03-19-2010, 09:24 AM
#16 |
Oddometer: 369
I've been wanting to get a set for sometime now, but the website says the 18" type only goes to a 2.15" rim width. Has anybody tried it on a 2.5" rim, or know when Nuetech will have one available?
03-19-2010, 09:46 AM
#17 | |
Oddometer: 4,911
There is a special liner, in which you place a thin high pressure inner tube. AFAIK they used to use road bicycle inner tubes.
Proud member of the HUSABERG ADVENTURE TEAM! '12 Husaberg FE570, 09 KTM XC-F/ 450 RFS hybrid, 07 KTM 450 SMR, 08+09 BMW F650GS twins/F800GS conversion, 03+05 YZF-R6 |
03-19-2010, 09:49 AM
#18 |
Candyass Camper
Oddometer: 3,333
BMW Atlanta, do you know which tube is a direct replacement for the Nuetech? I work part time at a bicycle shop, and while the pneumatic tube in the inner liner looks quite similar to a heavy duty tube at the bike shop, the size seems a bit unique. One other issue is that most of the bicycle tubes in this diameter...tube material diameter, not the rim diameter...use a presta valve not a schrader valve. I'm not saying there's nothing out there for a replacement, but I'm not sure it's a direct replacement.
I don't think the inner liner high pressure tube is in a very hazardous position. You've got the supplied heavy duty rim tape on one side and the hard shell plastic bead clamp on the other. A very long nail at just the right angle could/might penetrate the hard shell and then puncture the tube, but it's not a likely scenario. I don't think there's much question that about the only time the inner liner tube is punctured is during improper installation or the pressure isn't checked in a timely manner. Tusker, on the composition of the hard shell, the air valve, and the inner liner tube, the inner liner tube actually just "snakes" around the valve that inflates the air chamber of the tire itself. Sounds odd but not a problem. |
03-19-2010, 10:07 AM
#19 | |
Oddometer: 837
03-19-2010, 10:13 AM
#20 |
Geek Adventurer
Oddometer: 4,601
I am following this thread - but a few thoughts on some of the questions/reservations:
1) Whether the Tubliss tube is a bicycle inner tube or not, those tubes are a lot lighter, smaller and easier to carry as a spare than a conventional motorcycle tube. If I was going somewhere in BFE, I would carry that spare as it would not be that big of a deal. Yeah, bicycle inner tubes may actually be easier to find in the third world because there are a lot more bicycles there actually being used as transportation, but ROI on carrying such a small light spare would make it worth it. 2) Bicycle inner tubes come in 'heavy duty' too. 3) There are valve adapters.
'09 Husaberg FE570 '99 Beta Alp '04 Ducati MTS - sold Not all who wander are lost |
03-19-2010, 11:12 AM
#21 |
Geek Adventurer
Oddometer: 4,601
A question: since the Tubliss system seals the tire to the rim, are rimlocks still needed?
03-19-2010, 11:16 AM
#22 | |
Candyass Camper
Oddometer: 3,333
Look...I think we're really looking at a belt-and-suspenders kind of panacea here, and with rubber tires that have air in them, it's an impossibility. On the other hand, this Nuetech system is pretty darned easy for the apparent benefit and reliability. The complaints and gnashing of teeth are almost always connected with the installation process. I think installation is relatively simple and straight forward, but many, many folks have trouble even changing a normal tubed setup tire. I'm not saying this to demean anyone...just pointing out why installation causes heartburn for many. |
03-19-2010, 01:40 PM
#23 | |
Geek Adventurer
Oddometer: 4,601
I am probably going to try the Tubliss system on the rear pretty soon as I will need a new tire in the near future and that is as good a time to install it as any. Now I am just wondering if I can run a Dunlop 803 Trials tire on the pavement for the 15 miles I have to ride my bike to get to the trails.
03-19-2010, 03:23 PM
#24 |
Geek Adventurer
Oddometer: 4,601
BTW - came across this image elsewhere. Thought it might help those trying to visualize how the tube is in relation to the protection of the tube.
03-19-2010, 04:35 PM
#25 |
Guns are for pussies
Oddometer: 13,783
You guys are funny... here, watch the video and 99% of your questions will be answered
![]() I'm going to run the TUBlis system on my SE this year for the Paris to Dacre, so I'll give you guys a report of how it did. I've been running Tennis balls in the front with great results, so I'm looking forward to seeing how it works.
Just say'IN crankshaft screwed with this post 03-19-2010 at 06:26 PM |
03-19-2010, 04:39 PM
#26 | |
Oddometer: 837
03-19-2010, 06:15 PM
#27 |
Butler Maps
Oddometer: 14,431
tubliss seems great for lighter dirtbikes.
doesn't it only inflate the tire to 10-12psi? that would quickly kill a dual sport tire with any sort of hiway/paved time, no? what about dual sport loaded down w/ gear?
Butler Maps - motorcycle maps for riders by riders - Ozarks , Nor Cal , COBDR shipping, AZBDR scouting http://www.advrider.com/forums/showthread.php?t=598717 Facebook: http://www.facebook.com/butlermaps |
03-19-2010, 06:24 PM
#28 | |
Oddometer: 13,783
Mounted on the old SE and run up to 100 MPH and many miles of nasty trails. Not DOT also.
Just say'IN |
03-19-2010, 06:28 PM
#29 |
Oddometer: 954
With 110 psi in the tubliss tube and 12 psi in the tire, I've run 60 mph for two hours on pavement with no problems. The tire runs quite a bit cooler without a conventional tube in it. I live in a "third world" country and only carry a tire plug kit now. Plan to buy a suitable pump in the states in April when I visit there and also pick up a pair of replacement tubliss tubes.
My tires have stiff sidewalls, Maxxis IT Desert front and rear. I think even if they were to go flat, I could still ride on provided the tubliss tube still had pressure. I can't imagine how the tubliss tube could be punctured unless it was incorrectly installed to begin with.
03-19-2010, 06:42 PM
#30 | |
Oddometer: 837
