Old 12-30-2010, 06:56 PM   #211
danedg OP
Horizontally Opposed
Oddometer: 6,531
as each picture, is worth a thousand words, this'll be a long thread
the great story about this bike is Zircon rode it from Cleveland and back for 3 years, and finally holed a piston on the NYS Thruway last year...
Sam was riding shotgun with his '68 R69S in the back of the Ford. They switched bikes and Bob rode Sams bike back to Ohio, with Zircon's '68 as a trailer queen....it is apparently still not back on the road....but he finished the work on this little R60US...
sweet bike...
danedg screwed with this post 12-30-2010 at 07:27 PM
danedg is online now   Reply With Quote
Old 12-31-2010, 10:57 AM   #212
Rapid_Roy
finally understands
Rapid_Roy's Avatar
Oddometer: 25,562
Originally Posted by danedg View Post
..yer needle ain't fittin' right somehow into the fuel cutoff...
..you might get a little, but not 'gas foot"....
Stagehand gets gasfoot... I was there...
No. The needle seats far better than the original setup. My floats are original and have a lip around them where they were soldered together. That lip can catch on the side of the carb if conditions are just right, preventing the float from going up.
It was much worse with the original tops and float rod because it would cock enough that the needle wouldn't even come close.
It doesn't happen often, not enough to attempt to curl the edges anyway.
It definitely is gas foot.
What?!
Rapid_Roy screwed with this post 12-31-2010 at 11:09 AM
Rapid_Roy is offline   Reply With Quote
Old 12-31-2010, 04:23 PM   #213
danedg OP
Oddometer: 6,531
Our First Night Together
Old 12-31-2010, 06:48 PM   #214
danedg OP
Oddometer: 6,531
Old 01-02-2011, 01:22 PM   #215
danedg OP
Oddometer: 6,531
Just a reminder, ride every chance you get. You just don't know how soon it can be taken from you. T.Low
Old 01-02-2011, 02:50 PM   #216
danedg OP
Oddometer: 6,531
Margaret Lewis Norrie State Park
Old 01-03-2011, 01:26 PM   #217
danedg OP
Oddometer: 6,531
Are my Slingers Full?
.....and can I see them without pulling the crank?
Yes!...and NO!
danedg screwed with this post 01-06-2011 at 07:22 PM
Old 01-03-2011, 03:58 PM   #218
danedg OP
Oddometer: 6,531
Skirts Up!
So...it's the DEAD of winter...and I'll finally change that Dunlop that only lasted 600 miles on the back....
I picked up a pair of 'em on sale, and when the Bridgestone finally crapped out after 9000 miles, I popped this on. Useless...
So I'm gonna try one of these Michelins I got from Vech...
Between the luggage rack and the buco mounts, it's always an adventure gettin' into the rear fender, to pull the rear wheel...
It was worse when half the bolts had 11mm heads and half had 10....they are ALL now 10mm.!
danedg screwed with this post 01-03-2011 at 04:14 PM
Old 01-03-2011, 04:34 PM   #219
danedg OP
Oddometer: 6,531
What you'll find under the hinge flap
not pretty...and no accommodation was ever made to keep this spot from accumulating 60,000 miles of stuff....
Old 01-03-2011, 05:39 PM   #220
mykill
odd
mykill's Avatar
Oddometer: 1,160
Michelin Pilots
Are you running the same size tire F&R?
Never underestimate the laxative properties of motorcycling.
mykill is offline   Reply With Quote
Old 01-03-2011, 05:59 PM   #221
danedg OP
Oddometer: 6,531
I put a matched set of Bridgestone Spitfire S11's on it. 100/90 - 18 frt, and 110/90 -18 rear. I put 9000 or so on the rear, and the front is still on there.
Great tires. We'll see how the Michelin wears....
so YES.... it'll have 100/90-18's front and rear....
...the thing's a tractor....!
Old 01-03-2011, 06:40 PM   #222
danedg OP
Oddometer: 6,531
So I was telling that other guy about oilflow and I remembers this...
One of the biggest advantages of increased capacity that is rarely mentioned is the fact that with increased capacity, the oil goes through the pump less often. The pump itself heats the oil considerably! Many a tuner has got more power to the ground AND decreased oil temps by downsizing the oil pump. I have worked on one such airhead.
Lowering the sump level away from the crank is often a good thing when you have the room but don't forget that these engines are plain bearing engines. There are VOLUMES of oil squirting out of those rod and crank bearings like putting your finger over the end of a garden hose. All that oil squirting out becomes a big blob of oil that hangs around the spinning crank and rods and actually pulsates and moves around. ALL the while this blob is loosing as much oil as what is going into it from all the oil squirting out of the plain bearings. ALL that oil is up there and ALL around your crank breather until your sump level gets down below the oil pickup. I don't recommend lowering your sump's oil level that far! Your right rod big end is sure to go first and
danedg screwed with this post 01-03-2011 at 06:59 PM
Old 01-03-2011, 09:24 PM   #223
crazydrummerdude
Wacky Bongo Boy
crazydrummerdude's Avatar
Oddometer: 7,593
..and?! AND?!
crazydrummerdude is offline   Reply With Quote
Old 01-04-2011, 04:37 AM   #224
Jimbosidecar
Jimbosidecar's Avatar
Oddometer: 238
/2 Bings
Don't laugh, but Chang Jiang carbs look an awful lot like these and may work as a replacement. They are cheap at about US$ 65/pair or so.
Regds,
Jim
www.bmwsidecar.com
My levertop retainer has failed. Not only has the fibrous washer disappeared but the distressed shaft has worn through the top. My temp solution was to secure it with a zip tie, which proved to be gasoline resistant. At least I didn't lose the lever...
I'm thinking a blob of JB Weld on the right spot as a new retainer...
Any flashes of brilliance out there?
Jimbosidecar is offline   Reply With Quote
Old 01-04-2011, 07:56 AM   #225
Chad M
Custom User Title
Oddometer: 771
Lowering the sump level away from the crank is often a good thing when you have the room but don't forget that these engines are plain bearing engines. There are VOLUMES of oil squirting out of those rod and crank bearings like putting your finger over the end of a garden hose. and
Your aircooled VW has plain (shell) bearings, your /2 has ball bearings. I don't have a lot of experience with these bikes but I understood this era of engine had rather low oil pressure as very little oil is required for a roller bottom end.
Chad M is offline   Reply With Quote
Times are GMT -7.   It's 06:20 AM.
