Old 03-23-2011, 11:29 AM   #16
Calgary06
Calgary06's Avatar
Oddometer: 165
Originally Posted by Lager Meister View Post
I'm trying to relocate the alarm plug and cap, but for the life of me I can't get the cap loose from its mounting tab. It seems like it should just slide off the mounting tab, but no matter what I try it just won't come loose. I'm afraid to use too much force and risk snapping the tab off. What's the trick to getting it loose?
Lager Meister,
Did you ever get that plug off? Mine is well attached and for the life of me I can't get it off. Arghhh.
EEUC
2010 F800GS
Calgary06 is offline   Reply With Quote
Old 03-23-2011, 02:10 PM   #17
PeterX
PeterX's Avatar
Location: Philadelphia/San Francisco Bay area bi-coastal
Oddometer: 187
rear connector.
Originally Posted by Calgary06 View Post
Lager Meister,
I did end up snapping the clip where it is mounted and then just zip tying it in a rear corner - no harm, no foul. Now I have a nice clear space for storage and the connector is just as happy as it was in the middle of things.
PeterX is offline   Reply With Quote
Old 03-23-2011, 08:57 PM   #18
Calgary06
Calgary06's Avatar
Oddometer: 165
Got it off finally. I think I broke the tip off the holding clip though...oh well.
Here is the inside of the cap.
Here is the bottom of the cap showing the retainer.
If you were to jam something under from the left (with respect to this pic)
it might slide right out.
Or if you could lift the end of the retainer from the wire end
...if there is room to actually get something under there....
it would probably slide right out.
And finally the inconvenient location of the stupid wires...
Now the alarm wires are tucked out of the way and all my tools fit under the seat.
EEUC
2010 F800GS
Old 03-23-2011, 11:17 PM   #19
OrcasKen
OrcasKen's Avatar
Oddometer: 126
You're not "missing" a toolkit in that space, but you can add this one from ADV Designs. It's not cheap, but so far has provided everything I've needed.
2010 F800GS
2006 KLX250S
2008 CRF230L
OrcasKen is offline   Reply With Quote
Old 03-24-2011, 02:10 PM   #20
Kerfuffle
Mostly Harmless
Oddometer: 198
I was just looking at that plug this week as I was trying to fit my "always on the bike" tools into that space, and was thinking the same thing - the space would be really useful if that plug were moved. I'll try relocating it this weekend.
Between that space and the space in the seat pan, I have a folding 1/4" drive T handle w/ 8, 10, 12 and 13 sockets, Torx bits / sockets up to T55, hex bits, combo wrenches (8, 10, 12 and 13), needle-nose vice grips, tire gauge, tire plug kit (tubeless in the F658G), bike pump, zip ties and last but not least, a list off BMW dealers and roadside assistance card. Still need to add a few things (adjustable wrench, safety wire) but we're close.
FYI, many of the aftermarket seats (e.g., Sargent enduro-style), have additional storage compartments in the seat pan itself.
Kerfuffle is offline   Reply With Quote
Old 04-03-2011, 05:02 PM   #21
Thorvald
Thorvald's Avatar
Oddometer: 61
Hmm, that looks like a perfect place to put the GS911 in a square box (assuming it's large enough).
08 BMW F800ST, 09 BMW F650GS
Thorvald is offline   Reply With Quote
Times are GMT -7.   It's 06:28 AM.
