Old 04-05-2010, 11:40 PM   #46
pfb
Riding, not skiing.
pfb's Avatar
Oddometer: 5,501
Originally Posted by ganshert
Yeah your probably right. I ran 12 gauge with a relay and 30A fuse by the battery and an additional 14 gauge wire directly from the battery so I have switched and battery power at the fuse box. I can always nix the fuse box but it sure makes it easy to distribute the power and use a different rated fuse for each device. The GPS is pretty expensive and I wanted to run a 2A fuse for it.
I'll put a horn on it at some point and the existing stock switch provides a ground so all I have to do is run 12V to the other side of the horn and I'm done.
I'm also going to mount a tri color LED that monitors voltage so that will wire right in to the fuse box.
I like my wiring to be tidy so I figured 4 things powered up there off of two wires w/o a distribution panel of some sort would get messy.
I think of fuses more as protection from burning the wiring harness to the ground rather than protecting individual devices... Pretty much the only thing that is going to blow them is chaffing/cutting/accidentally grounding a hot wire (somewhat likely...) or overloading a circuit (not bloody likely with nav gear).
For distribution, first I run to a master Nav switch, then tie in all the feeds to soldered/shrink wrapped/sheathed connections. I like things neat, but also like them simple and am wiling to trade off a bit of cosmetic beauty for simplicity and robustness.... And while I know they do it all the time on race bikes, having many crimped connectors, screw terminals, and lots fuses makes much less sense to me on a rallye bike with dust/dirt/vibration/water, especially with something that is moving back and forth with every turn of the handlebars.
Course it's only my opinion, and I've redone my nav gear mounting and wiring four times already as I am never completely happy with what I set up. Maybe we'll get a chance to admire each others handywork this weekend
950 Adventure 950 Super Enduro 450 XC-W Six Days
pfb is offline   Reply With Quote
Old 04-06-2010, 07:00 AM   #47
tahoeacr
tahoeacr's Avatar
Oddometer: 2,210
Don't need to. Looks like a 2010 you have. Horn wires are already there on the right side of the frame up by the radiator. Plug in a horn and your good. I got to figure where to put the mount.
tahoeacr is offline   Reply With Quote
Old 04-13-2010, 03:05 AM   #48
ChR1s
Spherical Bastard
ChR1s's Avatar
Oddometer: 336
Thumb
To the OP: Thanks for posting up the details of your FE build-up. It's been quite helpful!
Finally got my 390 out for a ride yesterday. I like it. A LOT. Seems to be perfect for the boney New England woods.
Chris
ChR1s is offline   Reply With Quote
Old 04-15-2010, 08:19 PM   #49
ganshert OP
not sleeping
ganshert's Avatar
Oddometer: 8,039
So I finally got out for some real riding.
14.5 hours and 365 miles later, looped it once and got it good and stuck in a mud hole. I think I've got it broken in
The 3 days of riding was mixed single / double track, jeep road, gravel, highway, and even a couple of miles of interstate.
It performed flawlessly. That thing is a tractor or a rocket ship depending on gear and throttle position. Me likey
Seems a little rear heavy. Makes for some interesting sand riding. I've always had to get way back and lighten the front to go fast in sand. Not on this bike. I wanted to get some hours on it before I picked up a damper. I think I'll get one but I want to move the bars back directly above the stem first. Right now I have them in position 3, clamps towards rear but in front hole. More to come on that...
Still seems geared low with the 14 on front and 52 on back. Stock is 13/52. I think I'll get a 48 for the back and see what that feels like. I'll keep the 52 around for tight technical single track.
I got it good and hot a couple of times and spit up some coolant. I picked up a fan and will be posting pics of that install some time this coming week. Might even try to figure out a coolant overflow catch can but haven't a clue where I'll mount it.
Fuel seems to get really hot. Not quit boiling yet but hot enough to overwhelm the vent and build serious pressure. At one point it was trying to spit the inline vent out of the tubing and I could hear it hissing. This was after some particularly tight single track with the sun beating down and no wind.
I changed the oil before this ride at 1.2 hours and it was debris free and clean. I'll do a valve check and oil change this coming week and report back.
I got 40 mpg on easier terrain, the fuel light came on at 71 and it was still running at 82 and took slightly over 2 gallons. I got about 36 over a 120 mile day of harder stuff.
Overall I couldn't be happier. The FI is spectacular, the bike feels as light as my old 03 250EXC, and the suspension is spot on. I'm 229 w/o gear and am running .50s in front and a 8.5-11 progressive in back. I get 105 race and 30 static with that setup. Might have to go lighter on both ends as I approach my 200lb goal.
At the beginning of the day
After 120 miles of challenging terrain... and some mud.
more to come...
ganshert is offline   Reply With Quote
Old 04-23-2010, 01:05 PM   #50
Blakebird
r-u-n-n-o-f-t
Blakebird's Avatar
Oddometer: 16,297
what's a thread of awesomeness doing on page 8?
IBA #11735 . 1968-present
Blakebird is offline   Reply With Quote
Old 04-23-2010, 01:33 PM   #51
Hayduke
///SAFETY THIRD///
Hayduke's Avatar
Oddometer: 43,975
It's not orange enough.
"What these people need is some mental psychology."-Bonnie Abbzug
Hayduke is offline   Reply With Quote
Old 04-23-2010, 03:16 PM   #52
Hair
Outside the boxer
Oddometer: 14,038
If we pick a fight in here, it will be the most awesome thread in the basement.
Hair is offline   Reply With Quote
Old 04-23-2010, 04:00 PM   #53
ganshert OP
not sleeping
ganshert's Avatar
Oddometer: 8,039
Page 8 is apparently the most awesome page then
Old 04-23-2010, 04:00 PM   #54
ganshert OP
not sleeping
ganshert's Avatar
Oddometer: 8,039
I was going to give you all my spare orange parts
Old 04-23-2010, 05:09 PM   #55
CodeMonkee
Geek Adventurer
CodeMonkee's Avatar
Oddometer: 5,598
Blue and yellow is the new orange.
'09 Husaberg FE570
'99 Beta Alp
'04 Ducati MTS - sold
Not all who wander are lost
CodeMonkee is offline   Reply With Quote
Old 04-23-2010, 05:11 PM   #56
Hayduke
///SAFETY THIRD///
Hayduke's Avatar
Oddometer: 43,975
Yay!!!1!!
Hayduke screwed with this post 04-24-2010 at 01:35 PM
Old 10-18-2010, 11:18 AM   #57
Stobie
Mr. Motivated
Stobie's Avatar
Oddometer: 1,865
Bump.
Stobie
Problems cannot be solved at the same level of awareness that created them.
-Albert Einstein
Stobie is offline   Reply With Quote
Old 10-18-2010, 12:13 PM   #58
ganshert OP
not sleeping
ganshert's Avatar
Oddometer: 8,039
Originally Posted by Stobie
Bump.
I've been riding the piss out of it.
P.S. I'm taking it supermoto racing this spring
Old 10-18-2010, 12:32 PM   #59
Fubars
What would Scoobydo?
Fubars's Avatar
Oddometer: 1,776
Rode a demo FX450 this weekend. Loved it. I'm now fantasizing over a 570s.
Fubars is offline   Reply With Quote
Old 10-18-2010, 01:00 PM   #60
Hayduke
///SAFETY THIRD///
Hayduke's Avatar
Oddometer: 43,975
Way to make Ned pick up your bike.
Times are GMT -7.   It's 11:13 PM.
