Old 03-14-2010, 03:04 AM   #1
jellycow OP
Back on track!
jellycow's Avatar
Oddometer: 985
airhead kickstarter question
So, it seems common to think that the kickstarter of a airhead is not to be used to keep it from snapping something inside the tranny.
I'd like to know what does it mess with and has anybody ever modified one to make it more durable so they could lose the electric starter?
I'm just curious, I've used the kicker on my 60/6 for ever and never had a problem with it so I've though a few times about loosing the magic button on the handlebar.
Sure, the bigger engines are a bitch to kick, but I'd like to believe that's not all there is to this story.
Any thought anyone?
R100GS rescue: only the brave put it on hold for now
Workshop credo: if it ain't broke, fix it till it is.
jellycow is offline   Reply With Quote
Old 03-14-2010, 03:36 AM   #2
SamH
90S on the bench
SamH's Avatar
Oddometer: 436
I ditched the starter on my R45. That bike started first kick every time. Cold or hot. I never had a problem with the kicker.
I have a feeling, as you've said, that it's more of a problem on the bigger engines. Someone will chime in with an educated opinion.
SamH is offline   Reply With Quote
Old 03-14-2010, 04:31 AM   #3
Rob Farmer
Rob Farmer's Avatar
Oddometer: 5,829
It's the teeth on the quadrant that have a habit of snapping off. (item 4)
I've rebuilt 3 gearboxes all with the same problem - all had the first tooth to make contact with the input shaft missing. It could be that more teeth would break with continuous use but once ones gone the action is pretty poor and the owners stopped using the kickstart.
Rob Farmer is offline   Reply With Quote
Old 03-14-2010, 06:59 AM   #4
jellycow OP
Back on track!
jellycow's Avatar
Oddometer: 985
So, it's the teeth on #4 giving up.
And how about the short stroke, looks like having a longer stroke could give more momentum to the crank making it easier to get things rotating. Anybody worked on that?
Times are GMT -7.   It's 03:48 PM.
