Old 08-06-2010, 04:13 AM   #16
Cortez
BAZINGA!
Cortez's Avatar
Oddometer: 3,870
Originally Posted by Grainbelt
Speaking from personal experience with the 650R, and probably stating the obvious, KEEP THE HEAVY STUFF IN THE SIDECASES! That big case out back looks like a great place for a case of beer, but it is way out behind the bike, and the shock is under damped as it is. Crank up the preload all you want, but you'll still be bouncing and wallowing around corners.
That setup looks great though - I'm still adjusting to the lack of midrange on the FZ6, those Kwak 650s are great motors.
+1
I keep my preload at 6/7 for my ~200lbs frame and a 35l topcase and
it's "ok", but a bit of good pavement and a happy right hand will make
the rear shock scream.
It's in my opinion the worst single part of the bike.
BTW, I almost replaced my 650R ABS for a Fazer S2 ABS back in 2008,
but it was a bit too much paperwork to deal with at the time so I skipped
the deal..
I remember when I hopped on the FZ6 for the first time. If the 650R
was 650cc, this felt like a 400 at best.. but after 8k.. WATCHOUT
'12 Kymco Downtown 300i ABS, '08 Yamaha FZ6n S2 ABS
SOLD: '03 Peugeot Speedfight2, '07 Kawasaki ER6F ABS, '06 Kymco Agility 125
My Flickr gallery
Cortez is offline   Reply With Quote
Old 08-08-2010, 06:30 AM   #17
Green427
Morbidly Obtuse
Green427's Avatar
Oddometer: 1,070
Originally Posted by Sumo64c
Now that is nice!!!
1995 CB750 Nighthawk
Green427 is offline   Reply With Quote
Old 10-03-2010, 05:46 AM   #18
Veda
Veda's Avatar
Oddometer: 28
RunningWild, How do you like those handguards? Do they block out some of the cold wind? I have been thinking about getting a pair. How was installation, I am not very handy.
I have the Givi v46 on my er6n on the Givi rack. Got the rack from twisted throttle and used it with an old JC Whitney case last year. Got the Givi case this year from sporttour, very fast and free shipping.
Lots of photos here of the Givi v46 on my ER-6n
Having had both the JCWhitney and now the Givi the Givi is much nicer and I think looks a lot better.
Another word of caution. A few months after installing the Givi rack I checked it one day to find two of the four bolts holding it onto the bike had sheered off ! I don't believe I ever overloaded the rack, I think Givi just sent crappy bolts. Twisted throttle customer support referred me to Givi support who were friendly but all they did was send new (heavier duty bolts). I was still out the $125 to have the old bolts drilled out :( Not to mention what would have happened if the others sheered off while riding and the whole set up fell on my back wheel. So far no problems with the better bolts, but be sure to check frequently!!
www.bikesareforgirls.com
Twitter: @bikesR4girls - Follow us for daily deals on motorcycle gear and accessories
Veda screwed with this post 10-03-2010 at 05:53 AM
Veda is offline   Reply With Quote
Old 10-05-2010, 03:04 PM   #19
RunningWild
ADV Wannabe
RunningWild's Avatar
Oddometer: 187
The Barkbusters Storm handguards work really well. Installation was simple and straightforward. I bought them last winter and liked them so much I kept them on for the summer. Really helps keep the rain off and some wind. They even protected my brake lever from breaking after a slow speed tip over.
10 KTM 990 ADVENTURE
www.crossfit.com
RunningWild is offline   Reply With Quote
Old 10-08-2010, 09:28 AM   #20
unL33T
Oddometer: 9
Originally Posted by Cortez
The 650R/ER6F stuff fits, the only difference between those bikes is
in angle of the front shocks. There's Givi / Kappa stuff available, sidecases,
topcases, the lot.
I think you're wrong about the front shocks, as far as I am aware the 650R (also called the ER-6F elsewhere) is exactly the same as the ER-6N other than the body work (and some tabs on the frame to mount the body work). Versys is completely different frame, shocks, etc but the engine is the same with different cams and different tuning. Check out Ninja650Shop.com for aftermarket accessories that fit both. There are risers on there and several handlebar options. brp650forum.com, riderforums.com, and kawiforums.com are all great places to find info on this bike. A lot of aftermarket stuff for the 06-08 years will fit and work on the 09+ models.
unL33T is offline   Reply With Quote
Old 10-10-2010, 03:32 AM   #21
Cortez
BAZINGA!
Cortez's Avatar
Oddometer: 3,870
The 650R/ER6F stuff fits, the only difference between those bikes is in angle of the front shocks.
I was commenting on the ER6n vs. 650R/ER6F, I'm aware the latter are
the same bike called differently in various parts of the world (no rear
grab rails though on the 650R.). I own the 2007 EU ER6F w/ABS.
As for the ER6n vs. 650R/ER6f shock thing I mentioned..
it IS exactly the same, however, the ER6n's front fork rake angle is
slightly different, resulting in a 1 or 1,5cm shorter (I forget, I knew
this in 2007 when I bought the bike) wheelbase on the naked version.
That's about 0,4-0,6".
My Flickr gallery
Old 10-10-2010, 07:31 AM   #22
unL33T
Oddometer: 9
Checked the specs. You're right. My mistake. Never heard of that before in all my time frequenting the forums specific to those bikes.
Old 10-10-2010, 08:08 AM   #23
Cortez
BAZINGA!
Cortez's Avatar
Oddometer: 3,870
I did my homework before buying the bike.. ..but not to the point that
I figured out that the new Bandit 650 was just coming out a few months
later with fuel injection/water cooling/abs, and same goes for the Honda
CBF600S.. at which I'm now looking at as a replacement.
Oh well!
My Flickr gallery
Old 03-20-2011, 05:03 PM   #24
Ken in Regina
Oddometer: 19
Sorry to bring this old thread back and I hope your memory is good. Do you remember whether you got the S7 (bar end mounted) or the S1 (handlebar bracket mount)?
I want to put a Kaoko throttle lock on my 2010 ER6n when I get it (soon). I also want to change to a wider bar with a bit more rise. So I don't want to depend on a bar end mounting.
...ken...
Ken in Regina is offline   Reply With Quote
Old 03-21-2011, 04:28 AM   #25
Veda
Veda's Avatar
Oddometer: 28
I ended up getting the Barkbusters too. Mine are the bar end mounted ones. They are a "universal fit" so not exclusive to the ER-6N bar end. They might fit other ones too.
I put together a brief video review/guide on the barkbuster storms, although I later was told I have installed them upside down in the video.
http://bikesareforgirls.com/2010/10/...rm-handguards/
Old 03-21-2011, 10:04 AM   #26
madisonreid
Oddometer: 1,476
Having owned a Versys (2x) and a 09 650r I can say the big difference is gearing and ergos. Both of course can be tweeked to meet your needs. I went with the V again after owning and enjoying the 650r simply because of the riding position and customizing potential all and a very reasonable price. All three are outstanding choices. Good luck-ride safe.
madisonreid is offline   Reply With Quote
Times are GMT -7.   It's 02:05 PM.
