pro Auto Clutch
WINGS N.O.S Exhaust
Euro Headlight with PIAA bulbs
KTM Hard Parts Radiator Cover
CJ Racer Clear Spoke Clutch Cover
Hilslamer Long Pegs
GPR Stabilizer
DH Racing tripleclamps
'300' Throttle Cam
16t CS Sprocket
Mefo "Super Explorers"
Ram Mount Garmin 76c
PABIKER sidestand relocaton kit.
2007 KTM 300XC (long live lightweight 2-strokes)
Las Vegas, NV and the Great Mojave Desert
dezracer is offline   Reply With Quote
Old 02-23-2010, 10:24 PM   #21
pfb
Riding, not skiing.
pfb's Avatar
Oddometer: 5,519
Without knowing what your current shims are, it would be pretty hard to predict what shims you might want to buy. Hence the idea of purchasing the entire hotcams shim kit.
Valve clearances typically lessen over time, so if it was recorded what shims were used on your last valve adjustment, you could make sure you had the 2 .050 increments below your current shims and you almost certainly would be good. (though often you won't need any adjustment, and can reuse current shims on different valves as needed)
Old 02-23-2010, 10:43 PM   #22
Pete640
I hate sand.......
Pete640's Avatar
Oddometer: 1,893
DEZRACER - Ive done my valves and know what the shim sizes are. I bought the "whole 8" next sizes, 0.025mm down so that next check Im ready to go. Might need them - might not. But for the cost vs convenience measure they were a bargain and will keep the 9fiddy hummin through the 30km service, so that takes me to 40km before I have to worry about it again.
Pete
Pete
Turtleshell5@icloud.com
For those who sit at home and dream-let them...Meoni
Pete640 is offline   Reply With Quote
Old 03-15-2010, 08:56 AM   #23
bdefen
bdefen's Avatar
Location: Boise, Idaho - In the heart of Dual-Sport Paradise
Oddometer: 326
I bought the Hot Cams box...
I bought the Hot Cams box of 84 shims yesterday. $69.95 plus $7.95 shipping. Many thanks to this thread for turning me on to that alternative. Our local Harley dealer parts guy was very helpful, but he said that he could only order the V-rod shims priced at about $3 each, in packs of 5, so the Hot Cams box seems like the best way to go. Will be much easier to re-do, if I find I've goofed on sizing after reassembly.
Got an 8mm, 1.25 thread-pitch bolt, 100 mm long at Ace Hardware to use as the TDC crank lock for $.98.
Hope to do my valve adjustment in the next month or so.
Byron
'13 BMW R1200 GSW
bdefen is offline   Reply With Quote
Old 03-15-2010, 10:53 AM   #24
mynameis
mynameis's Avatar
Oddometer: 212
Along with other people on this forum i`ve been using the 9.48mm hotcam shims in my 950,at the time the 10mm kit didnt exist.
I doubt wether i will buy the new kit to replace my current hotcam shim set.cheers
Andy UK.
KTM 950SM
Suzuki DRZ400S
mynameis is offline   Reply With Quote
Old 03-15-2010, 06:48 PM   #25
ridewestKTM
ridewestKTM's Avatar
Oddometer: 1,717
Do notice this too
The KTM shims should be measured they are often not exactly what is stamped. Look at the positive side there are partial steps.
My 950KTM makes me feel like a little kid again......because it's so tall!
ridewestKTM is offline   Reply With Quote
Old 04-11-2010, 05:09 PM   #26
saved
sanctified scum
saved's Avatar
Oddometer: 37
Shims
Originally Posted by Simland
HOTCAMS Shim kits:
NEW 10mm shims for KTM, Harley and Buell!
10mm VALVE SHIM KIT> 10mm diameter - Includes three valve shims of each size from 1.85 to 3.20 in .05 mm increments. 84 shims in total, 83 cents per shim!
Fits 08-up KTM 450/530 XCW-R, EXC-R, all Harley Davidson V-Rod, Buell 1125RR
Does your local dealer have the shims you need? 68-2180 $69.95
I have a set of hot cam shims for my drz400. well they also work on the 950?
thanks Ben
saved is offline   Reply With Quote
Old 04-11-2010, 05:56 PM   #27
Bronco3738
Mike
Bronco3738's Avatar
Oddometer: 498
thanks Ben
People have used them, just read a few posts before yours. But the DRZ uses 9.48 mm the KTM 950 uses 10.0 mm. So can you? Yes. Would I use them in my bike? No. I don't like the idea of using the wrong sized part in, to me something that is very important. Call it piece of mind. A new Hotcams kit is only $70.
2009 KTM 990
Honeymoon Ride Report
Crazy Europeans Tour Utah
Bronco3738 is offline   Reply With Quote
Old 04-11-2010, 06:49 PM   #28
saved
sanctified scum
saved's Avatar
Oddometer: 37
Thumb shims
Thanks I well get the right ones
Ben
Old 04-18-2013, 07:43 PM   #29
ridemorestressless
ridemorestressless's Avatar
Oddometer: 65
Feelin
How do you decide when using a feeler gauge how tight is right for a good measurement?
ridemorestressless is offline   Reply With Quote
Old 04-22-2013, 06:00 PM   #30
unaweep
Uses lotsa band-aids
unaweep's Avatar
Oddometer: 21,338
It's all relative.
My preference is to get some resistance on the feeler gauge when withdrawing it. About 1/6 of a turn is about the difference between shim sizes. Going from memory . . . Anyone correct me on anything. A lil pui!
unaweep is offline   Reply With Quote
Times are GMT -7.   It's 05:25 AM.
