Old 03-21-2010, 06:16 PM   #1
jasonTDI OP
TDI Guru
Oddometer: 187
Power connection for LED lights F800
Where are you guys hooking into for power and for the leed wire?
New to the canbus stuff....I haven't seen posts on it and the instructions are lacking.
09' F800GS.
Got the LED TrailTech Denali lights.
jasonTDI is offline   Reply With Quote
Old 03-21-2010, 10:00 PM   #2
gpracer171
Kodak Courage
gpracer171's Avatar
Oddometer: 361
Try this.
Several options. Read through this (searched "switched power") and it should work for you. If you want always on, use the battery, if you want switched, then I would use the GPS plug or as a fuse block. all are discussed here.
http://www.advrider.com/forums/showt...switched+power
Mike
2010 BWM F800GS
2007 Triumph Dayton 675
2013 Husqvarna Nuda
If you are not moving forward, you are falling behind...
gpracer171 is offline   Reply With Quote
Old 03-22-2010, 07:58 AM   #3
jasonTDI OP
TDI Guru
Oddometer: 187
Thanks Mike.
Missed that in the search.
Times are GMT -7.   It's 09:46 PM.
