Old 03-21-2010, 02:15 PM   #61
Impulse2k1
Oddometer: 39
I just picked up an '83 CB1000 Custom that had been sitting for ever. It originally came from New Mexico and some how made its way up to the Chicago area. It was coated in dirt from a leaking valve cover gasket, I am currently soaking the carbs in a pinesol vat just like you did and I will reassemble them hopefully on Monday. I was able to get it to fire on some starting fluid
Impulse2k1 is offline   Reply With Quote
Old 03-21-2010, 04:25 PM   #62
Hondo OP
What if its a Samsquamch?
Hondo's Avatar
Oddometer: 9,727
Cool-
KLRWorld.com Forums - Nighthawk Forums
"Life's an adventure, and I refuse to live a boring one."
Hondo is offline   Reply With Quote
Old 03-21-2010, 04:36 PM   #63
XS500RUS
XS500RUS's Avatar
Oddometer: 376
Loving this thread
I've been wrenching/polishing my two vintage bikes as well, and the engine in the XS500 needs a new base gasket, I think I'll try my hand at polishing up the cases and cylinder jug while it's out and apart. I credit this thread with giving me the inspiration to do work on my own bikes.
1977 Yamaha XS500C cross country veteran
XS500RUS is offline   Reply With Quote
Old 03-21-2010, 05:36 PM   #64
Dave in Wi
Dave in Wi's Avatar
Location: Madison WI (40 Square Miles Surrounded By Reality)
Oddometer: 2,033
FWIW, I really like using the Honda tool for adjusting the valves, because you don't need to rotate the engine (or hammer the tool) to depress the bucket.
Dave in WI
2002 ZRX1200R
1975 XL100
1988 DT50
"Daddy, it's five o'clock sometime!"
Dave in Wi is offline   Reply With Quote
Old 03-22-2010, 08:33 AM   #65
drhach
gorillamanufacturing.com
drhach's Avatar
Oddometer: 2,522
Great thread. I did a similar thing with 78 Suzuki GS1000. That is now my touring bike. My only compaint about the older bikes is the weak charging systems. I can run a set of heated gloves but that's about it. So, it limits cooler weather riding. Your bike should be good for about 100K miles once you're done. Keep up the good work.
1976 R90/6
1972 XLCH
2010 Triumph Thunderbird SE
drhach is offline   Reply With Quote
Old 03-22-2010, 08:39 AM   #66
Hondo OP
Hondo's Avatar
Oddometer: 9,727
Thanks- it's a work of passion.
After I did a ride from Denver to Michigan & back on the CB1KC, I decided that it's in need of a few things for long distance touring-
- a custom saddle
- an aux fuel tank
- a better fairing.
Ideally a bike with the factory Hondaline fairing and side/top boxes is great on the road, but it's smallish fuel tank means lots of fuel stops (125 miles or so).
So it's my day bike for Colorado, or for the region.
I have my eye on the R1150RT for my future distance bike.
Old 03-22-2010, 09:36 AM   #67
Hondo OP
Hondo's Avatar
Oddometer: 9,727
Day 15
A very short day anyways. I dropped the kids off at school and had about an hour of free time.
So I pulled the exhaust pipes down and removed their rear mounting brackets.
They were pretty groady, so they get to soak in the Pine Sol vat for the next 5 days-
I'll paint them when I get home from my trip.
Old 03-22-2010, 08:32 PM   #68
mapleleafalumnus
Demigod
mapleleafalumnus's Avatar
Oddometer: 186
Sir, I salute you! I think you are doing an incredible job..LOVE the Pine Sol application!
"Illegitimati non carborundum"
-Gen. Joseph Stilwell
mapleleafalumnus is offline   Reply With Quote
Old 03-28-2010, 09:46 PM   #69
Hondo OP
Hondo's Avatar
Oddometer: 9,727
Day 16
Since I'm still waiting on the new valves, I did a little work on the CB today, odds and ends.
First, I painted the rear exhaust pipe mounts after their Pine Sol bath. Since it's a hi temp item, I used hi temp paint -
Then I worked on removing the baked on grease, tar, and other oily crud from the pipes. Before -
After cleaning with lacquer thinner -
These pipes will nee a lot more attention down the road...
Then I moved onto the GM Coil upgrade/mod. One of the coils I picked up at Checker Auto for $24.00 -
Figuring out the mounting bracket...
And where the new coils will go -
Beemer Pat came by and we brainstormed the mount some, and he took my template with him to see what he might be able to fab up for me at work (Thanks Pat!).
Old 03-28-2010, 09:53 PM   #70
mapleleafalumnus
Demigod
Oddometer: 186
Old 03-29-2010, 06:10 AM   #71
Brad Felmey
Brad Felmey's Avatar
Oddometer: 5,002
Originally Posted by Hondo
GM Coil upgrade/mod
Brad Felmey is offline   Reply With Quote
Old 03-29-2010, 10:45 AM   #72
Hondo OP
Hondo's Avatar
Oddometer: 9,727
Originally Posted by Brad Felmey
GM Coil info here -
http://www.cb750c.com/modules.php?na...iewtopic&t=125
Old 04-07-2010, 07:19 AM   #73
Brad Felmey
Oddometer: 5,002
Old 04-17-2010, 08:57 PM   #74
Hondo OP
Hondo's Avatar
Oddometer: 9,727
Day 17
Did a bit of work today-
Cleaned up these pipe retainers after they soaked in the Pine Sol vat for a week or so -
I also polished up the tops of the carbs. I had to strip off the old clear coat before I started buffing. I used some paint stripper and after that was rinsed off I soaked them overnight in my gallon can of carb cleaner.
Here is a comparison -
After getting them buffed up nicely, I brought them into the kitchen to be scrubbed in some very hot water and dishwashing liquid -
I used a small, soft tooth brush to clean any remaining polishing compound from the logo & letters -
Tomorrow I will clean them off with brake cleaner and when they are dry I plan on spraying a few coats of clear lacquer on them to maintain the shine.
Hondo screwed with this post 04-19-2010 at 06:39 AM
Old 04-17-2010, 09:27 PM   #75
mapleleafalumnus
Demigod
Oddometer: 186
Hallelujah We Are Delivered!
YAY! New Post!!
Times are GMT -7.   It's 09:38 AM.
