Old 03-20-2010, 07:00 AM   #1
SingleTrackMind OP
Oddometer: 90
Adjustable kickstand qwerstion
Aurel and others, what diameter bolt do I need to make this?
I cut my kickstand last night and welded a new pad to make it shorter, but I see now that adjustable is a better option. I should've measured while I had it cut but I didn't.
WANTED - 2008-09 R1200GS Adventure - PM me
2008 KTM 990 Adventure
- SOLD
SingleTrackMind is offline   Reply With Quote
Old 03-20-2010, 07:16 AM   #2
Peanuts
Peanuts's Avatar
Oddometer: 1,642
Look at the piece you cut off ;)
Peanuts is offline   Reply With Quote
Old 03-20-2010, 07:22 AM   #3
SingleTrackMind OP
Oddometer: 90
D'oh!
Man, looks like I picked the wrong week to quit sniffing glue. You would think a brilliant engineer like myself would've picked up on that right away.
- SOLD
Old 03-20-2010, 08:07 AM   #4
Dan Alexander
Ride Far - Ride Fast
Dan Alexander's Avatar
Oddometer: 7,531
Beemers Past and Present: 74 R90S, 77 R100RS, 85 K100RS, 2x 87 K100RS, 96 R1100GS (getting hacked), 99 R1100S, 2002 R1150GS, 2005 F650 Dakar, 81 GL500/Velorex
Plus the occasional Triumph, BSA, Yamaha, Honda, Suzuki and KTM but who's counting
Dan Alexander is offline   Reply With Quote
Old 03-20-2010, 08:28 AM   #5
dad2bike
Cranky Old Fart
dad2bike's Avatar
Oddometer: 4,059
For the benefit of us lazy FF's out here. Me included.
How about posting up what you measure?
It would be nice to go get all the parts and do the job in a single pass.
I was gonna get a second sidestand to mod... What the Hell. I'll do this one. One less thing to swap when I change between knobbies & street tires.
Tom
2006 950 Adventure "Big Orange", 2009 690R "Ginger",2003 525 EXC,
To Think is to Create!
My2Wheels
690 WIKI
dad2bike is online now   Reply With Quote
Old 03-20-2010, 11:20 AM   #6
SingleTrackMind OP
Oddometer: 90
Well, here ya go you lazy FF.
The correct answer is 3/4" bolt. My welding skills leave much to be desired, but adequate to stick two pieces of metal together. The foot pad is just a 3/4" washer. I'll test drive it a bit before painting to make sure it's good to go.
- SOLD
Old 03-20-2010, 02:02 PM   #7
dad2bike
Cranky Old Fart
dad2bike's Avatar
Oddometer: 4,059
Your welding no worse than mine. Functional at best for me.
That's what they make grinders for. I'll be using a much bigger washer for the foot. Something about equal to the diameter of the TT plate.
Tom
My2Wheels
690 WIKI
dad2bike screwed with this post 03-20-2010 at 02:20 PM
Old 03-21-2010, 08:07 AM   #8
mookymoo
Mookish Mook
Oddometer: 4,394
Be aware that if you make the end of the kickstand too heavy, its going to flop down every time you hit a decent bump.
I tried Aurels bike and it didnt take much force at all to push the kickstand down against the spring. He was having a bit of trouble with it at the time - not sure what hes done to fix it.
Ultimately, a big-ass bolt & 2 heavy nuts probably weighs as much as the kickstand itself (its pretty light for what it does). If you keep the threaded section short though, you should be ok.
mookymoo is offline   Reply With Quote
Old 03-21-2010, 08:55 AM   #9
AdvGa
AdvGa's Avatar
Oddometer: 1,320
Here is how I did the same thing a little differently:
The Red Arrows is the Section that was cut out.
Then pressed 2 Nuts inside each tube that was JB welded inside tubes and then over the nuts for added security. Than cut the Bolt to size, about 4 inches (with 1 1/2" Bolt Stock going up into the Tube for added support) .
I did drill a hole on the bottom mount through the nut area and installed a Drift Pin or Cotter pin to prevent it from turning or spinnin off via vibration.
It works great, does not flop around and gives a better lean angle.
Hope this may help.
AdvGa screwed with this post 03-22-2010 at 08:30 PM
AdvGa is offline   Reply With Quote
Old 03-21-2010, 09:03 AM   #10
dad2bike
Cranky Old Fart
dad2bike's Avatar
Oddometer: 4,059
What size bolt did you use? Looks like 7/16" or so.
I wonder what the inside diameter is of the tubing? If the wall thickness is enough it could be tapped to eliminate one nut and welding too.
Tom
My2Wheels
690 WIKI
Old 03-21-2010, 09:08 AM   #11
AdvGa
AdvGa's Avatar
Oddometer: 1,320
Dad,
I think you are correct. It FIRMLY fits inside the ID and this process does not need a welder. There is not enough material to even think about tapping.
Hardest part of this process was getting the Kickstand On and Off!
Old 03-21-2010, 10:48 AM   #12
DirtNap
Oddometer: 194
Subscribed for any updates.
Thanks.
Dale, NE9V
"when the going gets tough, just downshift"
2006 Goldwing | 2007 BMW F650
DirtNap is offline   Reply With Quote
Old 03-21-2010, 12:05 PM   #13
Brown Dog
North Georgia Dual Sportr
Brown Dog's Avatar
Oddometer: 1,947
Originally Posted by dad2bike
What size bolt did you use? Looks like 7/16" or so....
He said 3/4". I bet he means a 3/4" wrench fits it, which would be a
1/2" thread size. I would prefer the FINE Thread in original post #1 over coarse. just sayin
Brown Dog is offline   Reply With Quote
Old 03-21-2010, 12:27 PM   #14
SingleTrackMind OP
Oddometer: 90
Brown Dog, I used a 3/4" bolt which takes a 1 1/8 to drive it. I think Dad is referring to AdvGa's version which uses a smaller bolt and a recessed nut.
I thought real hard about some sort of press fit bushing that could be tapped internally but couldn't find such at Lowes. I do like that cleaner install like AdvGa's , but I fear that going too small on the bolt will increase chances of bending. His looks like a common carriage bolt which is very low grade stuff...I'd definitely consider getting a Grade 8 bolt in there.
You're right mookymoo, that is a lot of weight out there at the end. I'll keep an eye on it for now with intentions to do a lighter weight version later. I do like the cleaner look of AdvGa's...maybe that will be my next iteration after I see how mine fairs.
- SOLD
Old 03-21-2010, 12:38 PM   #15
Brown Dog
Brown Dog's Avatar
Oddometer: 1,947
Brown Dog, I used a 3/4" bolt which takes a 1 1/8 to drive it... His looks like a common carriage bolt which is very low grade stuff...I'd definitely consider getting a Grade 8 bolt in there.
The 3/4" would be mucho better. Your right on the carriage bolts as they are
grade 2 like threaded rod = NO good / Very Weak.
Brown Dog screwed with this post 03-21-2010 at 05:09 PM
Times are GMT -7.   It's 09:55 AM.
