Old 03-10-2013, 08:56 AM   #1441
mex
Oddometer: 20
and the trail tech light is perfect for transporting your starter cable...
(if the regulator fails in the middle of mongolia...)
mex screwed with this post 03-10-2013 at 09:09 AM
mex is offline   Reply With Quote
Old 03-10-2013, 09:00 AM   #1442
Lornce
Lost In Place
Lornce's Avatar
Oddometer: 18,111
Great looking bike, Rose.
Is that subframe your own design/construction.
Originally Posted by Rose View Post
Just fitted a 8" Trail tech unit to the airhead. No technical inspection for bikes over here, so I'm taking the risk of running a single beam...
I think it looks good on the airhead, a bit of eighties retro...:ymca
Old 03-10-2013, 09:53 AM   #1443
CrazyIvan
Vonkentrekker
CrazyIvan's Avatar
Oddometer: 151
Yes it is.
CrazyIvan is offline   Reply With Quote
Old 03-10-2013, 11:37 AM   #1444
naginalf
Handy Schtroumpf
naginalf's Avatar
Oddometer: 250
Originally Posted by Box'a'bits View Post
It isn't high & low power.
It's is a bit more complex than that. High & Low beam are a function of the light source's position relative to the shape of the reflector, & also the cut of the lens.
In New Zealand the light must dip to the left so as not to dazzle oncoming drivers. There also needs to be a defined cut off to the beam, aimed below the oncoming driver's direct line of sight.
Oh, yeah, duh, I forgot about the tiny reflector inside most dual bulbs, not to mention the lense. You're right, it would still blind people. Well, there may be a solution to that as well. Ok, first thought, make a rock guard double as a light guide/ louvre, like you used to see on the rear window of 70's trans ams. I think that would actually look pretty awesome, you could even make it adjustable. Second idea and much more subtle, install a small, shiny metal reflector over the bulb with a wire hinge secured to the plastic socket, then... hmm, well you could use a simple neo magnet, but a more elegant solution would be to wire a small electro magnet coil into the lighting circuit. I guess there'd have to be some sort of bar for the reflector to rest on so as not to break the bulb eh? ...ok, a long thin bolt attached to a hole in the base ought to do the trick. I may try this when I get my tt light ( someday).
And the lense... don't they have a "flood" version of these lights. Perhaps simply attaching a lense cover. Ok, yeah, this is getting ridiculous, why the hell don't they make a driving version?! Grr.
'91 R100GSPD
Adventures with a Type1 TARDIS.
naginalf screwed with this post 03-10-2013 at 01:28 PM
naginalf is offline   Reply With Quote
Old 03-10-2013, 12:52 PM   #1445
bgoodsoil
Dare to be Stupid
bgoodsoil's Avatar
Oddometer: 4,557
Dayum! Can you tell us anything about the sub-frame?
'85 BMW r80G/S--Another G/S on the road--Central America on a Shoestring--Nova Scotia on a Shoestring--Never Leave a Man's Behind
Proud SmugMug User Support ADV: Don't give those cheap bums your discount code
bgoodsoil screwed with this post 03-10-2013 at 02:03 PM
bgoodsoil is offline   Reply With Quote
Old 03-10-2013, 02:09 PM   #1446
Beater
Freakin' Swamped
Beater's Avatar
Oddometer: 3,353
Both of the men had been trained for this moment, their lives had been a preparation for it, they had been selected at birth as those who would witness the answer, but even so they found themselves gasping and squirming like excited children.
"And you're ready to give it to us?" urged Loonquawl.
"I am."
"Now?"
"Now," said Deep Thought. ...
"Tell us!"
"All right," said Deep Thought. "The Answer to the Great Question ..."
"Yes ... !"
"Of Life, the Universe and Everything ..." said Deep Thought.
"Yes ... !"
"Is ... " said Deep Thought, and paused.
"Yes ... !"
"Is ... "
"Yes ... !!! ... ?"
"Forty-two," said Deep Thought, with infinite majesty and calm. ...
"Forty-two!" yelled Loonquawl. "Is that all you've got to show for seven and a half million years' work?"
"I checked it very thoroughly," said the computer, "and that quite definitely is the answer. I think the problem, to be quite honest with you, is that you've never actually known what the question is."
- Douglas Adams (Hitch-hiker's Guide to the Galaxy)
Originally Posted by mex View Post
And I can tell you with much certainty, that in this particular case ... 42 is indeed the answer ... and I also have a sneaky suspicion as to the question. Yes indeed I do.
Fred * '85 R80RT G/Sified * '73 R75/5 LWB
"Simple" with a Goal of "Ludite"
Beater is offline   Reply With Quote
Old 03-10-2013, 02:23 PM   #1447
naginalf
Handy Schtroumpf
naginalf's Avatar
Oddometer: 250
Laugh
Nice! Well said Fred. Well. Said.
'91 R100GSPD
Old 03-10-2013, 06:52 PM   #1448
hardwaregrrl
ignore list
hardwaregrrl's Avatar
Oddometer: 7,475
+1 Fred, always full of surprises!
Old 03-11-2013, 12:52 AM   #1449
mex
Oddometer: 20
at least both of us had the answer.
Old 03-11-2013, 08:47 AM   #1450
gs-ell
gs-ell's Avatar
Oddometer: 100
Thats amazing!!
Can i ask, what front frame have you used to take the swingarm?? have you had to modify it in anyway to centre the rear wheel??
I'm building a race bike, with the same swingarm (1100rs running k1200 cast wheels) with an R65 1981 frame, but i'm gonna have to chop and move the swingarm mount out to the right by 20mm, did you do this to yours, it looks like you've done some welding around the area.
Many thanks
Elliott
gs-ell is offline   Reply With Quote
Old 03-11-2013, 10:49 AM   #1451
CrazyIvan
Vonkentrekker
CrazyIvan's Avatar
Oddometer: 151
Originally Posted by gs-ell View Post
Thats amazing!!
Many thanks
Elliott
The frame is off a 100GS, and the 1100 swingarm is mounted as far as possible to the right (it's narrower than the original swingarm). The rear wheel is spoked with an offset.
Cheers.
Old 03-11-2013, 12:58 PM   #1452
Ras Thurlo
Desert Lion
Ras Thurlo's Avatar
Oddometer: 660
Thats amazing!!
we covered some of this ground in this thread
http://www.advrider.com/forums/showt...=859536&page=3
Ras Thurlo is offline   Reply With Quote
Old 03-11-2013, 01:01 PM   #1453
gs-ell
gs-ell's Avatar
Oddometer: 100
perfect thanks!!!
Old 03-16-2013, 09:47 PM   #1454
Phreaky Phil
Oddometer: 1,830
Cheers.
Hi Ivan, do move the engine all the way over to the right in the frame, that is, no spacer ? Ive been having a look this afternoon an you can only move the motor so far before it hits the spring post for the center stand. I guess that could be modified. I managed to pick up another rear 1100GS reat wheel yesterday. They don't come up for sale often over here. What brand of triple clamps have you got. Are they a custom made set ?
Cheers Phil
Phreaky Phil is offline   Reply With Quote
Old 03-16-2013, 10:37 PM   #1455
motu
Loose Pre Unit
motu's Avatar
Oddometer: 4,533
No, a motorcycle beam can dip straight down, can have a centred beam and must have a drop rate of 3 to 3.5%. You only need just the dip beam too, the high beam only has to work if fitted...really it's if a dip switch is fitted, you can have an H4 bulb for example, but if there is no means of selecting high beam that's OK.
motu is offline   Reply With Quote
Times are GMT -7.   It's 09:06 PM.
