03-02-2010, 08:54 AM
#1 |
742 Evergreen Terrace
Oddometer: 4,405
which front spring rate?
it's become apparent that I need stiffer front springs. I've noticed that I bottom out the stock front springs on almost every little rise in the trail. What I don't know is what rate I should get.
I'm about 180 pounds and ride somewhat hard. By no means am I an "A" class enduro rider, but I'll cruise at about 30-40 on a two track and jump a few water bars. from what i've heard I should be looking at either the .56 or .59s. given my weight what is wisdom of the forum?
04 KTM 950 ADV 2001 KTM 400 SX "We're going out Marge, if we don't come back avenge our deaths." -Homer Simpson "Some people will tell you that slow is good – but I’m here to tell you that fast is better. I’ve always believed this, in spite of the trouble it’s caused me. Being shot out of a cannon will always be better than being squeezed out of a tube. That is why God made fast motorcycles, Bubba…"-Hunter S. Thompson |
03-02-2010, 10:19 AM
#2 |
Oddometer: 317
I'm about 190lbs with my riding gear and trailtricks have put in 55's in mine. Can't believe the difference.
03-02-2010, 10:28 AM
#3 |
Motorcycle Connoisseur
I hear 59's work best for the waterbars at Fourmile...
Daniel 2005 KTM 950 Adventure S 2004 KTM 250 exc 2004 KTM 525 exc 2006 Beta Rev3
03-02-2010, 11:17 AM
#4 | |
Oddometer: 4,405
my real concern is that I'll be oversprung and mess up weight transfer resulting in the front not biting in on a turn.
03-02-2010, 11:28 AM
#5 |
Look at it like an engineer:
$100 investment for a set of springs of whatever rate. Reclaimable in the flea market if you reconsider $20 Motionpro fork cap tool. Sort of useless, but just buy it anyway. Or maybe borrow Duke's? $10 A cheapie 22mm that you can buy from ching chong to file down and get the cap off. In the world of suspension, I'm sure you know that's a meager investment for what difference it could potentially make. Try and guestimate by how much preload you've got on your stock 48's now. Do you have any additional stacks on the inside? Do you have the preload cap maxed out (10mm)? If so, try the 59's. You can play with the internal preload a bit to vary the effective springrate. Don't forget if you've got 20mm additional preload internally, and the cap maxed out, they're not 48's anymore.
03-02-2010, 11:34 AM
#6 | |
Oddometer: 4,405
![]() Suspension has always been black magic to me and I'm just now getting to the skill level where something on the bike is what is holding me back, rather than my own abilities. Right now I know I have the compression damping turned all the way up, rebound is about 60-75%. I've never taken the forks apart so I've never messed with the internal preload. My long term employment prospects are pretty shaky right now, so I'd rather avoid dropping $100 to find out I was wrong and end up having to drop another $100 to get it right. I guess a better way of phrasing the question would be: has anyone about my weight put .59s on their bike and felt that they were oversprung?
03-02-2010, 12:01 PM
#7 |
My Setup
Here's my take:
I weigh 126 pounds and I will be running the 59 springs this season. Looking forward to hearing others' input
03-02-2010, 12:09 PM
#8 | |
Oddometer: 49
That's not really true. A straight rate spring is just that, adding preload only changes the amount of weight you need to put on the spring to overcome it's preloaded state and start moving it. After that, it is and will always be a 48(or whatever rate it is). Until it coil binds. All Preload really does is change your ride height. To change springrate you need to actually change the spring. |
03-02-2010, 01:03 PM
#9 | |
goat trail rider
Oddometer: 3,297
"Vive tus sueños en vida, no la vida en sueños. Kampale Moto Ranch Bed and Breakfast mototours/uruguay south america |
03-02-2010, 01:42 PM
#10 |
Oddometer: 336
trailtrick
What fork springs do you have in stock for an 04 S? Currently I have 52s but I need more spring as I'm 250 pounds |
03-02-2010, 01:59 PM
#11 |
Druid Revisionist
Oddometer: 396
Uh...
Xdbx do you really weigh only 126 pounds? .
....there's nothing more permanent than a temporary solution
03-02-2010, 02:06 PM
#12 | |
goat trail rider
Oddometer: 3,297
03-02-2010, 02:23 PM
#13 | |
Full on Yob
Oddometer: 202
So you recon .64 will be about right for our weight? It is important to get it right because it turns out this is a great hoon machine in canyons, and I can't wait to get it out on the track. All that ground clearance.
Rossco KTM 620EGS 950ADV Ducati ST4s SL900 900S2 kickstart. If your only tool is a hammer, make the problem resemble a nail. |
03-02-2010, 02:43 PM
#14 | |
Oddometer: 336
Thanks |
03-02-2010, 04:07 PM
#15 | |
goat trail rider
Oddometer: 3,297
