Old 01-02-2014, 04:15 PM   #256
Calkins
On Any Sunday...
Calkins's Avatar
Oddometer: 505
I love your tag line dirtdreamer50. This thread got me to find a copy on DVD. Love it!!
Justin Calkins - Iowa Falls, Iowa USA
1973 Yamaha DT3 - 250 - FOR SALE
Boss Framed Yamaha RT3 Flat Tracker - FOR SALE
2007 Triumph Bonneville America - 865
Calkins is offline   Reply With Quote
Old 01-02-2014, 04:19 PM   #257
dirtdreamer50
long time rider
dirtdreamer50's Avatar
Oddometer: 1,158
The movie shows how it really was back then. One of my all time favorites.
Little Fauss: I was going faster than I ever went in my whole life, then I fell off.
dirtdreamer50 is offline   Reply With Quote
Old 03-19-2014, 01:25 PM   #258
Calkins
On Any Sunday...
Calkins's Avatar
Oddometer: 505
Question
Hey Willie, I have a question for you. I picked up a RT3, and plan to build something similar to what you have. What do you think about the cradle drop mod, like the old Webco kit? I have the resources and ability to do it myself, just not sure if I should or not.
Old 03-19-2014, 01:51 PM   #259
dirtdreamer50
long time rider
Oddometer: 1,158
I'm not Willie, but did do that mod on a DT-1 back in '71. It did stabilize the bike in jumps and whoops and lowered the CG too. A friend and I did the mod in one evening. Pulled engine, cut frame, welded and cleaned welds, painted frame and reinstalled engine. Not a bad nights effort, but was 43 years younger, though... tomp dd50
Old 03-19-2014, 01:57 PM   #260
Calkins
On Any Sunday...
Calkins's Avatar
Oddometer: 505
I am building mine for just flat track, not TT. So, I was curious if the cradle drop was worth doing, instead of just lowering the suspension. It seems like it would do the same thing, bringing the crank centerline even with the axle centerlines.
Old 03-19-2014, 11:05 PM   #261
Valleyrider OP
I Survived The '60s
Valleyrider's Avatar
Oddometer: 1,877
YES! Also consider deraking the steering head. I have a frame for rebuilding my crashed TT500 that the steering head is pulled back to 23 degrees. It may be a little steep for but it will handle a bunch better!
http://www.flickr.com/photos/14934865@N07/
'07 1250 Bandit, '06 650 VStrom, '78 SR500E
'68 Yamaha DT1, '78 TT500 and no money
http://www.flickr.com/photos/48000856@N06/
Valleyrider is offline   Reply With Quote
Old 03-20-2014, 06:32 AM   #262
Calkins
On Any Sunday...
Calkins's Avatar
Oddometer: 505
Question
I was eyeballing my bike last night, and this is some thought I was/am having.
If I lower the bike about three inches with suspension mods, my axle centerlines and crankchaft centerlines will be near even (a good thing, to create neutral leaning in the corners), I will have a lower seat height (a plus), shorter shocks, and have a similar swingarm angle as the cradle drop mod.
But, if I drop the cradle about two inches, and I get creative with it, I could gain room where the air filter goes through the rear down tube (a plus). I would have near stock shock and fork length. I would have more suspension travel area (which I won't need for flat track only). And, it seems as if the center of gravity would be higher than a suspension drop.
I am just thinking out loud here. My ol' school Yamaha mechanic buddy doesn't think I should cut up such a nice (titled) bike. To me, it doesn't much matter. It is going to be a race bike, not a trailer queen.
Old 03-20-2014, 09:19 AM   #263
Valleyrider OP
I Survived The '60s
Oddometer: 1,877
I think you're on the right track lowering the frame 2 inches will lower the center of gravity. what you want is a swingarm angle positive about 7 to 10 degrees. The steering head pulled back will help it into the corners and that should solve most of the problems with what you're working with.I have an RT2 frame I believe that's what it is if you want to chop one up
Old 03-22-2014, 05:03 PM   #264
Calkins
On Any Sunday...
Calkins's Avatar
Oddometer: 505
Question
Here are some more idears;
If I were to drop the cradle two inches, the axle center lines would be about an inch below the crankshaft center line. Have all three lined up creates neutral handling in the corners. So, the one inch difference still has the bike having a top heavy characteristic (bad). You still get to keep stock length forks and shocks. But, the swing arm is going to have a near flat angle (not ideal, but not bad). The bike still has a tallish seat height (not ideal). And, the bike still has stock suspension area (not really needed in flat track). Dropping the cradle also lengthens the wheelbase slightly, and transfers a little more more weight to the rear (good for traction). Ideal wheelbase is around 54 inches, which is near stock. I have read that a swing arm extension kit was also available, and complimented the cradle drop kit. At that point, the wheelbase would be to long, so de-raking the neck would be next up. De-raking the sock 29* or so angle to about 26* would be great for short track, not as good for half mile.
Ok, how about keeping the frame stock? Drop the suspension the three inches that I mentioned before. Install shorter shocks in the rear. Slide the forks up, or install shorter ones up front. Keep in mind, you probably would not run the junk stock shocks anyways, so getting new short ones probably would not have a cost difference. Same with the forks, you would probably at least rebuild the stock forks. Now, you have a neutral handling bike, lower seat height, and no welding or machine work to do or pay for. The swing arm angle will be near flat, like the cradle drop mod. Want to de-rake the neck angle? Sure, no problem. Slide the forks up in the triples, and install longer rear shocks. The neck angle has been reduced for quicker steering, and you installed a set of near stock length shocks in the rear. With the suspension drop, you probably lost a little bit of wheelbase. Want to fix that? Install a set of triple clamps with more offset. You probably would not want to just the stock iron clamps anyways, so cost difference is near nothing. Not only does that lengthen the wheelbase back out, it also makes the engine think that it is closer to the rear wheel, and traction increases.
Like I said, I am just practicing years of research from real world results. I have not personally track tested these ideas, yet. But, I did use these ideas while building my TT500 flat tracker.
Old 03-24-2014, 09:36 AM   #265
Valleyrider OP
I Survived The '60s
Oddometer: 1,877
sounds like you have the experience to do this Justin. main thing is that you want about seven degrees positive swingarm angle.you mentioned that you had some experience with a TT500. just apply all that to your current project. Your head angle is going to be B your preference whatever you're going to ride short track or half mile the angles going to be different.You can't set it up perfectly for both so just find a nice compromise. Good luck.
Old 03-30-2014, 03:59 PM   #266
Calkins
On Any Sunday...
Calkins's Avatar
Oddometer: 505
Question
You guys win No can do...
Old 04-01-2014, 11:53 AM   #267
Valleyrider OP
I Survived The '60s
Oddometer: 1,877
What do you mean?? Anything is possible! Different forks and a 19" front wheel to start with.
It gets easier from the point you're at!!
I have a none titled frame if you want to cut on one for your project.
Old 04-01-2014, 12:22 PM   #268
Calkins
On Any Sunday...
Calkins's Avatar
Oddometer: 505
The tire in the photo is 27" tall, same as the DT IIs I will be using. I cut my frame up yesterday. I am looking for tubes to throw into my lathe and make my extensions.
Seemed like a good idear...
Old 04-17-2014, 06:54 AM   #269
Calkins
On Any Sunday...
Calkins's Avatar
Oddometer: 505
I added 2" to the frame. Using 14" shocks I get a slight rake in the frame, 24* in the neck, and only 4* in the arm...
Old 04-21-2014, 02:01 PM   #270
Valleyrider OP
I Survived The '60s
Oddometer: 1,877
That's looking great!
Keep the posts comin.
I want to see where you go with this.
Times are GMT -7.   It's 05:25 AM.
