Old 03-03-2010, 01:31 PM   #1
snakecharmr OP
Oddometer: 191
What's in your KLR650 toolkit?
I'm starting to put together a KLR specific toolkit to carry on the bike and was wondering what is in yours?
What one tool (other than duct tape) would you consider invaluable?
Where do you feel the best place to carry the tools is?
I did have a homemade tool tube on my bike last season, but as the ring clamp I had holding the left side on with broke as I was riding around a bend, I'm not 100% comfortable with this idea anymore, unless I can mount this better. I feel the stock location for tools is very inadequate for carrying proper tools. It's just too small.
Have a good day.
Stop planning life and live it!
snakecharmr is offline   Reply With Quote
Old 03-03-2010, 02:43 PM   #2
kdxkawboy
Mr. NVKLRGirl
kdxkawboy's Avatar
Oddometer: 2,631
Lets see, in my Motion Pro tool bag /w detachable shop floor -
  • Motion Pro Quick Jak
  • Tire patches
  • Tire patch cement
  • Tire patch tool for scuffing tube and working in the patch
  • Ultraflate CO2 holder
  • Enough CO2 cartridges for about 4 flats
  • tire gauge
  • Two tire irons with spare duct tape wrapped around the shaft
  • Open end/box end wrenches for 8, 10. 11, 12, 13, 14, 17 mm
  • Closed wrenches for axle nuts (lifted from various OEM toolkits)
  • Motion Pro MP Tool
  • Additional hex wrenches
  • 1/4 drive T-handle
  • 8, 10, 11, 12, 13, 14 mm 1/4 socket set
  • Needle nose pliers
  • Vice Grip
  • cotter keys
  • zip ties
  • spare spark plug
  • shop rags
  • safety wire
  • spare fuses
All tools are equally valuable to insure I can mange any doable roadside repair
When the going gets weird, the weird turn pro
kdxkawboy is offline   Reply With Quote
Old 03-03-2010, 03:46 PM   #3
CA Stu
CA Stu's Avatar
Oddometer: 47,319
Basically the same except I got these fancy things from Motion Pro:
One for front, one for rear axle nut
I carry a bicycle pump (with duct tape wrapped around the shaft) instead of CO2 cartridges
Multi bit screwdriver (that can be used as nutdriver) with electrical tape wrapped around the handle.
Folding hex key set
Spare front tube as well as patch kit. Some flats you just can't patch.
Crescent wrench
Needle nose vice grips
A few common bolts
A couple Nitrile gloves
Spare brake and clutch levers*
Spare shift lever *
Spare clutch cable
* I've never needed them personally, but I have given them to other KLR riders who needed them.
I carry most of my heavier tools in my Aerostich Tank Panniers to keep the weight on the front tire and low, except the bike pump, tube, clutch cable and a couple of other small, light things that I keep in my Kawi tail bag.
CA Stu
PS things to add:
Master link and short section of chain
chain breaker
Motion Pro bead buddy
http://youtu.be/C6cxNR9ML8k
CA Stu is offline   Reply With Quote
Old 03-03-2010, 04:04 PM   #4
Oly
Deadlines whooshing by
Oly's Avatar
Oddometer: 8,099
Better include a headlamp in your tool kit or you may be stuck out all night.
I carry spare tubes front and rear because some tube tears cannot be patched.
Not tools but are in the tool kit.
Electrical wire
JB Weld
Oly screwed with this post 03-03-2010 at 04:11 PM
Oly is offline   Reply With Quote
Old 03-03-2010, 04:06 PM   #5
Oly
Oly's Avatar
Oddometer: 8,099
Originally Posted by CA Stu
CA Stu
PS things to add:
chain breaker
** 20 amp fuses **
Old 03-03-2010, 04:23 PM   #6
snakecharmr OP
Oddometer: 191
Wow
How big are your tool kits? I'm just curious as the lists grow and I add more items i'm going to put in mine, I'm wondering how I am going to fit everything on the bike.
does anyone have any pics of how you carry everything and how they are all organized?
Oh and just to add a few essentials that I won't leave home without
-small roll of duct tape
-assortment of extra bungie cords
Old 03-03-2010, 05:30 PM   #7
Chaos-in-MT
OK lets GO!
Chaos-in-MT's Avatar
Oddometer: 446
Originally Posted by Oly
** 20 amp fuses **
assorted nuts and bolts At least the ones that always fall off, we are talking KLR
Some people suffer from insanity, Me I just enjoy it.
Chaos-in-MT is offline   Reply With Quote
Old 03-03-2010, 07:34 PM   #8
CA Stu
CA Stu's Avatar
Oddometer: 47,319
** 20 amp fuses **
Plastic orange juice bottle and lighter.
CA Stu
Old 03-03-2010, 07:58 PM   #9
Ironhead
But Itsa Dry Heat
Ironhead's Avatar
Oddometer: 772
Bottle opener
"I wanta be the man that my dog thinks I am"
" Lord grant me patience, because if you grant me strength, I'll need bail money and a lawyer to go along with it"
Ironhead is offline   Reply With Quote
Old 03-03-2010, 09:26 PM   #10
Oly
Oly's Avatar
Oddometer: 8,099
CA Stu
You don't happen to have a grinder do you?
Old 03-03-2010, 10:01 PM   #11
XDragRacer
Oddometer: 3,101
Complementing the excellent suggestions above, the http://www.rockymountainatvmc.com/pr...FamilyId=19566 Moose Moto Tool offers a practical and useful array of tools in a convenient package; $ 19.95 well-spent! Hex keys (Allen wrenches), valve core wrench, 1/4" square drive, spring puller, all with needle-nose pliers and the "usual suspects" (screwdriver bits, knife, file, etc.) ordinarily associated with a multi-tool.
An indispensible carry-on, for me, is . . . J-B Stick Weld; this epoxy putty, after kneading, offers 5-minute serviceable repairs to radiators, crankcases, water pump housings, etc. "Don't leave home without it!"
Lincoln Welding Rod Holder On Bike; Hobart Model On Asphalt
REI Eagle Creek "Tube" Zippered Packing Case
Fits inside tool tube (holds digital multimeter as well); extracted, all tools are at hand, easily transportable to the point of need, no need to fish for tools inside the tube.
XDragRacer screwed with this post 03-03-2010 at 10:14 PM
XDragRacer is offline   Reply With Quote
Old 03-03-2010, 10:22 PM   #12
Cliff-77
Lost Adventurer
Cliff-77's Avatar
Oddometer: 1,067
KLR tool kit
Some good ideas here,i throw in extra masterlink&small dia.rope for tow rope or tie up stuff on bike.
IBA#54495 Patriotism is supporting your country all the time,and your government when it deserves it.Mark Twain.
Cliff-77 is offline   Reply With Quote
Old 03-04-2010, 02:08 AM   #13
holycaveman
Oddometer: 14,387
Wow, too much to list!
But with my tool kit I can............
Adjust my valves(yes shim buckets)
remove my chain/sprockets, break my chain, add a link
remove wheels, and repair or replace tubes(carry a tube in the tool kit)
Tear down the top end of my motor. And even split my cases if I had too. And glue them back together.
repair broken cases
Pretty much disassemble the whole bike.
tear down the carburetor
steering head
Disassemble Forks?? with some luck
Disassemble Shock? same thing
And I think I may even have a spark plug
Banned for the truth.
holycaveman is offline   Reply With Quote
Old 03-04-2010, 05:15 AM   #14
Doorguy1979
Dreamridin'
Doorguy1979's Avatar
Oddometer: 627
btw, whenever I work on my bike, I keep EVERY tool I use to work on it on a seperate table, and those tools HAVE to go into the kit, you never know when you'll need to get to something. Don't forget to check the factory tool kit to see what you need to add to make it a good kit.
I use this setup, although I use "Rod Guard" Brand tubes that I pay 7.95 each for at the welding supply store(Indiana Oxygen), they are blue and don't have a fancy belt clip, but are strong and waterproof, I used 3" muffler clamps to mount it to my front skid plate just above my highway bar. I had the same issue with broken clamps after taking a piece of asphalt in Chicago, no issues since the upgrade to muffler clamps.
The older I get the more I realize how few people I actually need in my life.
08 KLR 650
82 Suzuki GS850
7? Sachs Moped Basket Case
Doorguy1979 is offline   Reply With Quote
Old 03-04-2010, 04:29 PM   #15
snakecharmr OP
Oddometer: 191
Some really good ideas here.
My tool container will end up being made from 3" ABS capped at one end and threaded on the other with the threaded plug to close. This time I'm bolting it directly to the engine guard, no more hose clamps to break on me.
Allen set for sure
I'm looking for some good combination wrenches in 8, 10, 12 (are there any others I will need?
spark plug and socket
duct tape
bungies
tubes and tire sealant
need to find axle wrenches and tire irons, (love the combo pictured in this thread, but not sure where in Ontario to find them and shipping will be a deal breaker I'm sure)
Chain links and breaker
well it's a start!
Times are GMT -7.   It's 09:26 PM.
