Old 01-22-2012, 08:56 AM   #1156
danedg OP
Horizontally Opposed
Oddometer: 5,287
I'll happily acknowledge my meager knowledge of auto electrics, but I'm stumped as to how you've got an alternator supplying juice where necessary without having a battery inline...
'65 R60/2
'68 R60US
'74 MG Eldorado
'95 R100M
danedg is offline   Reply With Quote
Old 01-22-2012, 11:59 AM   #1157
Goomicoo
Rubber Cow
Goomicoo's Avatar
Oddometer: 465
Originally Posted by datchew View Post
It's a /2. It doesn't require any at all! But it has a 12V anyway.
Batteries Plus, Xtreme, AGM Permaseal, XTAX7L-BS
I think he saying that a slash 2 doesn't need it in normal circumstances. I imagine he knows that an alternator does need a battery as the field is not self exciting! I'll give him the benefit of doubt on that one.
After the Honda it's been all BMW's
R65, R1100S, R1100RT
R1150R, R1150GS, R1150GSA
R90/6, R60/5
R60/2, R50/2, R69s X 3
Goomicoo is online now   Reply With Quote
Old 01-22-2012, 12:25 PM   #1158
datchew
Don't buy from Brad
datchew's Avatar
Oddometer: 7,403
While I appreciate the benefit of the doubt, it's misplaced.
My electrical prowess is quite anemic, however... I do know that even if I cut all the wires to my charging system, the bike will still continue to run. And this is what I meant about not requiring a battery.
That being said... this also speaks to my lack of reading comprehension as it's obvious to me now that this is not what Dan was asking.
He's probably used to me being a little off the mark by now.
On tap:Nada
Aging: 3 experiments in mead - blackberry, apple, and straight honey
datchew is offline   Reply With Quote
Old 01-22-2012, 01:28 PM   #1159
danedg OP
Oddometer: 5,287
You've got a unique, well engineered system there.
'65 R60/2
'68 R60US
'74 MG Eldorado
'95 R100M
danedg screwed with this post 01-22-2012 at 02:35 PM
Old 01-22-2012, 01:47 PM   #1160
Goomicoo
Rubber Cow
Goomicoo's Avatar
Oddometer: 465
I think we're all on the same page here. Different paragraphs though!
R90/6, R60/5
Old 01-22-2012, 02:26 PM   #1161
danedg OP
Oddometer: 5,287
That coil looks familiar. And new.
Emerald?
Is it 12V? Does it matter?
Most importantly, does the bike run better with 800W of raw power?
It must light up those 6V bulbs!
'65 R60/2
'68 R60US
'74 MG Eldorado
'95 R100M
Old 01-22-2012, 04:31 PM   #1162
Goomicoo
Rubber Cow
Goomicoo's Avatar
Oddometer: 465
Emerald?
That's a lot of stuff to pack under the cover!
R90/6, R60/5
Old 01-22-2012, 05:21 PM   #1163
wirewrkr
the thread-killer
wirewrkr's Avatar
Oddometer: 4,297
this was also a factory option in the last few years of the /2 bikes.
I ran this same set up on my brothers 64 R60 until it was transformed into an R90/2
www.wirewerkes.com
KILL YOUR TELEVISION !!!!
Old 01-22-2012, 06:37 PM   #1164
danedg OP
Oddometer: 5,287
A 12V alternator?
'65 R60/2
'68 R60US
'74 MG Eldorado
'95 R100M
Old 01-22-2012, 07:59 PM   #1165
Carl
Carl's Avatar
Oddometer: 680
The factory /2 Twins alternator system is/was 180W and uses the identical charging circuitry as the /5 and up airheads.
Dat's system is a custom that uses a mod'd (both mechanical and electrical) 280W post '74 airhead stator and rotor, along w/ DR Delcotron charging components.
The two charging systems have similarities, but are not the same.
It is a rare jewel to find a '68 or earlier airhead twin w/ a factory alternator system, The 4-brush generator 100W system were sometimes used on authorities fleet machines and tend to be more common
Carl
Dat's charging system circuitry
NOS 12V 180W alternator harness. Note the earthed brush lead:
http://www.flyingtpot.com/
Don't be a dick. I'm growing weary of having to follow you around cleaning up the arguments you seem to invariably involved in.
Thank you. Dave
BINGO
Carl is offline   Reply With Quote
Old 01-22-2012, 08:19 PM   #1166
danedg OP
Oddometer: 5,287
Brilliant!
Thanx for sharing!
By the way, what became of your old 6V system?
'65 R60/2
'68 R60US
'74 MG Eldorado
'95 R100M
danedg screwed with this post 01-23-2012 at 01:58 PM
Old 01-23-2012, 03:09 PM   #1167
danedg OP
Oddometer: 5,287
Sam's '68 R69S has a 12V generator setup on it. It's been reliable.
'65 R60/2
'68 R60US
'74 MG Eldorado
'95 R100M
danedg screwed with this post 01-23-2012 at 07:49 PM
Old 01-23-2012, 03:29 PM   #1168
Carl
Carl's Avatar
Oddometer: 680
Sam's '68 R69S has that 12V generator setup on it. It's been reliable.
Are you sure it's the Bosch/DR Delcotron design and not the Bosch/Voltpak type?
Carl
Thank you. Dave
BINGO
Old 01-23-2012, 03:42 PM   #1169
danedg OP
Oddometer: 5,287
Couldn't tell you.
The bike has the 12V "Police" generator package
OEM I believe.
I didn't know they had an alternator rig available before the /5.
Looks very stout!
'65 R60/2
'68 R60US
'74 MG Eldorado
'95 R100M
danedg screwed with this post 01-23-2012 at 07:53 PM
Old 01-24-2012, 06:16 AM   #1170
Bill Harris
Confirmed Curmudgeon
Bill Harris's Avatar
Oddometer: 3,862
Originally Posted by Datchew
Inmate Carl helped me out and most of this (except the points plate) is his design.
That 12v alternator set up is sharp, real sharp. The Delco rectifier bridge is indeed the heart of the Emerald Isle/Omega BMW diode board. On a Delco alternator, it normally resides inside of the alternator housing, along with the voltage regulator.
'73 R60/5 Toaster
Times are GMT -7.   It's 11:54 AM.
