12-05-2005, 05:58 AM
#121 |
Ignostic
Oddometer: 13,839
Hey creeper,
doesn't JPF's method also assume that the adjustment was done properly initially, and that the jam nutz were torqued to the same spec? With his method that becomes a HUGE assumption, and any initial variance among the valves would be amplified over time by any subsequent drift due to variance across jam nut torque values and JPF's "standardized" adjustment... "Screw tappet into tight. Back off 1/4 turn [=0.15mm]." Exactly what is "tight"? And how good can YFF be at consistently "backing off 1/4 turn (0.15mm)" evenly on all valves? Plenty of variables in there including tight workspace that make me think it best to spend the time to measure the valves so that the redundancy of measuring them is a QA/QC check of the mechanic if nothing else.
Kronreif Trunkenpolz Mattighofen LC4 640 Its not so much staying alive; its staying human that counts. meat popsicle screwed with this post 12-05-2005 at 07:21 AM |
12-05-2005, 12:32 PM
#122 |
Still alive...
Oddometer: 10,718
Good observation Meat. Yes, there are several assumptions made when using an X turn equals X clearance method.... too many for my taste.
For example, "tight" can be anything from lightly touching, to X amount of preload on the valve assembly. Because there has been some "confusion" lately about the best process to use, I opted to post an old response to a common question and let the readers form their own opinions. What people choose to do in the privacy of their own garage is not my concern. To publish a method that can, in my opinion lead to possible gross inaccuracies is irresponsible, and only serves to confuse those that may be struggling with the job in the first place. C |
12-05-2005, 05:09 PM
#123 | |
Buffo Maximus
Oddometer: 850
I start by having the person learning turn the adjuster nut 90 degrees, snug the lock nut down and practice with the gauge. They seem to get the correct feel learned more quickly and accurately with this reference. (80 degrees on my 450 is more difficult to find.) I have them repeat this several times until they understand how loose or tight the clearance must be to be right. Stu |
12-05-2005, 06:24 PM
#124 | |
Ignostic
Oddometer: 13,839
My earlier dos centavos on that subject, thanks to some private tutoring ala El Jefe
![]() Quote:
for the kitty, well, I do have some secrets ![]() So play with those feeler gauges, over tighten, over loosen, and get the feel of it in the obviously wrong settings; somewhere in the middle lies a truth.
Kronreif Trunkenpolz Mattighofen LC4 640 Its not so much staying alive; its staying human that counts. |
12-05-2005, 06:31 PM
#125 | |
Molon Labe
Oddometer: 6,286
How long do we have to wait for your pussy stroking secrets Meat?
Chris '03 KTM Adventure 640 '43 BSA M20WD |
12-06-2005, 07:11 AM
#126 | |
Ignostic
Oddometer: 13,839
![]() but let's not get sidetracked here ok?
03-14-2006, 06:09 AM
#127 |
Lost in the woods
Oddometer: 354
Well, I did my valve adjustment with about 1100 miles. Went OK except for one small item. I removed the lever on the compression release cam. 1st problem was when I removed it, I rotated it so it was actuating on my exhaust valves. Took a good bit of time to figure out why I couldn't get a feeler gauge in there even after I backed out the adjuster screws a LOT.
OK, figured out that one and got the valves to a good .006 lash. Now how do I put the spring, O-ring, O-ring holder, decompression arm, washer and screw back???? After a few hours and very sore fingers I stooped and asked Creeper. His solution was quite simple and worked in about 3 minutes. " Assemble everything with the spring in position but not up over the arm... then lever the spring over the arm with a spring puller or small screwdriver." Well I used a cable wrap and was able to pull the spring arm over the decompression lever without much fuss.Thanks Creep for the help in my specific issue and in the very well written description. Techie. |
06-03-2006, 10:10 PM
#128 |
D Boon!
Oddometer: 2,291
Thanks again for all in involved in another great tech thread. Did the valves yesterday. Was a tight fit, but doable. I thought about using my headlight the whole time, should've done it. I'll do it next time.
Errin
Thunderbird 1 - '07 KTM 990 "Love comes in spurts!"--Richard Hell |
06-03-2006, 10:46 PM
#129 | |
Still alive...
Oddometer: 10,718
06-03-2006, 10:58 PM
#130 | |
D Boon!
Oddometer: 2,291
08-01-2006, 09:09 PM
#131 |
Ignostic
Oddometer: 13,839
THIS should have been here.
11-05-2006, 10:43 PM
#132 |
Ignostic
Oddometer: 13,839
Valve Lash Inspection #2 completed
Thanks Creeper, your guide was great once again.
I had three loose 7s and something that musta been tigher than a tight 5. The port intake valve was tight. I could barely get the .006 feeler gauge in, whereas the other three were easy (almost no "scotch tape feel" to them). I was thinking that was probably due to my last adjustment; a bit tight to begin with or perhaps I didn't get the torque value correct on that jam nut. Should we be concerned with how our valve lash clearances vary over time? Does that variance indicate anything or is there too many sources of variability involved? I adjusted both intakes and left the exhausts as loose 7s. It was once again too late, so I don't get to start her up until tommorow morning. I hope to have good dreams in anticipation.
11-05-2006, 11:04 PM
#133 | |
Still alive...
Oddometer: 10,718
A small reduction or increase of clearance in a relatively random pattern; .001" or less plus or minus indicates "normal" wear... or a previously inaccurate lash setting. A reduction or increase, consistently one way or the other, repeating at one or more locations... that could be an indicator of abnormal wear. Cam lobes, cam bearings and journals, rockerarm cam follower rollers, elephants foot adjuster ball and sockets, stretching valves, battered seats... all show up as unusual and excessive changes in lash. |
11-06-2006, 08:47 AM
#134 | |
Ignostic
Oddometer: 13,839
I didn't get to ride today, but I started her up just because I couldn't wait... she started up real easy and idled well.
11-06-2006, 08:54 AM
#135 | |
Still alive...
Oddometer: 10,718
