View Results: What should Tlub do with his R50?
Nothing 21 0.01%
Pimp it out and chrome the crap out of everything 4 0.00%
Repaint it to look like everybody elses' bike 314,159 99.99%
Voters: 314184. You may not vote on this poll
Old 07-17-2014, 08:39 AM   #1711
danedg OP
Horizontally Opposed
Oddometer: 6,686
Sparkplugs
While we are on the subject of sparkplugs.....
I've had bad luck with the NGK B8ES (B8HS) plugs that I've been using from day one of this saga. The last batch of 8 that I got have resulted in 4 of them bad out of the box or shortly thereafter. 2 would not 0 out for continuity and the others left me stranded with fouled plugs. I think I've got a couple of them in there now that seem to firing correctly.
A 50% failure rate is not a real confidence builder....
I'm using the NGK's because I can't find Bosch plugs in my neck of the woods. Even on the net they are as scarce as hen's teeth. The factory specs Bosch W240T1 (or 2) for the HK or LK heads. Those are NLA as far as I can determine, and have been superceded by W4AC and W4CC. I haven't been able to find those either through the normal channels as no one uses them in modern vehicles. I was just about to give up when I have finally found a source for the Bosch plugs.
It seems that the plugs are now used regularly in modern chainsaws.
I just received a batch of plugs from forestershop.com, a forestry supply company in Wilkes-Barre, PA. http://www.forestershop.com/
The W4AC plugs are made in Germany, the W4CC plugs are made in India?
Im looking forward to seeing if the quality is better than the NGK
54' R51/3, 65' R60/2, 68' R60US, 74' Moto Guzzi Eldorado, 95' Mystic
danedg is offline   Reply With Quote
Old 07-17-2014, 06:17 PM   #1712
David4
Oddometer: 223
Originally Posted by crazydrummerdude View Post
Anyone have experience with it? Pretty tempting.
This battery is now back ordered until the end of August 2014. I'm going ahead with my purchase.
1966 Triumph TR6R Trophy
1967 Triumph T120R Bonneville
1968 BMW R60/US
1969 Triumph T100R Daytona
David4 is offline   Reply With Quote
Old 07-17-2014, 07:04 PM   #1713
danedg OP
Oddometer: 6,686
This is what I've been using
From Batteries Plus . $37 It's a sealed battery,no leaks. 14AH
What you want is the T1 model. It's got the right connector with the fuse inline.
RAYA6-14T2 Rayovac 6V 14Ah Battery with H Terminal Batteries and Chargers Power Wheels Toy or Riding Car
Batteries and Chargers Power Wheels Toy or Riding Car Rayovac 6V 14Ah Battery with H Terminal RAYA6-14T2 . Powerwheel H-type terminal. Rayovac AGM batteries are quality tested and inspected to insure the highest standards in performance. To keep you running throughout the day you can trust Rayovac batteries.
Item number: RAYA6-14T2
Weight: 6.2400 lbs
Voltage: 6V
Capacity: 14AH
Old 07-18-2014, 10:47 AM   #1714
jcf
Oddometer: 249
Pissed
Wow - that is just shocking (sorry) to hear.
I have had starting issues that I could not figure out - all new ignition parts/battery - even a few sets of those same plugs
jcf is offline   Reply With Quote
Old 07-18-2014, 01:16 PM   #1715
danedg OP
Oddometer: 6,686
Starting issues will not involve the battery.
The magneto will spin, send voltage to the coil, and the points will fire the plugs.
Hard starting will be a coil problem or a plug problem.
Pull the plugs and set them on the cylinders attached to the wires.
Kick the motor over and you should see a big fat blue spark...
If not, start chasing it back from the plugs. Then the caps, then the wires, then the coil.
Old 07-18-2014, 03:19 PM   #1716
bpeckm
Grin!
bpeckm's Avatar
Oddometer: 5,842
...and the points, which is how the timing is set.....
XS650 becomes a VT BackRoadRunner
Loving the 80ST
I love projects that take twice as much effort as should be needed. Should be an Airhead motto. (disston)
bpeckm is offline   Reply With Quote
Old 07-19-2014, 02:10 AM   #1717
RagerToo
vroom vroom
Oddometer: 303
I haven't followed this entire saga, but I have worked with a magneto fired engine or two.
I traced back a hard starter to a mis-"adjusted" mag spring. Someone somewhere had allowed the magneto to lose a wrap of spring tension. This was an old cast iron industrial engine. They had been using a generator/ starter motor and a belt to crank the holy hell out of the engine. After adjusting the mag spring, the mag released fast enough to fire the engine with one or two pulls of the starter cord.
I hope this makes some sense.
'80 R100RS but nekkid
Some folks still insist on going to a gun fight with a popsicle stick sharpened on the driveway.
RagerToo is offline   Reply With Quote
Old 07-19-2014, 08:19 AM   #1718
Pokie
Just plain Pokie.
Pokie's Avatar
Oddometer: 1,017
What's the bike with starting issues? Always start the timing drill with aligning the flux marks. If the marks are off (yes, they do drift), it may well affect starting. Once the flux is aligned, then proceed with checking the points and setting the timing (never adjust the timing by moving the mag body, that will affect the flux). If starting gets more and more difficult, to the point of requiring bump starting, the likely cause is the coil.
Work your way in, start with the spark plugs (or as the English say "sparking plugs"),....... Plugs, plug caps, H/T leads (plug wires), check the spark gap at the mag (should be 10mm if I'm remembering right), check the flux alignment, clean and lube the advance mechanism (check for sticking), check and lube the points and condenser (don't forget to check the insulating bushing and washers for the points wire), adjust the point gap, check and adjust the timing (on manual retard bikes, check and adjust the retard stop). If the phenolic block is worn, you will be able to set the point gap but will not likely be able to adjust the timing, replace the points.
If starting problems continue, check the carbs for water or dirt or poor adjustment. If hard starting continues, even when warm, I would suspect the coil.
Pokie is offline   Reply With Quote
Old 07-31-2014, 03:59 PM   #1719
David4
Oddometer: 223
I know you've all been asking yourselves....
What kind of oils does Dan run?
so I'll tell you...and why...and we'll never have to have another oil discussion... ever.. until next week.
In the tranny, driveshaft and rear end....
Sta lube GL-4... more zinc for the brassy things...available at most NAPA stores....
In the motor:
Shell 40W NON DETERGENT motor oil... why ND?
Detergent motor oil suspends all the dirt in the oil in anticipation of puttin' it through the oil filter......
I'd rather drain the shit every 1000 miles out of the pan.... than have THAT MUCH MORE get slung.....
LucasOIL zinc additive.... again, all the brassy parts are starving for the zinc that's been deleted form modern fluids due to EPA regs....
I put a dwollop in the tranny, the rear drive, driveshaft area, AND the crankcase... the tappets and crankshaft really like it.
Dan, I've bought these oils, please define the amount of Lucas oil described as a
"dwollop". ???? Dave
1968 BMW R60/US
Old 08-01-2014, 08:04 AM   #1720
bpeckm
Grin!
bpeckm's Avatar
Oddometer: 5,842
Pretty sure that it's a metric term... you know: either ten times or one-tenth of a regular dollop. Dan will know.
Loving the 80ST
Old 08-01-2014, 12:56 PM   #1721
danedg OP
Oddometer: 6,686
It's a bit more than a spooge..a lot more than a squirt....
Old 08-01-2014, 01:30 PM   #1722
David4
Oddometer: 223
I see there's an art to oil chemistry!
1968 BMW R60/US
Old 08-01-2014, 02:10 PM   #1723
danedg OP
Oddometer: 6,686
The zinc is primarily added to the engine oil. It helps "cushion" the flat tappet against the flat cam. The pressures exerted there are enormous, and need all the help they can get. It's been said that oil with no(lo) zinc is like no oil at all. It protects sliding surfaces from each other. And that includes piston rings,wrist pins,valve guides,bronze bushings,bearing surfaces, helical cut gears,.etc., etc.....
No one can tell you the % of this and that in their product, or how much of that and this is needed for your machine.
I put a big ol' SQUIIIIIIRRRRRTTT!.. of the shit in whenever I change oils.
danedg screwed with this post 08-01-2014 at 04:37 PM
Old 08-02-2014, 04:52 AM   #1724
David4
Oddometer: 223
Got it..thanks. dave
1968 BMW R60/US
Old 08-02-2014, 05:07 AM   #1725
Chobro
spinning the wheel
Chobro's Avatar
Oddometer: 795
Picking up a 68r50us. Drove to my folks house in NJ where the bike has been since the '90s, last ridden at the Vt. MOA national in '06. Not sure if this pic will work , but here goes.
-Chobro
Chobro is offline   Reply With Quote
Times are GMT -7.   It's 03:03 AM.
