Old 03-02-2010, 08:53 PM   #1
johngil OP
Reseda, CA
johngil's Avatar
Oddometer: 3,801
F800GS Brake Pads
Anyone happier than normal w/ any aftermarket pads using the stock rotors?
Part #'s?
johngil is offline   Reply With Quote
Old 03-03-2010, 01:43 PM   #2
CrazyMike
***42***
CrazyMike's Avatar
Oddometer: 931
John,
I wish I could offer up some advice on current brake pads but at 13600, I'm just about to put on some Galfer FD165 Black pads on the rear and FD 172 Green pads on the front.
It'll be a couple of weeks before I can offer any advice but I'll try to follow up for you.
Mike
1999 BMW R1200C
2009 BMW F800GS
WANTED: Kawasaki ZRX 1200R
CrazyMike is offline   Reply With Quote
Old 03-03-2010, 03:15 PM   #3
johngil OP
Reseda, CA
johngil's Avatar
Oddometer: 3,801
I may try these as well. It's time (again).
Old 03-03-2010, 03:17 PM   #4
YetiGS
No Talent Ass Clown
YetiGS's Avatar
Oddometer: 7,614
If you didn't ride in so damn much mud . . .
-Scott- MotoGearGrinder.com
Semper Fi
YetiGS is offline   Reply With Quote
Old 03-03-2010, 03:23 PM   #5
johngil OP
Reseda, CA
johngil's Avatar
Oddometer: 3,801
"when i get home, i'm gonna punch your momma right in the mouth, because there is no wayyyy you came from my loins."
Old 03-03-2010, 04:52 PM   #6
GSranger
blacksheep
GSranger's Avatar
Oddometer: 83
Smokey and the Bandit
I love Jackie Gleason in that movie
GSranger is offline   Reply With Quote
Old 03-04-2010, 06:26 AM   #7
PackMule
love what you do
PackMule's Avatar
Oddometer: 19,460
I've got a set of Galfer Gold's on the rear now. The rear is very easy to lock up b/c of the studded knobbies, but the gold's have a nice feel and are easy to modulate. Much better than the stockers.
Can't comment on longevity yet.
Nate in N.E.
Yes, I have a Dakar problem -- that there are 50 weeks of the year without Dakar!
They don't expect you to finish. That's why it's the Dakar. -- PPiA
PackMule is offline   Reply With Quote
Old 03-05-2010, 03:47 PM   #8
johngil OP
Reseda, CA
johngil's Avatar
Oddometer: 3,801
CrazyMike, thanks for the info. I will ride Sunday and report back.
Old 03-05-2010, 04:24 PM   #9
bumbee800
Oddometer: 69
I have a set of carbone Lorraine pads on their way from bmwboneyard.
Any trick to mounting these new pads. Do you just push the pistons back in and if so what are using to push them back in with?
I was also planning on flushing the old brake fluid while doing this. Is there anything I need to be aware of when flushing the brake fluid (ie abs got yas)? I have always just opened the bleed valve and squeezed the brakes while replenishing the old fluid with new in the resevoir being careful not to run the resevoir dry.
Any advice would be appreciated.
bumbee800 is offline   Reply With Quote
Old 03-06-2010, 06:20 AM   #10
CrazyMike
***42***
CrazyMike's Avatar
Oddometer: 931
The rumor is that you don't have to unmount the calipers to replace the brake pads. Removing the calipers is not that hard so either way that works for you will be fine.
I use a large flat-bladed screwdriver to compress the pistons back into the caliper.
No extra tips for bleeding the brakes even with ABS (which I have and I've bled).
Good luck!
Mike
1999 BMW R1200C
2009 BMW F800GS
Old 03-06-2010, 06:27 AM   #11
johngil OP
Reseda, CA
johngil's Avatar
Oddometer: 3,801
I pulled the rear wheel. Easy enough.
For the front, I removed the calipers. Probably unnecessary, but so easy I really didn't think about it.
As for bleeding the brakes...
I have changed a couple of brake lines on the bike (w/ ABS) and bleeding the system was totally painless.
Old 03-06-2010, 07:09 PM   #12
Bayner
Oddometer: 1,612
FYFFI:
Proper method for brake pad replacement on an ABS system includes opening the bleeder screw when retracting the pistons. This prevents any sediment from being forced back up through the plumbing and F-ing up your ABS valving, which you definately don't want to have happen.
(I've done it without opening the bleeders many times, :ie when they're siezed, and rarely had troubles. However these bikes are new enough nothing should be stuck. Opening them regularly will ensure it stays that way.)
Bayner is offline   Reply With Quote
Old 03-07-2010, 06:57 PM   #13
johngil OP
Reseda, CA
johngil's Avatar
Oddometer: 3,801
Love the green up front. The black in the back works well, but may be lacking feel. Only got in 120 miles or so. Lots of fire roads and sliding.
I may be tempted to try the green in the back as well.
Old 03-08-2010, 05:53 AM   #14
PackMule
love what you do
PackMule's Avatar
Oddometer: 19,460
The gold has good feel (IMO) out back, John, and should last longer than the greens.
Nate in N.E.
Old 03-08-2010, 11:57 AM   #15
johngil OP
Reseda, CA
johngil's Avatar
Oddometer: 3,801
I have used the gold on my KTM's.
I'm reluctant to try them on the brokeback beemer only because of them being harder on the rotors. From the price sheets I have seen, I would need to sell my son and pimp out my wife to pay for a new set of rotors.
I'm sure I'm just being paranoid.
Times are GMT -7.   It's 12:03 AM.
