Old 03-23-2010, 11:55 AM   #1
newride OP
newride's Avatar
Oddometer: 704
airhead "gasket" ID
Okay so I don't have a picture, but I am trying to figure out the name of a rubber "gasket" in the front cover of my R90/6
If you take off the front cover of the bike, down below there is a rubber gasket that I would assume would go where the points were. I have electronic ignition, so I a not sure. It tucks into a little groove
Mine is completely falling apart and I wanted to get a new one. Does any one have any idea what it is called?
It is not perfectly round and seems to be not connected to itself if that makes sense. Maybe mine just fell apart.
Sorry I seem to be at a loss for describing things today.
1975 BMW R90/6
My moto blog: http://jbloggie1.blogspot.com/
newride is offline   Reply With Quote
Old 03-23-2010, 12:04 PM   #2
mykill
odd
mykill's Avatar
Oddometer: 1,166
http://www.realoem.com/bmw/showparts...33&hg=11&fg=10
Try this.
Never underestimate the laxative properties of motorcycling.
mykill is offline   Reply With Quote
Old 03-23-2010, 12:17 PM   #3
CurlyMike
Formerly SaddleSoar
CurlyMike's Avatar
Oddometer: 984
I just replaced one of those points gaskets and Boxers by Bruce sells it by the foot. Much cheaper.
After doing so I was changing the oil on my wife’s van and when I took of the Wix oil filter the rubber gasket looked just like the one I bought for the points, square and all. Havent had the chance to pull the cover off of the bike and see if that one would work. It looks like its 3mm by 2mm in the pict and description. If it does fit, it will be a good recycling option...
Giving the horses and the wife a break from riding...
CurlyMike is offline   Reply With Quote
Old 03-23-2010, 12:21 PM   #4
newride OP
newride's Avatar
Oddometer: 704
Originally Posted by mykill
That did it!
Thanks for the link!
Wow,
$13.00 for a little piece of rubber, oh well.
1975 BMW R90/6
Old 03-23-2010, 12:56 PM   #5
mykill
odd
mykill's Avatar
Oddometer: 1,166
Originally Posted by newride
That did it!
Wow,
That is a silly price. I ran without one for years and never had an issue. Make sure the point wire rubber is in good shape and seats well. My buddy had his bike sitting in the rain and the points filled with water. The opoint wire boot let the water in and the gasket did not let it out.
Old 03-23-2010, 08:03 PM   #6
Bill Harris
Confirmed Curmudgeon
Bill Harris's Avatar
Oddometer: 7,740
That part is a:
11 14 1 265 394 points seal strip ( 3.2mm x 20cm ) 1970 - 1979 $ 5.00
One of the best sources for Airhead BMW parts is Hucky's Spare Parts
http://bmwhucky.com/
'73 R60/5 Toaster
Old 03-24-2010, 07:54 AM   #7
newride OP
newride's Avatar
Oddometer: 704
Thanks Bill,
Jeremy
1975 BMW R90/6
Old 03-24-2010, 09:57 AM   #8
wirewrkr
the thread-killer
wirewrkr's Avatar
Oddometer: 4,295
Originally Posted by Bill Harris
That part is a:
Just so you all know, that description is incorrect.
the 3.2mm is only for 1970-1975 models, when BMW changed the chain cover in 76, the size of that seal increased to 4.2mm
the part number for 76-78 is 11 14 1 262 644.
robert
Robert
www.wirewerkes.com
KILL YOUR TELEVISION !!!!
Old 03-24-2010, 10:25 AM   #9
Yarddog
Oddometer: 322
They recommend when you install the Dyna III ignition to drill a hole to let out the water in the bottom of the cover...I did so, believe it would be wise to do for points ignition also...
Yarddog is offline   Reply With Quote
Times are GMT -7.   It's 07:51 PM.
