06-16-2011, 01:22 PM
#31 | |
consummate n00b
Oddometer: 96
I ran my original pads to 24,000mi., and they were overdue for a change. So far I've taken delivery of the green Galfers for the front. It is grabby in a good way, but hard to compare to the OEM since they were so worn out. Still waiting for my rear green Galfers to come -- been riding without using the (totally worn out) rear brake for like 3 weeks now
06-16-2011, 01:41 PM
#32 |
consummate n00b
Oddometer: 96
Speaking of new Galfer pads, can anyone tell me if this looks normal? These are the green front pads.
![]() This is how they came in the package. Seems they were planed down, since nothing sticks up, but those rough areas dip down below the level part. I didn't return them since it would have been a pain and I didn't know for sure this isn't normal. And they seem to work fine (for now). |
06-16-2011, 03:17 PM
#33 |
Oddometer: 248
Im just getting ready to roll over 20k on the bike and am ready to replace them. I am pretty suprised! I guess i should start to uses them more.
06-16-2011, 06:07 PM
#34 |
Oddometer: 58
[ QUOTE=replicant;16181969]Speaking of new Galfer pads, can anyone tell me if this looks normal? These are the green front pads.
Mine stared out smooth and eneded up looking the same only worse after about 500 miles (including 50% off road) and they have NO stopping power. They are junk. You can have Galfer Greens... Went back to OEM.... Much much better. ![]() This is how they came in the package. Seems they were planed down, since nothing sticks up, but those rough areas dip down below the level part. I didn't return them since it would have been a pain and I didn't know for sure this isn't normal. And they seem to work fine (for now).[/QUOTE] |
06-19-2011, 12:19 PM
#35 |
Oddometer: 4
Thanks Cowboy
I have 40,500 miles on my original BMW rear pads on my GS8 and was looking for information on replacement options. I saw Cowboy2 comment and gave it a go. Worked great. About 10 minutes total. Since the original pads worked well for my type of use I have replaced them with factory OEM. However, these do not have the wear indicator grooves that were on the original pads. Anyway thanks to Cowbow2 for his advice.
06-19-2011, 04:17 PM
#36 | |
Oddometer: 3,438
Disappointingly, but rear pads look like yours, my front pads look as I would expect - no surface defects. I'll probably go back to the OEM units unless the life and wear rate on the ROTOR are better. |
06-19-2011, 05:41 PM
#37 |
NoMoTDM still Gary
Oddometer: 3,705
No surface defects in mine, but a decidedly difference texture. Front is smooth but the rear is abrasive like sandpaper.
BMW Motorrad USA customer service: "We make superior motorcycles and continue to improve them." itsatdm screwed with this post 06-19-2011 at 07:49 PM |
07-30-2011, 04:26 PM
#38 |
Oddometer: 2,490
When I had the my last service done at 27903 they told me I would be need front brake pads before long. Today I changed the pad at 33300 I changed the pads. The old pads appear to me to have about as much left on them as the new green Galfers. Were the OEM pads thicker than the Galfers? Old OEM pad on top Galfer on bottom.
07-30-2011, 05:23 PM
#39 |
NoMoTDM still Gary
Oddometer: 3,705
I am glad you posted that. At 21,000 my OEM look just like yours and compare the same way as to the Galfers I intendend to install. I think I will look at a new OEM pad for comparison.
BMW Motorrad USA customer service: "We make superior motorcycles and continue to improve them." |
08-05-2011, 11:00 AM
#40 |
Oddometer: 2,490
Did you have a chance to compare the new OEM?
08-07-2011, 06:40 PM
#41 |
Oddometer: 1,237
I replaced my rear pads a while back and figured the front would be due soon as well, so I ordered some in. I was surprised when they arrived and are the same thickness as my original pads at 50k kms. I never did bother to put them on the bike yet.
08-07-2011, 07:19 PM
#42 |
NoMoTDM still Gary
Oddometer: 3,705
I haven't switched mine either and the dealer is 60 miles away, so it will be awhile.
08-08-2011, 01:03 PM
#43 |
Oddometer: 3,438
I have a set of the Galffer green pads on the shelf ... awaiting installation.
I do not know what the new thickness is for the OEM pads, but the pad thickness on the Galffers (NOT counting the backing plate) is: Rear: ~0.23" Front: ~0.17" I have no idea why the fronts are thinner, but they are indeed noticably thinner just by looking at them. |
09-17-2011, 05:38 PM
#44 |
Oddometer: 24
rear pads
Hey there, does anyone know what the thickness of the OEM new rear pad should be. I just got a set from local dealer and they appear to be too thick and having trouble getting them to fit and no room for rotor. They may have sent the wrong set but figured I would check first. Thanks in advance. PS these are for the F800GS
rokboat screwed with this post 09-17-2011 at 05:40 PM Reason: correction |
09-18-2011, 11:31 AM
#45 | |
Oddometer: 248
