01-10-2013, 01:00 AM
#391 |
Oddometer: 1,690
One or the other...
Running sealant is not such a flash idea if a tyre ever needs to be repaired.
Cheers, Numbers 05 R1200GS, 11 TE630, 11 DR-Z462, 09 990AR, 12 R1200RT, 12 VFR800 Founding member Longtails SC |
01-10-2013, 07:48 AM
#392 | |
Rides a dirty bike
Oddometer: 1,416
Two roads diverged in a wood, and / I took the one less traveled by, / And now where the hell am I? 'Being an adult is so much better when you forget that you're supposed to be boring' (D.Corsetto, 9/7/12) |
01-10-2013, 08:25 AM
#393 |
Candyass Camper
Oddometer: 3,327
If using Slime I would agree. However, something like Stan's sealant is relatively clean and at least equal to or better than Slime. I've used both in my Tubliss setup. Cleanup when changing to a new tire was messy with the Slime and not with the Stan's. If I didn't use sealant, I've had numerous situations where I would have had a flat without it...a nail, wire, mesquite thorns, etc. In the case of the nail incident, I plugged the hole when I pulled out the nail, but amazingly the sealant seemed to seal the hole. I went ahead and plugged the spot with a common string plug just to insure the fix. I ran that tire until it was toast.
01-10-2013, 10:42 AM
#394 |
Rides a dirty bike
Oddometer: 1,416
I actually use a homebrew sealant composed of latex mold builder, Slime, antifreeze and water. Similar to, but better than Stan's NoTubes sealant. I had a nail puncture a while back - the sealant held air pressure after pulling the nail, but I kept having a persistent wet spot there. Put a string in it, and it's all dry.
01-10-2013, 11:15 AM
#395 | |
Oddometer: 416
http://www.ride-on.com/motorcycle-formula-mot.html |
01-10-2013, 03:25 PM
#396 |
Oddometer: 1,690
Did I mention Slime? Maybe someone would like to quote the relevant text and highlight that word.
Any sealant worth the name should be able to seal a nail hole.. .It is the bigger holes that require patching or a tube that become a problem.
01-10-2013, 03:57 PM
#397 | |
Conquistador
Oddometer: 109
The advantages are vastly reduced chance of pinch flats and sealant can be used to fix against nail/wire/thorns if you wish to use it. Another advantage of sealant would be dynamic balancing of your wheel meaning no more mega weights to offset the rim lock I'm struggling to find a downside vs a tube set up here.
i contacted the spirit world but they don't know what's wrong with my 690 either |
01-13-2013, 09:42 AM
#398 |
we build, we fight
Oddometer: 1,729
you can run a sealant if you want to with the tubliss system, but really, all you need is a plug kit and a mini compressor.
another advantage of the tubliss is running crazy low pressures for great traction. just watch out for dinging your rims.
calling an illegal alien an "undocumented immigrant" is like calling a drug dealer an "unlicensed pharmacist" "If guns cause crime, then all of mine are defective." Ted Nugent |
01-13-2013, 11:46 AM
#399 | |
Candyass Camper
Oddometer: 3,327
01-13-2013, 12:07 PM
#400 | |
we build, we fight
Oddometer: 1,729
![]() once you start changing your own tires, you'll appreciate not having sealant in there. water clean up or no, it's still a mess. ymmv
01-13-2013, 12:51 PM
#401 | |
Candyass Camper
Oddometer: 3,327
But seriously, I mentioned Stan's because the stuff really works, and you don't get the goshawful mess that you do with something like Slime. I've been using it in my dirtbike tires for about 3.5 years now and way longer in mountainbike tires. For something that really seals a hole, it is amazingly clean stuff. I agree that because of the way the inner liner seals the tire bead, a plug fix works wonders on the trail because you don't have to worry about a quick, high volume air supply to seat the bead. Still, when I've changed the many tires over that 3.5 year period on my dirt bike, I've almost always found things stuck in the tire that probably would have yielded a needed fix in the field. It's nice to keep on riding. |
