Old 03-16-2009, 01:05 PM   #766
Velvet Elvis
mild mannered adventurer
Velvet Elvis's Avatar
Oddometer: 158
Thumb
Prolly more of a cosmetic dirtbike than actual, but I sure think it looks cool.
From the Boxer Schmiede website @ http://www.boxerschmiede.de/.
Don't think I've seen this one posted here before; sorry if it's 205.
Kevin
Zoinks
Velvet Elvis is offline   Reply With Quote
Old 03-20-2009, 04:19 PM   #767
2ndlaw
2ndlaw's Avatar
Oddometer: 78
I hate to be critical but...
I can't fault the workmanship, but this is a design error:
Loads from the diagonal tube will deform the walls of the frame's backbone. The headstock will be stiffer; the frame will fail further back.
Rule 1: Try to keep tubes in compression/tension.
Rule 2: Attach gussets at the neutral axis of the tube.
1971 CL350
1986 K75
1988 R100GS
HPN Baja #420
2ndlaw screwed with this post 03-20-2009 at 04:24 PM
2ndlaw is offline   Reply With Quote
Old 03-20-2009, 04:26 PM   #768
2ndlaw
2ndlaw's Avatar
Oddometer: 78
They did my cylinder heads for my HPN. (I lived in Berlin at the time.)
They are cool.
1971 CL350
1986 K75
1988 R100GS
HPN Baja #420
Old 04-02-2009, 02:41 AM   #769
Warthog
TeutonicChronic
Warthog's Avatar
Oddometer: 845
Thumb compassionate moment...
Originally Posted by Roma
Y'know...some douchebag in the GSpot told me "don't try to school me on Airheads. They are relics".
I'm just sitting here thinking it would be cool if you drove that yellow headlight relic right up his ass.
I feel better now.
Warthog
2006 HP2
Warthog is offline   Reply With Quote
Old 04-02-2009, 09:21 AM   #770
photojojo
This space for rent!
photojojo's Avatar
Oddometer: 470
I have this...
On occasion I would want something like this...
Would it be feasible to start collecting parts and swap them out when I knew I was going to be riding rougher stuff? If for no other reason than to keep the pretty white stuff pretty. It seems like I could just change out the tank, seat, and headlight and be mostly there. Is that right? mines a 93 what tanks would fit? Suggestions on headlight? What about changing the rear fender out to a dirt style fender? Is there an aftermarket rear fender that works well?
Chris Jennings TJA
2002 BMW K1200LT
Gone, but not forgotten 1998 Honda ST1100, 1993 BMW GSPD, 2005 KTM 400 EXC, 2004 ZRX 1200, 2001 XR650R, 1993 DR350, 1978 BMW R100, 1984 BMW R80RT, 1993 KLR650
photojojo is offline   Reply With Quote
Old 04-02-2009, 10:44 AM   #771
Solo Lobo
airhead or nothing
Solo Lobo's Avatar
Oddometer: 8,820
Roma's bike us an R80G/S, but that said the pre-91 (?) GS's had the same headlight set-up and the non PD tank... you can buy these used and swap them on.
Haven't done the fairing to earlier-style headlight switch, but I think there is enough envolved that you wouldn't be doing it for the occasional dirt jaunt, there seems to be a significant about of work involved to remove the fairing and 'roo bar...
"punk rocks what it's all about" - J. Strummer
R65LazaruS
So I sold my GS and went shopping for a G/S!
Solo Lobo is offline   Reply With Quote
Old 04-02-2009, 11:01 AM   #772
Airhead Wrangler
Adios Mexico
Airhead Wrangler's Avatar
Oddometer: 6,496
A friend of mine is actually doing that same conversion right now... puting on the exact same headlight in fact (same one I have too). You'll have to figure out a way to relocate (or replace) your gauges and iginition switch as well as all the associated wiring behind your dash, so I think it'd be more of a semi-permanent conversion, definitely not hot-swoppable. There's definitely something to be said for this conversion though. On a GSPD you're looking at losing a good 10-15 pounds or so from the highest part of the bike.
R80ST Gets The HPN Treatment
Seattle to TDF on an airhead
Airhead Wrangler is online now   Reply With Quote
Old 04-02-2009, 11:15 AM   #773
Stagehand
+/- V TDSPP
Stagehand's Avatar
Oddometer: 26,487
Just lose the Pretty but Useless Plastic bits, add knobby tires and its good to go!
Roma's bike rocks, its true.
Unintentional psychokinesis.
Stagehand is online now   Reply With Quote
Old 04-02-2009, 11:20 AM   #774
StephenB
G(/)S ... what else!
StephenB's Avatar
Oddometer: 2,044
I actually mod'ed the stock GS wiring loom heavily to accommodate the changes, which includes digital instrument, revised idiot lights, H4->HID conversion etc. I used mostly waterproof 2-, 3-, 4- and 5-pin AMP SuperSeal connectors and added a waterproof marine type ignitiuons switch. Cleaned all older connections further down the loom with electric cleaner and used dielectric grease generously. A lot of electric gremlins can be avoided.
(Click on picture to enlarge)
Some of the above is fact, some is fiction, some is my personal imagination and some is just simple truth. [me]
... i'm not touring around the world, but neither are most of the guys i see running overloaded spam cans ... [bmwblake]
Stephen Bottcher
Ontario, Canada
'72 R75/5 The Blues
www.stephenbottcher.net
StephenB is offline   Reply With Quote
Old 04-02-2009, 12:50 PM   #775
photojojo
photojojo's Avatar
Oddometer: 470
That's along the lines of what I was thinking of doing. What are you using for instruments?
Chris Jennings TJA
2002 BMW K1200LT
Old 04-02-2009, 12:55 PM   #776
StephenB
StephenB's Avatar
Oddometer: 2,044
Trailtech Vapor, LED Voltmeter, Accessory plug and ignition switch:
Click pictures for hi-res image
Stephen Bottcher
Ontario, Canada
'72 R75/5 The Blues
Old 04-15-2009, 06:13 PM   #777
atgreg
Africatwinarama
atgreg's Avatar
Oddometer: 10,023
a modded airhead competeing in a 2 day rallye in Oz
1990 RD04 Africa twin 750
350,000km and still going strong
atgreg is offline   Reply With Quote
Old 04-15-2009, 06:18 PM   #778
atgreg
Africatwinarama
atgreg's Avatar
Oddometer: 10,023
Some action
Old 04-15-2009, 06:24 PM   #779
atgreg
Africatwinarama
atgreg's Avatar
Oddometer: 10,023
The old airhead was going OK
Old 04-15-2009, 07:56 PM   #780
photojojo
photojojo's Avatar
Oddometer: 470
What tank is that?
Chris Jennings TJA
2002 BMW K1200LT
Times are GMT -7.   It's 06:50 AM.
