Old 03-13-2010, 06:41 PM   #1
wirewrkr OP
the thread-killer
wirewrkr's Avatar
Oddometer: 4,295
Inside An Airhead Muffler
I thought someone might appreciate what a 74-84 muffler looks like on the inside. I sliced one today before canning it.
Rob ert
www.wirewerkes.com
KILL YOUR TELEVISION !!!!
wirewrkr screwed with this post 12-03-2010 at 10:17 PM
Old 03-13-2010, 07:37 PM   #2
walkingbear
walkingbear's Avatar
Oddometer: 3,605
Interesting
just looks like a big chamber .. where is the baffle?
BMWMOA 82741 ABC 8418
2wheeltraditions@gmail.com
75 R90S , 77 R100 RS,88 R100GS ,94 R1100RS (Aragorn) 2k 1150GS DMC sidecar,
Rosso Mandello V11 , 2014 R nine T
walkingbear is offline   Reply With Quote
Old 03-13-2010, 08:36 PM   #3
anonny
What could go wrong?
anonny's Avatar
Oddometer: 5,703
No wonder they sound like a sewing machine
Cool!
Kawasaki H1 build thread
71- 450 Honda CL re & re
anonny is offline   Reply With Quote
Old 03-13-2010, 08:41 PM   #4
bmwhacker
Still on 3 wheels
bmwhacker's Avatar
Oddometer: 4,465
Thanks for the tour....I always wondered what went on in there.....quite a restriction at that one point........
http://jupiterhack.blogspot.com/
Living proof you shouldn't play with matches
ABC# 1992
Old 03-13-2010, 08:44 PM   #5
Airhead Wrangler
Adios Mexico
Airhead Wrangler's Avatar
Oddometer: 6,572
Wow. That's pretty cool. I've never seen the guts of one of those before.
R80ST Gets The HPN Treatment
Seattle to TDF on an airhead
Old 03-13-2010, 09:27 PM   #6
wirewrkr OP
the thread-killer
wirewrkr's Avatar
Oddometer: 4,295
neither had I, hence the picture.
pretty cool huh?
www.wirewerkes.com
Old 03-13-2010, 09:56 PM   #7
Wirespokes
Beemerholics Anonymous
Wirespokes's Avatar
Oddometer: 8,237
I've also wanted to know how they worked! Thanks!
But... now I've got more questions, of course!
So... I see the inlet emptying into the first chamber. Was it meant to exit through just the one hole we see, and the rest of the tubing rusted away?
Then there's a tube connecting the first and third (end cap) chamber.
Now the question: how do the gasses pass from the third back to the second (middle) chamber?
There's a guy in the area here who used to build stainless mufflers - Tom Webb. One of his friends did some research on exhaust technology and came up with the idea that BMW built the mufflers backwards (whatever that means). So Tom built some as directed and with only a slightly throatier note, produced 7 more HP on a 90S in a dyno run. They give the feeling of being in one gear lower.
I've always wondered just what they did to achieve that result. I asked him, but didn't get much of an answer. Perhaps I'll have to have him draw me a diagram.
Old 03-13-2010, 10:45 PM   #8
motu
Loose Pre Unit
motu's Avatar
Oddometer: 4,591
An old theory goes,change the direction 3 times.So it goes into the first chamber,then through the little pipe to the end,turns around and comes back to the middle,then turns again to go out the out hole.And each time it hits a chamber it expands.....controlled expansion,the correct way to contain an explosion and make it safe for the public....and that way you don't get the loud bang.
motu is offline   Reply With Quote
Old 03-13-2010, 11:20 PM   #9
danedg
Horizontally Opposed
Oddometer: 6,735
Very cool...
Jezebel is a bit older than '74, but I assume that the theory and principles remain essentially constant even with new Asiatic repops?
Wirespokes' comments, allude to my longheld theory that a certain amount of backpressure created by the exhaust "system" will yield HP benefits.
I'd guess that's what the skinny chamber would do...
Stagehand, on the other hand, has poo pooed the notion that my exhaust system needed to be "tight"...it's a/2!.. just stick 'em on there!
And between the crossover pipe and the "slip on" silencers, I assumed he was right....
This year, I've actually achieved some gaseous integrity, and though I've not many miles yet, it seems to have made a large difference in performance...better....
When I first got the bike it had a pair of beat up Sirwin's on it...loud as hell and straight thru...I think some PO put 'em on to improve performance...
54' R51/3, 65' R60/2, 68' R60US, 74' Moto Guzzi Eldorado, 95' Mystic
danedg is offline   Reply With Quote
Old 03-14-2010, 06:28 AM   #10
Airhead Wrangler
Adios Mexico
Oddometer: 6,572
If you look really closely, the wall between these two chambers appears to be perforated. You can see in the cut that the cross section isn't continuoous.
Old 03-14-2010, 06:55 AM   #11
Frank06
Oddometer: 235
How did you cut it? It looks like it was done on a mill.
Very cool, BTW.
Frank06 is offline   Reply With Quote
Old 03-14-2010, 08:55 AM   #12
wirewrkr OP
the thread-killer
wirewrkr's Avatar
Oddometer: 4,295
Very cool, BTW.
I have a 4x6 bandsaw and I use it in the upright position ALOT.
I just fed it straight in and held on for dear life..
Same way I did the cylinders awhile back.
Robert
www.wirewerkes.com
Old 03-14-2010, 01:40 PM   #13
Bigger Al
Still a stupid tire guy
Bigger Al's Avatar
Oddometer: 7,980
Robert
"I'd rather wake up in the middle of nowhere than in any city on Earth."
Steve McQueen
Bigger Al is offline   Reply With Quote
Old 03-14-2010, 03:06 PM   #14
El Hombre
Oddometer: 1,536
I've read about using a 3/4" hole saw mounted on an 18" bit extension and drilling the baffle. Now that I can see what's exactly in there, I might not do it. That would bypass almost all of the baffles.
It's supposedly only a little louder, but from you photo, I don't think so.
Anybody try it? Too noisy?
El Hombre is offline   Reply With Quote
Old 03-14-2010, 03:25 PM   #15
wirewrkr OP
the thread-killer
wirewrkr's Avatar
Oddometer: 4,295
Tried it with a long tapered punch, to about 1/2" or so. Not that noisy, but a little more bark.
R
www.wirewerkes.com
Times are GMT -7.   It's 03:45 AM.
