Old 06-19-2012, 09:31 PM   #1336
rediRrakaD
Whoopdie do
rediRrakaD's Avatar
Oddometer: 851
Me likey
Beauty that one.
S.
"Death in the pursuit of happiness is triumphant!"
rediRrakaD is offline   Reply With Quote
Old 06-20-2012, 03:39 AM   #1337
gsd4me
90% bluff
gsd4me's Avatar
Oddometer: 7,615
Originally Posted by Box'a'bits View Post
Steve, is that a TAG tank with two fuel caps?
David Hunn:
R100GS Ray Peake special.
http://www.advrider.com/forums/showt...uild+australia
gsd4me is offline   Reply With Quote
Old 06-20-2012, 11:29 AM   #1338
Caddy82rats
Caddy82rats's Avatar
Oddometer: 1,190
4 lugs on the wheel, and a R80 G/S swing arm, interesting
Caddy82rats is offline   Reply With Quote
Old 06-20-2012, 12:02 PM   #1339
Stagehand
Imperfectionist
Stagehand's Avatar
Oddometer: 26,975
Did they change the pinion gear inside the mono FD?
Unintentional psychokinesis.
Stagehand is online now   Reply With Quote
Old 06-20-2012, 12:18 PM   #1340
Beater
The Bavarian Butcher
Beater's Avatar
Oddometer: 3,527
The shafts were the same for the G/S's and the mono-levers. You can then get a mono-lever final drive (4 lug) and a GS hub ... lace it slightly off center to allow a bit of room for your rear tire ... and viola. FYI - That swingarm looks a bit longer than stock. It wouldn't surprise me if that rear shcok mount was added.
This is a great mod because it allows you to run a variety of final drives that were available in the R80's and R100 monolevers. The R80 G/S only had the one 37:11 which is perfect for dirt, but doesn't have much top end for highway speeds. I'm currently looking for the 33:11 mono final drive to do exactly what is above!
Fred <|> Need an Airhead Part? .... I May Have It!
'85 BMW R80RT G/Sified <|> '73 BMW R75/5 LWB <|> '94 MZ Silver Star Hack
Beater is online now   Reply With Quote
Old 06-20-2012, 12:24 PM   #1341
Airhead Wrangler
Adios Mexico
Airhead Wrangler's Avatar
Oddometer: 6,571
Originally Posted by Beater View Post
You can then get a mono-lever final drive (4 lug) and a GS hub ... lace it slightly off center to allow a bit of room for your rear tire ... and viola....
Just be aware, that there's a good bit of machining to do on a GS hub to make it fit a 4 lug mono final drive. Stephen Botcher's site has plenty of pics of what you need to do.
R80ST Gets The HPN Treatment
Seattle to TDF on an airhead
Old 06-20-2012, 12:37 PM   #1342
Beater
Beater's Avatar
Oddometer: 3,527
True true ... you have to lathe off a fair chuck of material from the inside of the hub. I haven't yet figured out how I'm going to accomplish that that one ... I do know a fair amount of machinists around here though. We'll see.
At least I've secured the hub!
Old 06-20-2012, 03:39 PM   #1343
Box'a'bits
In need of repair
Box'a'bits's Avatar
Oddometer: 2,361
Nope. Single GS style cap. Don't know what the tank is. I've sent a PM to Tony asking about this, & also what he did re the swingarm. I know he has 2 wheel sets, the 'motard' version & the 'dirt' version. He doesn't get onto ADVrider much.
Also that he is way quicker than me on Gravel...
My '91 R100GS thread is here
My Ride photos are here
Box'a'bits is offline   Reply With Quote
Old 06-20-2012, 06:35 PM   #1344
Beater
Beater's Avatar
Oddometer: 3,527
He doesn't get onto ADVrider much..
With a bike like that .... and if I were a trustafarian ... I wouldn't be either
Old 06-20-2012, 06:41 PM   #1345
Stagehand
Imperfectionist
Stagehand's Avatar
Oddometer: 26,975
maybe its the colors... that bike is really doing weird things to me
Old 06-20-2012, 07:28 PM   #1346
Airhead Wrangler
Adios Mexico
Oddometer: 6,571
It's the monolever. ...and the tank.
Imagine BMW nowadays accepting racing sponsorship from cigarettes and porn. Those were the days.
Old 06-20-2012, 07:40 PM   #1347
Stagehand
Imperfectionist
Stagehand's Avatar
Oddometer: 26,975
no kidding. WIsh I was old enough to remember them
Although I can say I am old enough to have smoked a cigarette on a flight. Those days I remember.
Just seen on FB:
Herbert Shek aux GS DAYS France 2012.
Stagehand screwed with this post 06-20-2012 at 07:46 PM
Old 06-20-2012, 10:19 PM   #1348
Kokopelli
Yeah, right!
Kokopelli's Avatar
Oddometer: 4,701
Just seen on FB:
He was/is the local BMW bike dealer where I grew up. Most people considered him nuts for doing the Dakar. There was no GPS or radio back-up when he did it. Once he was lost for a while until they found him with a broken leg, if I remember correctly. Just checked, apparently it was head -injury and he spent some time in a coma. He is in his eighties.
R1150GS
R80GS Basic
Kokopelli screwed with this post 06-20-2012 at 10:28 PM
Kokopelli is offline   Reply With Quote
Old 06-21-2012, 03:20 AM   #1349
guzzitony
Guzton
guzzitony's Avatar
Oddometer: 170
some bike info on Marlboro R80GSGRrr
Hiya, a mate bought a bike with the tank on it,didn't want one that big so i had to help him out.
it had been crashed so took a bit to fix/ fit, and had to cut a second seat shorter by about an inch at the front. i also made new side covers so i didn't have to notch the originals. not quite as big as the plastics but still 40L. i don't have a clue where it came from originally.
Swingarm- HPN stamped on the shock mount and also on the bottom of the WP shock, 100mm longer than normal. it used to flex quite a bit. i notched it to fit the bigger tyre and braced it at the same time (i tested this with the orig wheel and definite improvement). yes it's a 11/33 diff and i got a cam made to flip the lever up.
as mentioned earlier, the centre of hub was machined out and rim moved across in relation to hub. a local legend did this with the original spokes as i didn't want it too far across in case it stuffed up front/rear illignment too much.
*when fitting a new tyre i cut 5 or so mm off the outside knobs to help with clearance - i just ride really slowly around right hand corners!
gotta rest a bit, lotta words for me. i can do a vol 2 if anyones interested but not much else major stuff.
cheers Tony
SHEDSAM- objects given/collected and stored in a
shed/mancave. esp car/bike parts.
guzzitony is offline   Reply With Quote
Old 06-21-2012, 04:13 AM   #1350
igormortis
igormortis's Avatar
Oddometer: 1,381
33/11 - that seems quite high for a dirty bike! No wonder you’re faster than Steve.
Oh, and good job getting that wheel re-laced locally! No-one I asked wanted to know, legends included.
igormortis is offline   Reply With Quote
Times are GMT -7.   It's 08:02 AM.
