Old 06-18-2013, 06:38 AM   #2581
texas_aggie
Oddometer: 54
Quick question on one of my units. When I turn it on, it blinks blue once, then red four times, then blue normally. It also has such a low volume level I can barely hear it at full volume. I just charged the battery yet the problem persists. Any ideas?
texas_aggie is offline   Reply With Quote
Old 06-18-2013, 06:43 AM   #2582
danham
danham's Avatar
Oddometer: 275
From page 10 of the manual:
4.5.1 LED Indicator
When the headset is powering on, the red LED flashes rapidly indicating the battery level.
4 flashes = High, 70~100%
3 flashes = Medium, 30~70% 2 flashes = Low, 0~30%
Did the volume problem just show up, or has it been constant? Usual problem is speaker placement. Small changes in location relative to your ears make a big difference. Could your speakers have moved? Your ears [g]?
-dan
2009 BMW F800 ST
Never let your motorcycle take you where your brain hasn't been five seconds earlier.
danham is offline   Reply With Quote
Old 06-18-2013, 06:46 AM   #2583
BlueLghtning
Riding is my passion
BlueLghtning's Avatar
Oddometer: 5,403
The blinking light sequence is normal. The 4 red lights tell you it has 70% or more of battery power.
What are you having trouble hearing? Intercom, phone, music? When you turn the volume up on the Sena (while its on your head you are turning it towards the back of your head), can you hear the beep that tells you you are maxed out on the volume? Can you hear the beep when you go the other way all the way to low volume?
Have you recently changed the speaker setup or anything on this helmet? I'm guessing you had no trouble before hearing? Speaker placement is critical and stuffing them behind cheek pads away from your ear can really lower the volume.
Final suggestion. Go into the config menu (hold down jog dial for 12 seconds) and erase all the pairings and start over and maybe do a factory reset too?
BlueLghtning - Follow me on my SPOT Messenger
Mine: KTM 650 ADV (Katuki), 09 DL650, 08 Husky TE610, 08 WR250R
Hers: 07 Ninja 650R, 13 CRF250L
Smugmug Pics - Save $5 <-- Click Here
BlueLghtning screwed with this post 06-18-2013 at 10:41 AM
BlueLghtning is offline   Reply With Quote
Old 06-18-2013, 09:13 AM   #2584
AlecMyrddyn
Oddometer: 255
You say "one of your units". You have more than one?
If you swap the unit from helmet to helmet, does the quiet volume stay with SMH-10 unit itself, or with the helmet? That'll tell you if the problem is in the unit itself, or with the mount or speakers.
If the unit itself, try factory reset and a firmware upgrade again. Make sure you are running the latest copy of the updater and firmware. If that fails, contact Sena support for a replacement unit.
If the low volume follows the helmet, has it always been this way, or is this new? As others have already said, speaker placement is key. They should be centered over your ear canals. If this is a recent change and it worked fine before, the speakers, clamp or wiring may have been damaged somehow and you should call Sena for a replacement if under warranty.
Finally, remember that the Sena remembers different volume levels based on the activity. When you turn it on, before using the intercom or phone/music, turn the volume up until it beeps.
Hope that helps.
-Alec
AlecMyrddyn is offline   Reply With Quote
Old 06-18-2013, 10:19 AM   #2585
Nitro1970
Nitro1970's Avatar
Oddometer: 191
The volume on your phone turned up?
Nitro1970 is offline   Reply With Quote
Old 06-27-2013, 07:38 AM   #2586
obnoxious2
Oddometer: 36
I've noticed an occasional random sonic boom sound coming out of the smh10 speakers. I'm not sure if it's the speakers or the main unit itself that is causing it. It's completely random and it's pretty loud and annoying. It doesn't matter if I'm on the intercom with another smh10 or playing music thru A2DP to an iphone. I've sent an email out to Sena but was just wondering if anyone else has experienced this?
obnoxious2 is offline   Reply With Quote
Old 06-27-2013, 08:27 PM   #2587
Boon Booni
Red Clay Halo
Boon Booni's Avatar
Oddometer: 13,907
Dang it, noticed today that my clamp is cracked. Looks like I installed the Allen bolts too tight? Don't know how long it's been cracked, but it's been installed for at least 8 months.
Old 06-28-2013, 06:13 AM   #2588
Nitro1970
Nitro1970's Avatar
Oddometer: 191
Mine started acting up a little a couple of days ago. When I'm going to make a call the music will die down, I speak the name of the person I want to call, phone confirms its calling, starts ringing and the music starts creeping back in. Even when/if they answer the music is going... I can hear them ok but it's sure annoying.
Old 06-28-2013, 06:42 AM   #2589
El Gato
El Gato's Avatar
Oddometer: 783
Give Sena a call. They were good about RMA'ing my clamp when the earbud pigtail broke (again).
El Gato is offline   Reply With Quote
Old 06-28-2013, 07:05 AM   #2590
John Smallberries
John Smallberries's Avatar
Oddometer: 1,322
ditto
I have the same problem on some calls - the music volume reduces during the call, but does not go to zero. But not all calls.....
I will check to see if there is any new software to download.
'05 BMW 1200GS '09 Honda CRF230 '10 Yamaha TW200 '07 KTM 400 XCW/EXC '15 Jialing 150 GY2
John Smallberries is offline   Reply With Quote
Old 07-01-2013, 03:36 PM   #2591
sonic578
Oddometer: 749
Sena just announced the combo clamp for SMH10... earbuds AND speakers all in 1.
http://www.senabluetooth.com/products/acc_SMH-A0305.php
Available mid-July, but no pricing yet as far as I know?
Dave
'11 GS
sonic578 is offline   Reply With Quote
Old 07-01-2013, 03:45 PM   #2592
lmychajluk
Oddometer: 2,117
Judging by the pic and the connectors, it seems to be more for earbuds OR speakers, not AND.
-Lee
NE ADV Event Calendar (Request Additions here.)
2013 Triumph Tiger 800
2008 Suzuki SV650n (Sold... I miss that bike...)
lmychajluk is online now   Reply With Quote
Old 07-01-2013, 04:49 PM   #2593
rush2112_2112
rush2112_2112's Avatar
Oddometer: 191
That's a lot of wire hanging.
Sent from my LG Optimus G
Super Tenere
rush2112_2112 is offline   Reply With Quote
Old 07-01-2013, 04:56 PM   #2594
Boon Booni
Red Clay Halo
Boon Booni's Avatar
Oddometer: 13,907
Just install the speakers in the helmet and tuck the wire up when you are not using it.
Not the cleanest solution, but usable. A better solution would be to switch to helmet speakers automatically when the ear buds are unplugged.
The problem I found with that (because I made this mod on my original clamp) was that when switching back to earbuds I had to be careful to turn down the volume before making calls and listening to music. More than once I almost blew my eardrums out because of the high volume needed for the helmet speakers.
I actually found keeping the volume adjusted correctly when switching back and forth between helmet speaks and earbuds was too much of a pain and ditched the helmet speakers all together.
Old 07-01-2013, 04:56 PM   #2595
ts3doug
ts3doug's Avatar
Oddometer: 1,102
ts3doug is online now   Reply With Quote
Times are GMT -7.   It's 05:36 AM.
