Old 03-23-2010, 05:23 PM   #1
Lost Rider OP
Broken Roadie
Lost Rider's Avatar
Oddometer: 2,807
F800GS - More Problems with mine, lets hear about yours....
Lost Rider screwed with this post 11-29-2011 at 08:53 AM
Lost Rider is offline   Reply With Quote
Old 03-23-2010, 05:31 PM   #2
johngil
Reseda, CA
johngil's Avatar
Oddometer: 3,502
So I guess we won't be seeing you in Death Valley this weekend...
I'll pour one out for you.
johngil is online now   Reply With Quote
Old 03-23-2010, 05:53 PM   #3
johngil
Reseda, CA
johngil's Avatar
Oddometer: 3,502
We will have tow ropes and beer.
Of course I may be worthless and need help myself.
My wheel bearings out back seem crunchy. My dealer says it's not time yet. "They are fine."
I've got a spare set just in case.
johngil screwed with this post 03-23-2010 at 06:01 PM
Old 03-23-2010, 06:13 PM   #4
805gregg
Just Stroming along
Oddometer: 1,318
So does BMW charge more for their new bikes to pay for fixing their sold bikes?
805gregg is offline   Reply With Quote
Old 03-23-2010, 06:51 PM   #5
Dansrc51
I need a cape....
Dansrc51's Avatar
Oddometer: 998
I notice you ride pretty hard. What's your mileage if you had to guess? on-road? off?
sucks the yeller beast let you down. I've just had the basics (axle, bearing, radiator hose), but all covered and fixed promptly by my dealer. not to get to koolaid-y but my dealer is seriously the best I've ever seen.
motorcycles are a disease and riding is the only cure.
Dansrc51 is offline   Reply With Quote
Old 03-23-2010, 07:39 PM   #6
dave61
Oddometer: 4
What was the cause of the oil leak? Was it the stock chain that broke or after market?
Have had starting issues with my 800 when new, was a fuel issue. Could spray starter fluid down intake and it would run. After starting with starter fluid a few time it would run OK. Maybe a fuel injection issue. Has not been an issue for the last eight thousand miles. Maybe it fixed its self.
Rode the Great divide ride, 2792 miles mainly off road. Beat up fork bearings and knocked front wheel out of round a little. Have slight wobble from front wheel at the moment. Need to tighten spindle fork bearing a little more.
Planning on leaving for Inuvik mid may, when did you hit the Dempster? thanks......David
dave61 is offline   Reply With Quote
Old 03-23-2010, 08:59 PM   #7
kkug
kkug's Avatar
Oddometer: 931
Sorry to hear of all your problems. I had a simular experence with a first year 950 KTM. A lot of things but it always got me home. I sold it at 35 K and got a F800GS .
I have 15 K on it now. My problems
Caught the rear wheel bearings before they got real bad. Warrenty.
Front axel-Warrenty
Hoses-Warrenty -But I changed out the clamps because I do not trust the Beemer clamps.
Valve cover leak ( slight ) -Fixed my self when I checked the valves myself.
Fuel Pump craped out- Lucky not too far from dealer-warrenty
Run out of gas twice-Needs biger tank. Mabey stressing fuel pump ?
Bent front wheel- My foult- hit rock-- But Wheels are soft- Will replace with an Excell soon.
I will also replace my chain soon.
I am somewhat happy with the bike but know that I need spares or need to know how to work around these problems if on a trip.
Does any one know of a aftermarket fuel pump fix that I could carry on a trip ?
Thanks -Ken
________________________________
F800GS
KTM 450 MXC
"Never let the Situation affect you Emotionally. If you do it will have an adverse affect on your ability to make the correct decisions.
kkug is offline   Reply With Quote
Old 03-23-2010, 09:24 PM   #8
Bayner
Oddometer: 1,245
14K kms
I've had the valve cover leak, and front and rear wheel bearing failures. No other funky shit yet though. Slight coolant leak from an upper bolt on the water pump the other day though, which I thought was odd. We'll see how that plays out once I'm riding more. Dealer fixed the v/c leak no problem (well, there was some drama involved that required a return visit, but it was an honest mistake). No love on the other issues.
Woody's is doing up some wheels for me so I can roll on somethign round this year, which will be nice for a change.... and my rear hub was too tight in the bearing bore, which he also sorted out.
Bayner is offline   Reply With Quote
Old 03-23-2010, 09:45 PM   #9
Ducksbane
Quaaack!!!
Ducksbane's Avatar
Oddometer: 1,120
I have 20,000km in one year on my 800.
I really like it,but of course it is not perfect.
Problems:
  1. Rear wheel bearings … destroyed the originals by 10,000 km, replaced with SKF's, lasted 5,000km, just replaced with “Original” BMW bearings, but 2nd set of SKF's are ok, and I will keep them as spares. I am out of pocket buying and fitting the SKF's but at one stage BMW Australia couldn't supply the bearings. I will be writing to them soon and pointing this out.
  2. Front Axle – replaced under warranty
  3. Top Radiator hose – replaced under warranty, but the new part is still too short and leaked so it has a dealer approved jubilee clamp, problem seems solved.
  4. Fuel level sender – seemed fine but replaced under warranty, seems pretty accurate to me.
  5. Valve cover gasket leak – very slight – apparently fixed by dealer while doing valve check. I think they really "all do that!"
  6. Have a small bend in front wheel, have replaced the original fork springs with Hyperpro's – much better. I will soon do the rear spring as well.
  7. Chain – just replaced the original chains and sprockets with Regina kit. I didn't have any big problems with the original chain, but a friend had his break at 4,500km (replaced under warranty).
I don't have any really big issues with this as I have been treated well … except for the wheel bearings, I still have some unfinished business there.
As I said I really like the bike, but if I could change a few things I would like better more progressive suspension as standard, wider gear ratios, better screen and seat. I don't suppose anyone at BMW Motorad is listening? … hmmn thought not!
Ducksbane is offline   Reply With Quote
Old 03-24-2010, 01:27 AM   #10
GoneAgain
Huh?
GoneAgain's Avatar
Oddometer: 758
my valve/rocker cover gasket went at just over 16,000km... replaced no questions/dramas etc under warranty...
had no other issues, just put my 3rd back tyre on and bearings and chain are still fine....
GoneAgain is offline   Reply With Quote
Old 03-24-2010, 05:23 AM   #11
DockingPilot
Hooked Up and Hard Over
DockingPilot's Avatar
Oddometer: 7,563
In relative terms, the only thing I think is inexcuseable is the cheap ass chain and crappy forks (takes the crown from my 610 Husky).
The 800 dirty laundry list is still shorter than my 950 Adventure's was. And take a quick look over in thumpers at the 690 thread. It's all part of the Euro experience !
We're in good company fellas.
Frank Reinbold
"Every bike I ever had, was the best bike I ever had, when I had it"
*2010 FOREVER WEST*
NEW ENGLAND AND CANADA OFFROAD F800GS
14 DAY IDAHO ADVENTURE KTM 950
TRANS AM TRAIL WEST
TRANS AM TRAIL VID CLIP
THE DEAN OF WESTERN ADVENTURE ROUTES
DockingPilot screwed with this post 03-24-2010 at 07:26 AM
DockingPilot is online now   Reply With Quote
Old 03-24-2010, 07:20 AM   #12
GoneAgain
Huh?
GoneAgain's Avatar
Oddometer: 758
yeah, i have no problem... and to me it largely looks like the main problem is really with the North American $dealers.....
take your bike to Australia.... sure we get one year shorter warranty...... but at least they honour it.............................!
Old 03-24-2010, 07:35 AM   #13
Toadride
NTXer
Toadride's Avatar
Oddometer: 716
I bent the side stand the first few hundred out but, other than that nothing. Nada. In 30000kms. Is it Karma, Chi? Have you been bad?
Seriously, I'm stunned and would not wish your problems on my worst enemy, if I had one. Let's all wish Chi good luck from here on in. He obviously needs it!
Old 03-24-2010, 09:21 AM   #14
The Griz
North Forest Rider
The Griz's Avatar
Oddometer: 3,654
Originally Posted by ChiTown
Long Beach BMW just called, turns out it was just a battery failure.
They're covering it under warranty!
About time something works out good for me. ( if you consider a whole day waisted good)
SO I'm going to pick it up, and keep on going on.
It was weird when it died, like someone just turned the ignition off while I was riding. BAM. no power.
Hopefully this is just another random failure and not a thing to come with a batch of bad batteries, though I seem to have heard of a few like this.
Dan-A?..
It seems like my problems with the GS aren't so unique, just my combined BAD dealer experiences.
I think since I was early in some of these problems dealers didn't warranty some things because it was normal policy not to, but after BMW NA saw there's some design flaws or supplier issues they started having dealers cover things to keep the brand damage to a minimum...
Just a theory.
I know some have mentioned I should pursue reimbursement, but honestly I just want the frikin' bike to not break down. I don't want to deal with any BMW company BS.
We shall see how the Yellow Bitch does this week.... wish me luck!
ChiTown, the exact same thing just happened to me!! Battery failure. It wouldn't even take or hold a charge anymore. Glad to hear it was something simple. I know I was relieved when I was told it was just the battery!
The BMW tech at my dealer said that BMW's, due to the complex electrical and computer systems on the bike, rely on constant 12v throughput through the electrical system. Including the battery. He said that when the battery fails or gets really low, all sorts of odd things can happen, including erroneous fuel injection timing, air/fuel mixture, and spark timing. Head and tail lights will pulse. Etc.
Quick question, when you tried to restart the bike after it died, were some weird things happening? Like speedo and tach needles pulsing? Thanks.
Old 03-24-2010, 09:30 AM   #15
Gringa
Gringa's Avatar
Oddometer: 87
Question
Question, what number battery does this puppy use?, not in the manual and have not yet taken it out, thanks
A true Biker in need of more trips
#129166
Gringa is offline   Reply With Quote
Times are GMT -7.   It's 10:32 AM.
