Old 10-22-2012, 03:55 PM   #166
IDRIDR
Take me to the River
IDRIDR's Avatar
Oddometer: 1,521
'06 bought in Nov 2011 with 10,400 miles. Now at 12,600.
IDRIDR is offline   Reply With Quote
Old 10-22-2012, 04:01 PM   #167
EOD3MC
What will break next
EOD3MC's Avatar
Oddometer: 4,869
Originally Posted by EOD3MC View Post
2009 with just over 18000...I have to keep the average at 1000 miles/month or better or I go into withdrawl..
Just noticed this thread again so I figured I'd update my numbers...same 2009, lots of modifications, now over 52,000 miles
(Would have a lot more but I picked up an 08 KTM Adventure this past Feb and put 19,000 on it since then)
EOD3MC is offline   Reply With Quote
Old 10-30-2012, 02:11 PM   #168
pirate gonzo
Weirdo
pirate gonzo's Avatar
Oddometer: 121
KLR Mileage
08' I bought July 2011 with 12000 miles on. As of today it is at 32900. Everything is great on the bike and I love it to death but I am thinking about getting a bigger bike for the long distance trips. I don't want anything to fail too far away from home.
pirate gonzo is offline   Reply With Quote
Old 11-09-2012, 03:01 PM   #169
cedew
Oddometer: 26
I think the real question is...has anyone ever actually needed to rebuild one?!?
cedew is offline   Reply With Quote
Old 11-09-2012, 03:47 PM   #170
ysrebob
ysrebob's Avatar
Oddometer: 57
2001 model, well maintained but ridden hard, always dead reliable... the gearbox started getting crunchy on the 1-2 shift at about 30K miles and I was noticing metal flecks in the oil. Sold it at that point, so I don't know how many more miles it had left in it. Great bike, many good adventures!
ysrebob is offline   Reply With Quote
Old 11-09-2012, 05:22 PM   #171
NHADV
NHADV's Avatar
Oddometer: 554
bought my 09 in 2010 put 20,100 on it. Bought a 2012 in June 5200 miles and counting.
-Gary
NHADV is offline   Reply With Quote
Old 11-09-2012, 05:39 PM   #172
Myfuture_yourdebt
Oddometer: 372
'06 with 31k miles, 29k of which are mine. She's only failed to start and run once, and that was from the original battery taking a dump one winter.
Biggest lesson learned:
I'd suggest going over the rear suspension sooner rather than later if you haven't already to rebuild/replace whatever necessary and grease it all properly. I didn't do this until about 2,000 miles ago and it was a pain just to get it apart since the pivot arm axle was pretty well corroded in place. I had to liberally tap it with a sledge hammer to get it out of the frame. Also, Loctite everything!
Favorite mods: Ricor IAS shock and Intiminators, Vapor dash, and the Thermobob.
Myfuture_yourdebt is offline   Reply With Quote
Old 11-10-2012, 02:58 PM   #173
MtnRider2
MtnRider2's Avatar
Oddometer: 144
'05 with 15K and another '05 with 1800 To top it off the VIN's are 22 apart! Now to do some mods to the "new" one and rack up the miles!
MtnRider2 is offline   Reply With Quote
Old 11-19-2012, 03:14 PM   #174
Hektoglider
One with Life
Hektoglider's Avatar
Oddometer: 2,536
kilometers
valve clearance, doo lever inspection, oil level kept up. Original . no motor work.
Ride Our World
Hektoglider is offline   Reply With Quote
Old 11-19-2012, 07:16 PM   #175
ridepjride
Migrant
ridepjride's Avatar
Oddometer: 332
Originally Posted by ridepjride View Post
I have a 2004 with 62k miles, and just picked up a 2003 with 8k. That strategy is what I'd planned all along, to stay with the same make/model bike in order to keep the mods I like. The '04 is still going strong, but a lower mileage bike will have a greater chance of being more reliable on a long solo trip.
The '03 now has 36k. Did the Schnitz 705 kit at 11k, really smoothed out the bike and woke it up a bit. No issues, does not burn oil.
ridepjride is offline   Reply With Quote
Old 11-19-2012, 08:56 PM   #176
EmkIoway
Oddometer: 12
Wink Odd Duck here
10'xxx on my 1985 Klr 600. Going ok, but only 1600 are from me.
EmkIoway is offline   Reply With Quote
Old 11-21-2012, 05:49 AM   #177
eddie bolted
BOING!!!
eddie bolted's Avatar
Oddometer: 3,981
Originally Posted by kdxkawboy View Post
For mine, I gave them a gentle, respectable break-in and at 6000 went to a top quality full synthetic (Mobil 1 20W-50). After that all I did was change the oil and oil filter every 6000 miles, at which time I also checked/adjusted the valves. Cleaned the air filter as needed (use Twin Air and NoToil filters with NoToil oil). Stock doo.
Front side of doo hickey after 130,000+ miles
Back side of doo hickey after 130,000+ miles
But I did loose the spring which allowed enough slack on the balancing chain to let it eat into the cases
This also caused serious hooking of the balancer chain sprocket on the crankshaft, which with my anal approach to rebuilds makes this engine toast, and why I got a used engine to rebuild.
6000 mi between oil changes.....YEOWWWWWWW!!!!!!
If it stops raining now, i'll be pissed!(BEANTOP)
It's mostly Dan........I knew he couldn't keep a secret(SCOTTY P)
eddie bolted is offline   Reply With Quote
Old 11-21-2012, 05:49 AM   #178
eddie bolted
BOING!!!
Oddometer: 3,981
08 37,000 mi.
Old 11-21-2012, 05:54 AM   #179
nigelcorn
Wannabe.
nigelcorn's Avatar
Oddometer: 817
Yeah, and he obviously needs advice from random people on the internet about oil changes since he is only getting 130k miles out of a KLR.
nigelcorn is offline   Reply With Quote
Old 11-21-2012, 06:14 AM   #180
RandoCommando
Wannabe
RandoCommando's Avatar
Oddometer: 1,463
He switched to synthetic.
You can go a lot longer between changes with synthetic.
1999 KLR 650 (her name is KLaRissa) DOOHICKEY DONE!
2013 BMW F800GS (her name is FranGelicaS)
Please. Ride careful, ride safe, ride defensively! This thread should be mandatory reading!
MySPOT
RandoCommando is offline   Reply With Quote
Times are GMT -7.   It's 10:41 PM.
