View Results: What should Tlub do with his R50?
Nothing 21 0.01%
Pimp it out and chrome the crap out of everything 4 0.00%
Repaint it to look like everybody elses' bike 314,159 99.99%
Voters: 314184. You may not vote on this poll
Old 01-08-2011, 08:54 AM   #256
danedg OP
Horizontally Opposed
Oddometer: 6,772
Originally Posted by Renner View Post
yup...see the " / 3 " , stamped below the model # ?....
Renner... I'm looking at the air mixture and idle adjuster screwws on what I assume is your bike....
...were my carbs adjusted like that, I'd be idling at 2500 rpm and lean enough to hole a piston....
54' R51/3, 65' R60/2, 68' R60US, 74' Moto Guzzi Eldorado, 95' Mystic, '78 Honda Hawk...... the Axles of Evil!
danedg screwed with this post 01-08-2011 at 09:03 AM
danedg is offline   Reply With Quote
Old 01-08-2011, 09:11 AM   #257
Renner
rockin' the toaster
Renner's Avatar
Oddometer: 2,326
yeah, /3... gotta wonder.
You'll agree it's best not to adjust carbs by appearances.
Mine idles around 800-1000 and slightly rich.
"If you want to fix it with a rock, you have to stick to stone-age technology" -Anton
"...solving the latest crisis that is preventing my Airhead from taking me to the bar." -Beater-
Renner is offline   Reply With Quote
Old 01-08-2011, 11:46 AM   #258
danedg OP
Oddometer: 6,772
On the Flip Side
Leaky exhaust... I bought new crush nuts, cleaned the header threads and was REAL careful NOT to overtighten....
apparently it didn't quite seat correctly....
...both sides....
how much do you think that will affect performance? I thought it seemed loud...
How does one get everything sucked up tight?
Old 01-08-2011, 11:52 AM   #259
Stagehand
Imperfectionist
Stagehand's Avatar
Oddometer: 27,205
...both sides....
It should suck up tight over a couple of heat cycles, I presume. Snug it up, run it for a bit, snug it up in a day or two, run it. etc.
Unintentional psychokinesis.
Stagehand is offline   Reply With Quote
Old 01-08-2011, 12:11 PM   #260
danedg OP
Oddometer: 6,772
as horrifying as this may appear to a person such as yourself... I'm making my exhaust system shiny
...and I remember asking you, when I was a youngster....how much does a sloppy exhaust connection affect how the bike runs???....
...and you shrugged your shoulders and said..." ehhhh...."
So this time...I'm gonna mount the headers FIRST... then fit everything else down the line....
Think it'll make a diff?
Old 01-08-2011, 01:00 PM   #261
Stagehand
Imperfectionist
Stagehand's Avatar
Oddometer: 27,205
Thats a good idea. you'll probably find you have to loosen up the front stuff when the back mounts wont line up, but what the heck? I think I've since learned that the bike will run just fine (maybe sound farty) on some exhaust leaks, and if the thing sounds too bad or runs too bad, then find the pisser. THey sure do heat up and cool down over a greater range than the other parts generally do though.
Old 01-08-2011, 03:34 PM   #262
danedg OP
Oddometer: 6,772
I think the point is....
I've got wee ponies at best.
Sealing the intake side is good.
Whaddabout the other side?
Old 01-08-2011, 04:00 PM   #263
Renner
rockin' the toaster
Renner's Avatar
Oddometer: 2,326
Sealing the other side ist auch gut.
Aber only so much as is required, not wanting to risk galled exhaust spigot threads.
best to snug the nuts. If you find there's leakage then snug a little more.
but you know this... not going to free ponies appreciably, just good practice.
have you checked the two mating surfaces for flatness using plate glass and feeler guages?
It looks to me like you could improve the exhaust seal by sanding one or both surfaces flat
Renner screwed with this post 01-08-2011 at 10:00 PM
Old 01-09-2011, 03:22 PM   #264
danedg OP
Oddometer: 6,772
Old 01-09-2011, 03:37 PM   #265
danedg OP
Oddometer: 6,772
Old 01-09-2011, 03:37 PM   #266
datchew
Don't buy from Brad
datchew's Avatar
Oddometer: 7,409
Dan... are you in the middle of another rebuild?
datchew is offline   Reply With Quote
Old 01-09-2011, 03:44 PM   #267
danedg OP
Oddometer: 6,772
Still documenting the first one....
..didn't wanna publish unless the results were good.....
...so far...so good!
danedg screwed with this post 01-09-2011 at 04:00 PM
Old 01-09-2011, 06:48 PM   #268
Renner
rockin' the toaster
Renner's Avatar
Oddometer: 2,326
Sealing the other side is also good.
Has the lack of sealing at the exhaust header to spigot junction been resolved?
Old 01-10-2011, 11:28 AM   #269
danedg OP
Oddometer: 6,772
it's got a certain manatee look to it.....
Old 01-10-2011, 03:06 PM   #270
danedg OP
Oddometer: 6,772
inside yer headlight...
Times are GMT -7.   It's 01:39 AM.
