Old 10-20-2009, 01:13 PM   #901
Havannags
Oddometer: 4
Yes the swingarm is extended 100 mm by welding.
Here are the bigger pictures.
Havannags is offline   Reply With Quote
Old 10-20-2009, 01:22 PM   #902
Caddy82rats
Caddy82rats's Avatar
Oddometer: 1,075
Thanks, nice work on the swing arm, what a pity to let this bije go away
Caddy82rats is offline   Reply With Quote
Old 10-21-2009, 08:48 PM   #903
FatBoyCrash
Buckle up SpankY!!
FatBoyCrash's Avatar
Oddometer: 1,111
Gudday all,
Just a quick question, when the swingarm is extended, where how what when do you get a 100mm longer driveshaft???
Is there a thread about this lurking somewhere??
Regrads
FBC
Built In Shed
Because chrome don't get ya home.
FatBoyCrash is offline   Reply With Quote
Old 10-21-2009, 10:37 PM   #904
igormortis
igormortis's Avatar
Oddometer: 1,082
Have a look at these threads for an extended mono driveshaft:
http://www.advrider.com/forums/showthread.php?t=467221
http://www.advrider.com/forums/showthread.php?t=432325
Also note the other method mentioned, which is a longer coupling to the final drive - pictured in the first thread I've linked to.
igormortis is offline   Reply With Quote
Old 10-22-2009, 04:27 AM   #905
Rucksta
Chronic Noob
Rucksta's Avatar
Oddometer: 2,292
Originally Posted by FatBoyCrash
Gudday all,
Regrads
FBC
Paul Rooney down Ballina way does a longer shaft.
Rucksta is offline   Reply With Quote
Old 10-22-2009, 06:01 AM   #906
waspp
waspp's Avatar
Oddometer: 214
Curious what front end is that on your GS? I have heard YZ450 forks and triples will work with slight modification. I have found the old spindley forks to be a real weak point.
Hal
03 Moto Guzzi rosso corsa
78 Guzzi T3 cafe
79 Moto Morini 3 1/2 sport
2011 BMW GS
2013 F650GS (the wife"s)
waspp is offline   Reply With Quote
Old 10-22-2009, 06:18 AM   #907
bgoodsoil
Dare to be Stupid
bgoodsoil's Avatar
Oddometer: 3,786
They're WP 4054s. Says it on the front. White Power has been making forks for KTM for ages so it's probably off an old KTM. The 4860s are the USD forks on their new stuff.
'85 BMW r80G/S--Another G/S on the road--Central America on a Shoestring--Nova Scotia on a Shoestring
Proud SmugMug User Support ADV: Don't give those cheap bums your discount code
bgoodsoil screwed with this post 10-22-2009 at 06:27 AM
bgoodsoil is offline   Reply With Quote
Old 10-22-2009, 09:28 AM   #908
herb28
Oddometer: 46
Stagehand, what all, if anything, have you done to that PD to make it more dirtworthy? I have an 89GS that I want to dream about taking off road. That looks fun!
is that a watermelon?
herb28 is offline   Reply With Quote
Old 10-22-2009, 01:38 PM   #909
Havannags
Oddometer: 4
The front end is a ktm WP 4054 with stiffer springs. The only thing that i have to do is turning the diameter of the bearing to ø 28 instead of the original ø 29mm. The offset of the triples is much less than BMW,it is only 22 mm.
Old 10-22-2009, 05:54 PM   #910
Stagehand
+/- V TDSPP
Stagehand's Avatar
Oddometer: 19,875
Mostly stock except for a Wilbers rear, Progressive front springs, 15w, and an HPM steering damper setup, and some Carmichael SE motocross bars. Other than that it still weighs a metric shit-ton
What to do... What to do...
Stagehand is online now   Reply With Quote
Old 10-26-2009, 09:56 PM   #911
meijer's trails
meijer's trails's Avatar
Oddometer: 403
what's required to flip the rear brake actuator?
I'd like to do a "high brake" mod to my 1981 r80g/s. I see many of the bikes in this thread have that.
What is necessary? can I just put it on upside down? it looks like the cam will rotate the wrong way then. Should i reverse front and rear brake shoes?
thanks
jason
meijer's trails is offline   Reply With Quote
Old 10-27-2009, 12:16 AM   #912
Dustdevill
Dustdevill's Avatar
Oddometer: 228
You will need to run a Bowden cable otherwise the rear brake will start to be activated as the wheel travels up. When you bottom out on the suspension you could lock up the brake creating a dangerous situation.
The Bowden cable create more resistance and will reduce braking. I would recommend making a flexible cable from 4,5 mm cable(same as most car clutch cable). Get the cable maker to make the cable with both ends fitted with a 6 mm fitting and use the screw in fitting on the brake lever side of the old rod to adapt your cable to fit the brake lever.
With this you can then just keep a spare brake arm, it is small and light enough to keep in your tool kit.
If you ride in very rocky terrain often I would recommend the HPN floating cam in upright position with Bowden cable.
Dustdevill is offline   Reply With Quote
Old 10-27-2009, 06:46 AM   #913
meijer's trails
Oddometer: 403
Thumb thanks
thanks! I didn't even know about the HPN cam!
Old 10-27-2009, 07:16 AM   #914
Beater
Scope Creep's Victim
Beater's Avatar
Oddometer: 2,207
This is so sexy it hurts.
Fred
'85 R80RT G/Sified
'91 R100GS Bumblebee
Airhead Zen: Ride-Maintain-Repair-Ride On.
Beater is offline   Reply With Quote
Old 10-27-2009, 05:25 PM   #915
kennyk
Oddometer: 40
First off great thread. I M in the planing a parts collecting stag on converting a 84 R80RT into a ADV bike it will only be a dual purpose bike it will see some fire roads minor trails and street. Would like to find some info. It will be built in stages. Build in the winter and ride in the summer, etc. I M going this route because no funds to go out and get a true GS, every one seems to very proud of their bikes as they should be.
1. What shocks on a dual shock set up?
2. What is the simplest frok swap.
Any advice welcome
kennyk is offline   Reply With Quote
Times are GMT -7.   It's 05:01 AM.
