Old 03-16-2010, 08:37 AM   #1
davemon OP
High Speed Airhead
Oddometer: 116
Airhead tank slapper
Just did a 1200 mile ride on my 1977 R100S loaded with gear and camping eq. on the ride down road like a champ. Added my coat and riding pants onto the gear in the back and at 25 MPH the handlebars flapped like the tire was square. Repacked the load and same thing just not so bad. Was able to accelerate through the slap mode and cruised fine at highway speed. Made it home removed the load and same dance at low speed. Had the forks rebuilt about a year ago new rear schocks and new tires. Anyone else had this problem? Whats the fix?
Dave
davemon is online now   Reply With Quote
Old 03-16-2010, 08:55 AM   #2
jtwind
Wisconsin Airhead
jtwind's Avatar
Oddometer: 3,488
My r80 with an S fairing did this. Not uncommon on airheads with handlebar or fork mounted fairings and windshields. On mine it was steering bearing adjustment that fixed it. But could as easily be the fork, tires, tire pressure, fairing or windshield attitude, poor shocks or loading/weight issues. I'd just work on making sure each one was right and then move on to the next if it doesn't seem to improve.
If you rode it similarily loaded before you did the forks, shocks and tires and it didn't do this, I'd start there.
JT
www.northwoodsairheads.com
www.jefftrappwindsors.com
"Between two explanations, choose the clearest; between two forms,
the most elementary; between two expressions, the shortest."
Between two motorcycles the simplest (DW)
Eugeni d' Ors (1881-1954); Spanish writer.
jtwind is offline   Reply With Quote
Old 03-16-2010, 09:00 AM   #3
Foot dragger
singletracker
Foot dragger's Avatar
Oddometer: 12,852
The local BMW dealer is an airhead guy,he helped me put new races and bearings in the steering head on a R75/6 I brought back from the dead,he really stressed the adjustment on the steering head bearings. He used a torque measurement device suggested by BMW. He also said my forks would never work rt with out expert assembly and new stock parts.
Evidently the ft end on these older beemers is touchy about adjustment so maybe check all that over closely.
Some bikes around at times
Foot dragger is offline   Reply With Quote
Old 03-16-2010, 10:09 AM   #4
BKMLWR
Wondering around...
Oddometer: 4,611
been riding a 77 R100s since I bought it new in 77, over 170k miles never had a tank slapper except for hitting washboard road once, riding includes 2up cross country trips
Check tire pressure and steering head brgs
BKMLWR is offline   Reply With Quote
Old 03-16-2010, 11:20 AM   #5
Bigger Al
Still a stupid tire guy
Bigger Al's Avatar
Oddometer: 7,930
15 years on an R90/6, and the only time the front wags is when the tire reaches the end of it's life span. Once the shimmy begins, I replace it and things go back to normal. This is irrespective of brand or tread.
Still a good idea to check out the bearings, though.
"I'd rather wake up in the middle of nowhere than in any city on Earth."
Steve McQueen
Bigger Al is offline   Reply With Quote
Old 03-16-2010, 02:25 PM   #6
chasbmw
Oddometer: 2,211
low speed wobble is almost always caused by too loose steering head bearings, move the adjuster nut in small increments until the wobble goes away, but not so much that the bike feels as if you have wound down a friction steering damper.
Charles
Old 03-16-2010, 02:33 PM   #7
dilandau
dilandau's Avatar
Oddometer: 821
Charles
what he said - at least that fixed my wobble. the adjuster nut and the top nut sort of work together to make a friction damper so in my experience it was a bit of trial and error, moving the adjuster nut, then tightening the top--- testing how that was, then doing it again and again- maybe 4 or 5 times until it felt firm but the front end moved easy and smooth side to side.
morini 3.5 strada & sport, r75/6, duc 900sd (project)
dilandau is offline   Reply With Quote
Old 03-16-2010, 09:33 PM   #8
anonny
What could go wrong?
anonny's Avatar
Oddometer: 5,582
So.... how is your front tire? ..... check real close for cupping.
Kawasaki H1 build thread
71- 450 Honda CL re & re
anonny is online now   Reply With Quote
Old 03-16-2010, 11:10 PM   #9
mphoppe
Hops
mphoppe's Avatar
Oddometer: 577
Steering head bearings...this is what fixed mine... follow the directions exactly....
http://www.largiader.com/bearings/
Mike
2006 1150 GS Adventure
2006 CRF 250X
2010 KTM 690R
1995 R100GS (sold)
2007 XR650R as new, for sale
2001 XR650R Desert Bike
2006 KLR 650 Commuter (Sold)
2004 XR650R (sold)
2002 XR650R (sold)
Pro Racing Photos http://mikephotos.smugmug.com/
mphoppe is offline   Reply With Quote
Old 03-17-2010, 02:37 AM   #10
BadBob
Riding or paddling
Oddometer: 14
Tank slapper!
Yo Dave, nature of the beast!
Airheads, untill you`ve felt it, you would not believe!
Mainly because of the engines design.
The airheads are VERY intolerant of ;
Tyre wear/adjustment
Headstock/swingarm adjustment
Any loose frame/rack bolts!....one loose bolt on my rack, while touring in France. Tank slapper so bad, thought my frame had broken!
If you look at the position of the headstock relative to the rest of the frame, (with the tank off)
Its no wonder they somtimes shake there heads!
I welded two tabs on the frame, and attached a strut, on each side. (as I`d seen on endurance BMWs)
If you hold a inch dia. tube in position without removing anything.
just under the tank at the front. just above the S/Arm at rear. Its clear where to attach.
The change in handling is astounding!
From BMW to Italian motorcycle!!!
Ride safe, roll on summer!
BB
BadBob is offline   Reply With Quote
Old 03-17-2010, 03:21 AM   #11
davorallyfan
Commonist
davorallyfan's Avatar
Oddometer: 16,091
BMW's like yours are bad handling things and extremely sensitive to front tyres - change out - check pressures - my 90S was a shocker - I used to change out half worn front tyres to make it handle - ME33's.
They came with dampners but..
A new tyre should fix it steering head bearings - yes but its usually front tyre related
7th Day Adventourist.
Re-incarnated
Terrafied
I have learnt a lot from my mistakes. I am heading out to make a few more.
davorallyfan is offline   Reply With Quote
Old 03-17-2010, 08:51 AM   #12
slash5swb
Oddometer: 1
To get the steering head adjusted right, you have to lift the bike so the front end is hanging free. Starting with the wheel in the straight ahead position, you start to push the bars to one side or the other (doesn't matter which direction.) As you start to push, the bars front wheel should gently and slowly fall the rest of the way to the steering stop. This slow fall represents the right amount of friction from a properly tightened steering head. If the wheel falls quickly and bangs to the stop, it's too loose. if the wheel won't "fall" over on it's own (you have to push it all the way to the stop) it's too tight. It might take several adjustments to get it there, but it works, and it will make the front end very stable. (NOTE: Try to account for cables and wires that impede movement. Test fork in both directions and try to account for this in your estimation.)
slash5swb is offline   Reply With Quote
Old 03-17-2010, 12:09 PM   #13
charliemik
Oddometer: 420
When you're tweaking the steering brg adjustment, you'll know you've gone too tight if your bike starts to do a slow weaving back and forth on the road.
"Knobby tires and a GS do not a dirt bike make" - from Coco's sign-in book.
'81 R80G/S-SOLD (sad but I think the new owner is a really happy guy)
'81 R100RS
'96 R1100GS
'83 VW Westfalia (my 4 wheeled adventuremobile)
charliemik is offline   Reply With Quote
Old 03-17-2010, 12:12 PM   #14
Wirespokes
Beemerholics Anonymous
Wirespokes's Avatar
Oddometer: 8,130
Exactly! With one hand I hold the front of the fender and the other a handlebar. Then turn the front end slowly and feel for either too much free play or notchiness. Yes, notchiness! Too tight and it'll feel like bad bearings.
Old 03-17-2010, 01:09 PM   #15
P B G
Oddometer: 10,001
And when you tighten it up the top nut will change things a bit.
Times are GMT -7.   It's 01:37 PM.
