View Results: What should Tlub do with his R50?
Nothing 21 0.01%
Pimp it out and chrome the crap out of everything 4 0.00%
Repaint it to look like everybody elses' bike 314,159 99.99%
Voters: 314184. You may not vote on this poll
Old 12-28-2010, 03:41 PM   #196
danedg OP
Horizontally Opposed
Oddometer: 6,773
Actually, if you've seen one...you've seen 'em all. That's what the guy at Bing told me today. One basic gasket kit fits all "levertops"....
I bought the kit...it's under $20
...the issue here is that these 2 pieces were originally one.... you can see the "pinched" portion of the spring loaded lever...your "tickler"...
Your float contains the needle that rides in the central brass piece. Properly positioned, the float ascends and descends allowing the correct level of fuel into the "bowl"... the needle cuts off and allows fuel to pass through the 3 ports in the top. By depressing the "lever top", you simply depress the float and needle, allowing more gas into the bowl. This may or may not assist you in starting the bike. The popular concept of "tickling", only hastens the demise of the "lever' assembly. One only has to depress the lever for a longer time to achieve the desired result!
54' R51/3, 65' R60/2, 68' R60US, 74' Moto Guzzi Eldorado, 95' Mystic, '78 Honda Hawk...... the Axles of Evil!
danedg screwed with this post 12-28-2010 at 04:01 PM
danedg is offline   Reply With Quote
Old 12-28-2010, 04:18 PM   #197
uraldog
vagabond
uraldog's Avatar
Oddometer: 405
Any flashes of brilliance out there?
find a small brass block [ a brass nut would work ] drill a hole in one flat side and tap it out for an allen socket set screw -- it would be shallower than that zip tie and last longer or check your local mower shop amd ask to see a cable loc and drill it out to fit the shaft
uraldog is offline   Reply With Quote
Old 12-29-2010, 04:08 PM   #198
danedg OP
Oddometer: 6,773
5/32" retainer nut
Old 12-29-2010, 04:30 PM   #199
danedg OP
Oddometer: 6,773
Zircon's R69S '68
Old 12-29-2010, 09:24 PM   #200
vernon dent
vernon dent's Avatar
Oddometer: 713
thinking about this one. 20,000 miles starts and runs. is it worth $2k-ish?
I only ride 'em. I don't know what makes 'em work.
Oddball
vernon dent is online now   Reply With Quote
Old 12-29-2010, 09:27 PM   #201
crazydrummerdude
Wacky Bongo Boy
crazydrummerdude's Avatar
Oddometer: 7,651
crazydrummerdude is offline   Reply With Quote
Old 12-30-2010, 09:45 AM   #202
danedg OP
Oddometer: 6,773
Got a better photo?
Looks like there is some squirrely stuff been done to it. How accurate is that 20K mileage?
Old 12-30-2010, 10:33 AM   #203
vernon dent
Oddometer: 713
Originally Posted by danedg View Post
Got a better photo?
besides the seat? the sissy bar? the exhaust? the thick mist of on on the block at the push rod tubes?
only shot. near my oldest son's house a few hours away.
Oddball
Old 12-30-2010, 12:42 PM   #204
Renner
rockin' the toaster
Renner's Avatar
Oddometer: 2,331
yes...
but no more-ish
and don't run it again till the slingers have been cleaned (aka engine bottom-end rebuild).
"20,000 miles" and it's come to this... unglaublich
"If you want to fix it with a rock, you have to stick to stone-age technology" -Anton
"...solving the latest crisis that is preventing my Airhead from taking me to the bar." -Beater-
Renner is online now   Reply With Quote
Old 12-30-2010, 01:43 PM   #205
danedg OP
Oddometer: 6,773
Can you get the numbers off the frame and motor? If they're matching, $2K is a generous offer....
Why are the hubs and air cleaner so rusty?
It's probably good that you got it started, and it ran... got some juices flowing...it turns over...
Get a compression reading...100 psi is minimum.
They only made 23,000 of the things...
Where are you?....
danedg screwed with this post 12-30-2010 at 04:57 PM
Old 12-30-2010, 05:13 PM   #206
danedg OP
Oddometer: 6,773
here's the gasket kit from BING...$18.xx
there's a coupla extra in there for other carbs...
...don't need 'em...
My carbs, my slides, my jets, seats and gaskets, are workin' real good after 45 years....
...if they ain't broke.....?
Old 12-30-2010, 05:19 PM   #207
danedg OP
Oddometer: 6,773
how the cables run
Old 12-30-2010, 05:28 PM   #208
Rapid_Roy
finally understands
Rapid_Roy's Avatar
Oddometer: 26,507
I have the carb top kit that replaced the float center with a rounded rod, and the top has a needle valve on a brass lever that the float pushes up to seat. I still get "gas foot."
The first time I start it up in Spring, I tickle it and it starts in one kick. Then I try not to use it unless it sits for a week or two (which sucks, when it's riding season here for that bike ).
It is better to have less thunder in the mouth and more lightning in the hand.
Rapid_Roy is offline   Reply With Quote
Old 12-30-2010, 05:28 PM   #209
Stagehand
Imperfectionist
Stagehand's Avatar
Oddometer: 27,214
that looks purty
Unintentional psychokinesis.
Stagehand is online now   Reply With Quote
Old 12-30-2010, 05:41 PM   #210
danedg OP
Oddometer: 6,773
..yer needle ain't fittin' right somehow into the fuel cutoff...
..you might get a little, but not 'gas foot"....
Stagehand gets gasfoot... I was there...
Times are GMT -7.   It's 10:15 AM.
