Old 03-14-2010, 04:42 PM   #16
Max Headroom
lost in the '70s
Max Headroom's Avatar
Oddometer: 517
Originally Posted by El Hombre
I've read about using a 3/4" hole saw mounted on an 18" bit extension and drilling the baffle. Now that I can see what's exactly in there, I might not do it. That would bypass almost all of the baffles.
It's supposedly only a little louder, but from you photo, I don't think so.
Anybody try it? Too noisy?
IIRC, that was in an article about hotting up airheads printed in the early '80s, along with a bunch of other performance tips. I'd been reminded of that tip when I was looking at the pics of the disected muffler earlier too.
I'm quite reluctant to try that on my S/S Keihans, but am interested in feedback from anyone who has . . .
'76 R90S silver smoke
'75 R90/6 hybrid
'Skills are learned, talent is ornate.' Billie
Max Headroom is offline   Reply With Quote
Old 03-14-2010, 04:45 PM   #17
bmwrench
Oddometer: 2,130
I did the hole saw trick a lot "back in the day". It does seem to offer a bit more power, and since Udo Gietl suggested it to me...It's not a lot louder, really, just a little throatier.
I backed away from doing it when an older muffler started to come apart on me. That, and most of the guys who wanted fast bikes had moved on.
bmwrench is offline   Reply With Quote
Old 03-15-2010, 04:43 AM   #18
walkingbear
walkingbear's Avatar
Oddometer: 3,542
Muffler gas backpressure?
I've just installed a set of Pea-shooters from Epco and had the header's ceramic coated.a month ago.
I'm experiencing .. low torque starting out and mid-range.
Once it's going ..it's like a jet.
Do I need to jet up or down? I need to get more air to the air box
What is the best way to do this. I'm hoping to have this figured on on
Tech day on Saturday
BMWMOA 82741 ABC 8418
2wheeltraditions@gmail.com
75 R90S , 77 R100 RS,88 R100GS ,94 R1100RS (Aragorn) 2k 1150GS DMC sidecar,
Rosso Mandello V11 , 2014 R nine T
walkingbear is offline   Reply With Quote
Old 03-15-2010, 09:32 AM   #19
wirewrkr OP
the thread-killer
wirewrkr's Avatar
Oddometer: 4,295
i Really like those pea shooters. These are the same set you got.
Off of Ebay, "seconds"??
I think they were a steal!
Robert
www.wirewerkes.com
KILL YOUR TELEVISION !!!!
wirewrkr screwed with this post 12-03-2010 at 10:17 PM
Old 03-15-2010, 09:34 AM   #20
wirewrkr OP
the thread-killer
wirewrkr's Avatar
Oddometer: 4,295
Here's a better angle
www.wirewerkes.com
Old 03-15-2010, 10:11 AM   #21
walkingbear
Oddometer: 3,542
exactly
couldn't resist....... I even bid on another set.. but got beaten
out by some guy in California.
walkingbear screwed with this post 03-15-2010 at 03:06 PM
Old 03-15-2010, 02:00 PM   #22
rufusswan
rufusswan's Avatar
Oddometer: 962
Interesting. Looks kinda lilke a cutaway of a Bose speaker. Exhaust 'tuning' is a bit of a black art, and the math is beyond me.
I do know that for each spark of the plug, there are two pressure waves exiting. One is the expanding gas, and the other is pure sound pressure, both of which move at two distinct speeds. Both of which utilize the available 'space' in different manners.
1971 BMW R75/5 Toaster LWB
1974 Honda CL200
http://zenhuckfinn.wordpress.com/
rufusswan is offline   Reply With Quote
Old 03-15-2010, 04:39 PM   #23
Wirespokes
Beemerholics Anonymous
Wirespokes's Avatar
Oddometer: 8,154
Originally Posted by rufusswan
...there are two pressure waves exiting.
Don't forget the waves reflected from the end of the system returning as well!
Old 03-15-2010, 05:50 PM   #24
Grinnin
Forever N00b
Oddometer: 2,769
I've been looking at cutaways of mufflers wherever I can find them.
I cannot quite tell the shape of the exhaust path from the front to the back. Is that a simple round tube with another sheet of steel behind it or is it a crecent-shaped tube?
THANKS for the pic.
"The belief that there is only one truth, and that oneself is in possession of it, is the root of all evil in the world."-- Max Born, Nobel Physicist
Grinnin is offline   Reply With Quote
Old 03-16-2010, 06:45 AM   #25
Beemerboff
Oddometer: 2,319
Snowbum suggests drilling 4 holes in the flat portion right at the rear adjacent to the outlet.
Looking at the slice that would appear to give some gas a straightish path out.
Probably wouldnt free as much gas as a 1/2 inch hole in the main baffle, but it is easier to reverse if it dont work out as planned.
Adelaide Hills, Australia. 93 R100 GS, 77 R75/7 ,70 BSA B44VS, , 86 R80 G/S PD, 95 BMW Funduro F650 ST
Beemerboff is offline   Reply With Quote
Old 03-16-2010, 03:11 PM   #26
JimX
Oddometer: 711
Was the muffler bearing already gone when you cut it open?
JimX is offline   Reply With Quote
Old 03-16-2010, 07:37 PM   #27
wirewrkr OP
the thread-killer
wirewrkr's Avatar
Oddometer: 4,295
Yeah, they're the first thing to rust out on these models.
The older bikes had a problem with worn phinifler pins and piston pull-back springs weakening, but these later bikes only suffered from rotting muffler bearings.
Go-figure.
RVV
www.wirewerkes.com
Old 03-16-2010, 07:53 PM   #28
bmwrench
Oddometer: 2,130
Go-figure.
RVV
I just hate seeing part names being used incorrectly It's kannidling pins and piston return springs. A weak piston return spring can lead to many hard-to-diagnose problems, including glowing generator warning lights at engine speeds above 13,000 RPM. A green bulb can improve the symptom, but does not fix the problem.
Old 03-16-2010, 09:54 PM   #29
wirewrkr OP
the thread-killer
wirewrkr's Avatar
Oddometer: 4,295
You Yankees just have a different dialect than Jersey boyz.
Just remember, Ya canna get thayuh from heyah.
AHYUH.
RV
www.wirewerkes.com
Old 03-17-2010, 11:17 AM   #30
charliemik
Oddometer: 420
My first Beemer was an R60/6 that had this modification. It definitely had a more authoritative sound than other airhead bikes I'd ride with.
"Knobby tires and a GS do not a dirt bike make" - from Coco's sign-in book.
'81 R80G/S-SOLD (sad but I think the new owner is a really happy guy)
'81 R100RS
'96 R1100GS
'83 VW Westfalia (my 4 wheeled adventuremobile)
charliemik is offline   Reply With Quote
Times are GMT -7.   It's 04:00 PM.
