Old 03-21-2010, 10:49 PM   #1
syaufu OP
Oddometer: 131
Question F650GS throttle problem
I have about an 1/2 inch "play" in my throttle on my new 650 GS...It is quite irritating and somewhat dangerous..I put a new pair of Barkbuster guards on it but I am not sure if it was there before that or if it is a result of it..Any ideas as to how to take the "play" out of the grip ?? bj
syaufu is online now   Reply With Quote
Old 03-22-2010, 09:37 AM   #2
Bartron
Bike Punisher
Bartron's Avatar
Oddometer: 693
By 'play' do you mean the entire throttle assembly rotates or do you have no throttle response within the first half-inch of opening the throttle?
If it's the latter, you may need to tighten up the slack in your throttle cable to fix your woes. Just be sure to check that you don't get inadvertent revving while moving the handlebars lock-to-lock.
Ride on.
:: Furious Basterds: Velox, Vehemens, Oblivio
:: "For those who don't understand, no explanation is possible. For those who do, none is necessary."
Bartron is offline   Reply With Quote
Old 03-22-2010, 10:20 PM   #3
syaufu OP
Oddometer: 131
throttle
The grip turns about 1/4 to 1/2 inch.. before anything happens ..I don't think it is the cable..it is like the handle is loose..bj
Old 03-22-2010, 11:44 PM   #4
itsforrest
Ugly bag of mostly water
itsforrest's Avatar
Oddometer: 330
Sounds like the cable has some slack in it. The adjuster is right under the switch pod. It has a little knurled nut on so you don't even need any tools. Tighten it up a little bit at a time and make sure there's a little bit of play still when you turn the bars all the way left and right.
The urge to buy terrorizes.
itsforrest is offline   Reply With Quote
Old 03-23-2010, 08:05 PM   #5
syaufu OP
Oddometer: 131
throttle
That fixed it ..Thanks for the info..bj
Times are GMT -7.   It's 11:53 PM.
