Old 09-20-2011, 03:37 PM   #46
JRWooden
Oddometer: 4,231
Originally Posted by JRWooden View Post
I have a set of the Galffer green pads on the shelf ... awaiting installation.
I do not know what the new thickness is for the OEM pads, but the pad thickness on the Galffers (NOT counting the backing plate) is:
Rear: ~0.23"
Front: ~0.17"
I have no idea why the fronts are thinner, but they are indeed noticably thinner just by looking at them.
Just read in the manual that the BMW-OEM new pad thickness is spec-ed @ 5.0mm or ~0.20" front and rear at least on F658GS twin.
JRWooden screwed with this post 09-20-2011 at 03:48 PM
Old 09-20-2011, 08:20 PM   #47
johngil OP
Reseda, CA
johngil's Avatar
Oddometer: 3,795
I still love the Galfer green pads up front.
I have tried the gold and black on the rear and can't say I love either set.
johngil is offline   Reply With Quote
Old 09-20-2011, 09:29 PM   #48
JRWooden
Oddometer: 4,231
Jonh:
Did you try the green in the back?
Old 09-20-2011, 09:50 PM   #49
johngil OP
Reseda, CA
johngil's Avatar
Oddometer: 3,795
Jonh:
No. Can't really say why not. The bike is about due for pads. I'll give them a try.
Old 09-20-2011, 10:56 PM   #50
Gangplank
Advenchaintourer
Gangplank's Avatar
Oddometer: 2,294
bejeezus ya'll go through pads. I've got 15,002 miles on the stock pads. Plan to put galfer greens on front and black on back.... I rarely use the back that often except in the wet so not worred about the blk's
Ride more, bark less
Gangplank is offline   Reply With Quote
Old 10-19-2011, 11:00 AM   #51
Dansrc51
I need a cape....
Dansrc51's Avatar
Oddometer: 1,511
for those of you who have replaced the pads, the dealer is telling me I'm due to change the rear. I'll confirm once I get the bike back (fixing side stand switch under warranty).
My question regards the replacement, the dealer tells me I have to replace both the pads and a mounting bracket. Not sure exactly what they mean, but it's an extra $30 I think he said. Anybody have any experience or know what this is in reference to? I'm at work so I don't have my manual, but I've never had this on any other bike before.... sounds funny to me.
Dansrc51 is offline   Reply With Quote
Old 10-19-2011, 01:56 PM   #52
JRWooden
Oddometer: 4,231
There is a "mounting parts kit" that lists for $18.
See http://www.maxbmwmotorcycles.com/fic...8&rnd=03252011
it's part #8 on the rear brake diagram...
If you've seen lots of mud / water / corrosion it might not be a bad idea to swap that stuff out ....
I can only guess that the $30 quoted is the combination of $18 for the parts and a few extra bucks worth of labor .... ???
Old 10-08-2012, 04:07 PM   #53
rockinrog
rockinrog's Avatar
Oddometer: 2,865
Originally Posted by rockinrog View Post
When I had the my last service done at 27903 they told me I would be need front brake pads before long. Today I changed the pad at 33300 I changed the pads. The old pads appear to me to have about as much left on them as the new green Galfers. Were the OEM pads thicker than the Galfers? Old OEM pad on top Galfer on bottom.
I took my bike for a PA state inspection and the owner said the front brake pads would just barely pass inspection and I would need new ones before long. I thought this seemed odd because they hadn't been on near as long as the first set........ I figured the Galpher green just wore out really fast so I ordered 2 sets of EBC..... Tonight i took the Galphers off and they were almost the same thickness as the EBC ones I was getting ready to put on...I was WTF is going on. I don't have a tool to give an accurate measurement, but my guess is the replacement pads are coming in almost wore out according to state inspection specs...... anyone else run into this?
rockinrog is offline   Reply With Quote
Old 10-12-2012, 12:13 PM   #54
bxr140
Flame Bait
bxr140's Avatar
Oddometer: 1,041
Methinks PA has a brake pad spec that is being inappropriately applied to your motorcycle. I suspect the guy just doesnt know that cars and motorcycles are different. Those slots in the stock pads actually double as wear indicators. Those stock pads are barely worn!
bxr140 is offline   Reply With Quote
Old 10-20-2012, 10:34 PM   #55
Hayate
ADV Monkey
Hayate's Avatar
Oddometer: 59
Service guys suck, get to know your parts guys
Wow, what dicks! I'm so done with taking service guys recommendations! Your OEM pads are fine, mine are at 42k miles original (front). They are just now getting down to maybe half what you have there in the picture. I'm going to replace my fronts soon but I'm just saying I wouldn't ever gauge brake replacement by mileage, it's about the amount of material you have left. (3rd set of rear pads btw) Mileage front verses rear is going to depend totally on your riding style and conditions. My guess is I burn through all those rears and am gentle on the front due to the way my passenger has trained me. We're pretty heavily loaded a lot of the miles we do and that nosedive ya get on this bike with a handful of front brake doesn't make her the happiest. Light and agile and out on my own I barely use the rear so I know there's a lot variety.
I agree with JRWooden, that's probably what they are talking about, but seriously? More dicks charging you for crap you don't need. Inspect that little rod and the pin when you replace your pads, if they tell you it's required to replace them each time they are just ripping you off.
ad·ven·ture 1.an exciting or very unusual experience.
W
hat a great 40,000 mile adventure on the trusty F800GS. Looking forward to the next 40k.
Minnesota Parallel "Twin" Cities GS Riders
Daniel Betlock Adventure Rider
Hayate screwed with this post 10-20-2012 at 10:37 PM Reason: clarification
Hayate is offline   Reply With Quote
Old 11-02-2012, 09:04 AM   #56
HighTechCoonass
Living the Dream....
HighTechCoonass's Avatar
Oddometer: 2,478
Laugh
Going with Black and Black.... wear - I don't care.... rotors = expensive.
I am just an old guy putting around
NEW dash plates for your F800..here... lhttp://advrider.com/forums/showthread.php?t=1007140
HighTechCoonass is offline   Reply With Quote
Times are GMT -7.   It's 06:53 PM.
