03-25-2010, 03:22 PM
#46 | |
Oddometer: 44
With the old iron-sides you got with the wiring diagram, a bit of patience and a multimeter pretty far. Not so with CAN-bus. Quote:
03-25-2010, 03:29 PM
#47 |
Hooked Up and Hard Over
Oddometer: 7,563
Mine always shuts off. As far as I know. I dont have connected to the BMW plug though if that matters.
276c.
Frank Reinbold "Every bike I ever had, was the best bike I ever had, when I had it" *2010 FOREVER WEST* NEW ENGLAND AND CANADA OFFROAD F800GS 14 DAY IDAHO ADVENTURE KTM 950 TRANS AM TRAIL WEST TRANS AM TRAIL VID CLIP THE DEAN OF WESTERN ADVENTURE ROUTES |
03-25-2010, 04:08 PM
#48 | |
on the road o'dreams
Oddometer: 5,503
I find it hard to believe BMW would do this after spending years developing the system. On many large BMW's the CANbus system uses 3 computers to operate, so perhaps it's a cost thing? Dunno. |
#49 | |
House Ape
Oddometer: 2,178
Knock wood. David
David I'm tryin' ta think, but nuttin' happens! --Curly |
03-25-2010, 10:23 PM
#50 | |
motochorro
(Tobacco free since 12/01/10!) Failure. Shit, I'll have to try again. |
03-25-2010, 10:40 PM
#51 | |
motochorro
03-25-2010, 10:55 PM
#52 |
motochorro
Let me spout my hearsay. I have seen those step-down transformers keep the ZFE awake, firsthand. I am of the schematically unproven, but technically apparent, opinion that the residual remaining in the transformer makes the ZFE think a charger is plugged in: another reason to put in a relay. I do agree that BMW is not the only manufacturer to suffer from such issues. The problem is exacerbated by the fact that since BMW likes to bring their newest technology out before anyone else does, it sometimes seems like a beta version...
03-25-2010, 11:07 PM
#53 |
Oddometer: 389
Test
03-26-2010, 02:39 AM
#54 | ||
Oddometer: 44
CAN-bus
@sospelotudo
Quickly three disclaimers before I'd like to reply: First, Contrary to the common trend, I don't blame BMW for anything. They didn't expose that plug in the first place and I have no precise knowledge of what they intended to do with it. So when I'm faffing around with this thing I'm completely aware of the fact that I'm on my own if things don't behave to my liking. Second, concerning the CAN-bus in general: Well, I discussed this issue with my BMW mechanic (which btw deep-discharged from that plug one day with some generic mobile phone charger) and also on several occasions with friends which ended up in the automotive industry (One is working on injection electronics for BOSCH). My impression is that there is a growing concensus that what ADV-bikes (and real off-road cars for that matter) are concerned, CAN-bus has some disadantages: It sucks for field repairs. It sucks for reverse engineering when the right part is not at hand. It sucks for 3rd party assessory compatibility. And it very often ends up locking vital parts of the electronics (injection system, charging loop, fuel pump) just because some goofy assessory or the light system does something weired (In the old days you rip out the fuse and limp home). But yes, I am also well aware of the advantages for day-to-day use, road security, fault diagnosis (if you have the right kit, that is), protecting the engine, etc, etc and why it is here to stay. But all that is a different discussion, which doesn't belong in this thread. Third, I'd actually like to applaud you for posting here as an officially “BMW affilliated” person. My advice: Wear protective leather gear, you will need a thick hide. But back to the issue: Quote:
Finally, out of curiosity I got a couple of weeks ago down and dirty with this and tested this “switch off ” mistery. This was after a ridiculous scene on a parking lot where I made an absolute clown of myself getting my deep discharged bike up and running. Anyway, I have measured this with several loads which I intended initially (not all the same time, naturally) to connect there. They all had different residual currents between 50 and 300mA, if I remember right (since I'm at work I don't have my notes). Since this “ZFS remains up” effect doesn't happen all the time, you need a pretty big sample size of “power down cycles” (which include a waiting period of a minute) to see the effect. At some point I didn't feel like sacrificing my head-light bulb and also got bored, so I decided to call it a day after reconfirming three failures on three different devices and finally threw in a relay (~5$). Why didn't I wise up earlier? Well, my real worry was that if I put in a relay, which is also pulling (depending on the type) 50-150mA, why shouldn't the same thing happen? Well no idea, but it worked. So please note that your advice “just put in a relay” is double edged: My relay of 80Ω pans out fine. Some other relay of 60Ω, 100Ω might or might not work. And while we're at it: My hunch is that it might have something to do with the fact that the relay is (in a dc loop) a purely resistive load, but not the other charging assessories: DC voltage regulation cannot be done with step-down transformers. For this type of applications you use normally a charge pump type 3-Terminal Positive Voltage Regulator. My old garmin charger used a LM78M05. Don't feel curious enough to brake my recent one, but I bet they put in something similar. Since these regulators use capacitors to bump up (or down) V_output, they leave some ripple on V_input. Might be that what interferes with the CAN-bus. Either way, figuring out this kind of stuff used to be easier. Quote:
03-26-2010, 07:47 AM
#55 | |
Oddometer: 3,482
I may just wire the GPS to the battery directly leaving just my LED on the switched GPS output. I never leave the GPS on the bike if I'm away from it, so there won't be a big power drain and I would hope that with the DC-to-DC converter "brick" out of the circuit it will behave. If not I'll go with a relay approach ... CANBus ... hmmmmmmmmmmmmmm |
04-07-2010, 05:46 PM
#56 |
Oddometer: 201
ChiTown, what's the last few of your VIN? I have bike 00031 and it's been faultless so far except for the following:
1. Fuel-clogged charcoal canister causing fuel tank vacuum 2. Flaky oil-pressure sensor giving me false warnings in the middle of the pine barrens of New Jersey. Replaced sensor and no more false positives. 3. Bent sidestand First two handled under warranty (Hermy's BMW rocks!) and the third I just haven't had taken care of yet. 18,000 miles on the bike.
Cheers, Tom '09 F800GS (Yellow) '05 F650GS (Sold) '04 K1200RS (Sold) '03 F650GS (Crashed) (formerly hyperiate) http://www.shoottheapex.com |
04-07-2010, 06:12 PM
#57 | |
Dorkus Malorkus
Oddometer: 1,772
Battery Bug ![]() |
04-09-2010, 11:49 AM
#58 |
Oddometer: 949
Can you imagine if Yamaha would take a bike like the Xt225, simple, cheap and reliable and put a decent sized twin in it? It would selll like stink and alllow all these long suffering GS owners an option.
, i saved you the reply and added it to my post. Just saying, there is a lot of negatives about this once promising ride.
04-09-2010, 04:22 PM
#59 | |
Oddometer: 1,322
Armageddon Was Yesterday, Today We Have a Problem East is East & West is West 2008 http://www.advrider.com/forums/ad.php?t=400050 A Long Weekend 2009 http://www.advrider.com/forums/showthread.php?t=523893 All the Way to Nowhere & Back Again. 2010 http://www.advrider.com/forums/showthread.php?t=619683 Save 5 bucks on your Smugmug, use my discount code hQo9Atub1N9jg |
04-09-2010, 04:58 PM
#60 |
Oddometer: 52
