Old 03-11-2011, 05:22 AM   #496
65bmwr50
65bmwr50's Avatar
Oddometer: 535
Ethanol question...
I was reading your ride report and I can't get good old dino juice here in Virginia. Anyone have any ideas as to what I can do to keep my bings alive? I just got her running again, I don't want to ruin it!
1965 BMW R50/2 (RUNNING AGAIN!)
An adventure is only an inconvenience rightly considered. An inconvenience is an adventure wrongly considered. - G. K. Chesterton
65bmwr50 is offline   Reply With Quote
Old 03-11-2011, 05:38 AM   #497
Twotaildog
Old Poop
Twotaildog's Avatar
Oddometer: 1,289
Somewhere I have seen ethanol proof floats advertised. I'd check with Vech at Benchmarkworks.com. He was always helpful to me.
Twotaildog is offline   Reply With Quote
Old 03-11-2011, 05:50 AM   #498
Twotaildog
Old Poop
Twotaildog's Avatar
Oddometer: 1,289
Originally Posted by gertiektn View Post
Any one know what the KN means?
Here is my r50 when I put my exciter..(magnito) to the timing mark.
That was fun and a challenge..
So what does the KN mean?
Jim, Ketchikan
I'm not sure Jim. Mine didn't have that.
Kevin
Old 03-11-2011, 06:00 AM   #499
65bmwr50
65bmwr50's Avatar
Oddometer: 535
Jim, Ketchikan
I went back through the pictures when my dad rebuilt the motor for me and my 65 R50 didn't have those marks. Sorry no help here.
Old 03-11-2011, 06:51 AM   #500
danedg OP
Horizontally Opposed
Oddometer: 6,528
We run %10 Ethanol here. I haven't noticed any problems related to the corn syrup. Jezebel just sat for 4 months, and started on the first kick. I use no additives to the gasoline. I use the highest octane available as it ignites at a lower temp. I hear stories about the alcohol attacking plastic bits, but the only plastic on this bike are the saddlebags. My floats are still brass. Benchmark Works offered some plastic replacement floats a while back but they didn't work out. Better check with him, to see if they've solved the problem.
I believe your bike should run just fine on modern gas. They run better if you ride 'em every day. It's a low compression, low rpm, tractor with two wheels. Just change the oil a lot, and she'll putt along just fine for a long time.
Just a reminder, ride every chance you get. You just don't know how soon it can be taken from you. T.Low
danedg is offline   Reply With Quote
Old 03-11-2011, 11:21 AM   #501
Stagehand
+/- V TDSPP
Stagehand's Avatar
Oddometer: 26,103
Dans a happy man when the mailman comes.
Unintentional psychokinesis.
Stagehand is offline   Reply With Quote
Old 03-11-2011, 11:28 AM   #502
danedg OP
Oddometer: 6,528
'Specially when he's bringin' on some shiny new bling from Mississippi...
Old 03-11-2011, 11:43 AM   #503
bergermeister
housin'
bergermeister's Avatar
Oddometer: 2,055
The sport (narrow) bench seat allows my 29" inseam to straddle the bike and be flat footed...
I thought the solo seat would be the same or lower.. not true.
There is the ability to move the mounting base to the last set of holes in the plate between the tubes ahead of the battery box and to move the seat attachment to the last ... back attachments to the seat frame.. this is the lowest setting allowed by the design.
It is higher, but I can live with it.. more to report later..
Jim, Ketchikan, Alaska
Hey Jim,
I think some work can be done to the seat bracket to make it lower. I believe mine was modified prior to purchase by me. Either that, or it's a custom bracket. I can post a pic later if you'd like some ideas.
bergermeister is offline   Reply With Quote
Old 03-11-2011, 12:27 PM   #504
danedg OP
Oddometer: 6,528
So the question is...
What is the increase in lumens, when one changes from a 6V 35w Incandescent bulb,
To the new and superimproved, 6V 35W HALOGEN bulb????
danedg screwed with this post 03-11-2011 at 05:47 PM
Old 03-11-2011, 12:34 PM   #505
danedg OP
Oddometer: 6,528
Jim, Ketchikan
KetchekaN
Old 03-11-2011, 01:08 PM   #506
bpeckm
Grin!
bpeckm's Avatar
Oddometer: 5,774
XS650 becomes a VT BackRoadRunner
Loving the 80ST
I love projects that take twice as much effort as should be needed. Should be an Airhead motto. (disston)
bpeckm is offline   Reply With Quote
Old 03-11-2011, 01:29 PM   #507
devo2002
-Devo
devo2002's Avatar
Oddometer: 3,815
Just stumbled across this thread, wonderful pics Dan!
Originally Posted by danedg View Post
2014 DL650 Vstrom
devo2002 is offline   Reply With Quote
Old 03-11-2011, 05:44 PM   #508
danedg OP
Oddometer: 6,528
What's my headlight got? That yours don't?
Old 03-11-2011, 06:01 PM   #509
danedg OP
Oddometer: 6,528
Rearview
Old 03-11-2011, 06:14 PM   #510
danedg OP
Oddometer: 6,528
Times are GMT -7.   It's 10:29 PM.
