Old 03-16-2013, 11:21 PM   #181
Low594 OP
Adventuring Creep
Low594's Avatar
Oddometer: 1,160
Low594 is offline   Reply With Quote
Old 04-03-2013, 01:15 PM   #182
Low594 OP
Adventuring Creep
Low594's Avatar
Oddometer: 1,160
Death Valley Ride Report!
Old 04-03-2013, 08:12 PM   #183
bmwktmbill
Traveler
Oddometer: 5,218
Perfect.
b
'02 KTM 640 Adventure-lowered
Cormack McCarthy-The Crossing
Bill Shockley
bmwktmbill is offline   Reply With Quote
Old 11-13-2014, 09:34 AM   #184
MSH
The Salt
MSH's Avatar
Oddometer: 3,245
Originally Posted by Low594 View Post
I've long neglected updating my progress, so here goes!
Mirrors & handguards of newer KTM
ADVMonster M60(3600lumen) LED Flood, ADVMonster 10w(450lumen) LED Spot
Hella Supertone horns, Computer fan grill headlight protectors, Lockhart/Phillips billet clear turn signals
KTM fender (part #5030801030030), Seal Savers (All Balls seals and wipers inside)
Almost new condition seat, side panels and rear fender painted satin black(orange was worn out and looking bad!) footpegs widened by DJ Cycles, MotoSport hardbox pannier racks, ProMotoBillet tail shelf, SXC muffler (FMF repack and allen screw conversion), Touratech skidplate, SW-Motech sidestand w/extension, custom Orange Crush shock res cover
Acerbis LED tailight (part #210470001), Lockhart/Phillips billet clear turn signals
Left to Right: toggle for ADVMonster M60 flood LED, Magellan Triton400 (hiking/offroad GPSr), Ipod Nano, Magellan Maestro (road nav GPSr)
Found to the left of the Scotts Dampner: volume control for Ipod
Parts not seen:
-SXC enclosed chainguide
-RLR Coolant Recovery Tank
-pre-muffler delete S-pipe
-KTM airbox side cover
-KTM updated radiator cap
-3BR Powersports USB powerport
-Stenhouse fuel mixture screw
-oversized Tool Tube (holds tools and stove fuel!)
-ASI silicone radiator hose (found on Ebay; despite coming from China they were very responsive!)
Soon to be done:
-620Rallye rear disc guard
-Trailtech Vapor Stealth
-Stenhouse Sub-Dampner mount
-2009 exc throttle tube/housing/cables
-950 right control pod
-swap M60 light into Hi Beam location
-upgrade Low Beam to Bi-Zenon Projector
-rear LED strips to add running ckt, sequential turn signal & brake strobe
-Passmore's centerstand EZ-Up mod
-Emig Racing 1-1/8" lowering links
Nice! Thats inspiring. And here I am fretting over just buying a bike that has had nothing done... Needing everything done. Good work.
~KTM 640 Adventure R~
"Lately it occurs to me what a long, strange trip it's been"
MSH is offline   Reply With Quote
Old 11-18-2014, 07:37 AM   #185
overlandr
Dystopist
Oddometer: 5,926
Any idea of the part number of the fuel tank?
overlandr is offline   Reply With Quote
Old 11-18-2014, 12:18 PM   #186
Low594 OP
Adventuring Creep
Low594's Avatar
Oddometer: 1,160
Not a clue! But it is the original, which I believe only came in blue on '99 &'00. Google "KTM parts microfiche", the numbers are available... but good luck finding one in stock! If I am right, the '02 & newer had a flip filler and the capacity was more like a measily 7gallons, vs the earlier tank at 7.4g!
Old 03-26-2015, 12:31 PM   #187
MSH
The Salt
MSH's Avatar
Oddometer: 3,245
Old 03-26-2015, 05:50 PM   #188
Ben99r1
Ben99r1's Avatar
Oddometer: 3,090
Nice bike. The early years have always been my favorite of the 640 bikes.
Ben99r1 is offline   Reply With Quote
Old 04-02-2015, 11:15 AM   #189
NevBlu
Oddometer: 182
Originally Posted by Tseta View Post
Middle connector is for neutral wire, the other two are for 2nd and 3rd gear. The signals from those are used in a EPC (electrical power control) module, something to do with emissions or drive-by noise or such. This EPC is not fitted to all bikes (depending on market) and most people remove it anyway, as it diminishes rapid throttle response in 2nd and 3rd gear. Creeper has written a little bit more about EPC. here.
Tseta
From my 2001 LC4 640 E, here is the middle sensor apparently for the neutral position. The threads are 21 mm long with 23 mm including the moveable tip. On my model there is NO throttle position sensor (TPS).
2003 BMW R1150 RTP, 2001 KTM LC4 640, 1991 ATK 605, 1968 BSA B50SS
Ride with Wings of Passion
NevBlu is offline   Reply With Quote
Old 04-02-2015, 10:45 PM   #190
Low594 OP
Adventuring Creep
Low594's Avatar
Oddometer: 1,160
Mine too!
Times are GMT -7.   It's 11:38 AM.
