Old 09-01-2014, 04:01 PM   #17656
STBNE
Yamaha ADVenturer
STBNE's Avatar
Oddometer: 6,995
I use Walmart's Supertech 20w50 synthetic in 5 quart container only $12 and change...good quality oil...supplier is Pennzoil/QuakerState
http://www.walmart.com/ip/Pennzoil-S...Quart/16474401
Cant find the speciific oil weight but its the same price as this...
1979 Yamaha XS1100F "Swampthing"
Go Your Own Way
"Never Too Far...Never Too Cold...Never Too Wet..." Moonshine Lunch Run Mantra... RIP Terry Hammond
Dont Speak Unless You Can Improve Upon The Silence!
STBNE screwed with this post 09-01-2014 at 04:13 PM
STBNE is offline   Reply With Quote
Old 09-01-2014, 06:29 PM   #17657
wb57
wb57's Avatar
Oddometer: 7,463
Looking for the specs on it. The one thing I'm a stickler about is that it meet JASO MA-2 specs. Just about all diesel oils do. Don't remember precisely where I got that, but I've heard it from several engine builders and it seems to be borne out every time I get a notion to look into it.
'10 Kawasaki Concours (EB)
'11 Kawasaki Versys
Turning money into spent fossil fuels.
(Smiley crap is implied in all posts.)
wb57 is offline   Reply With Quote
Old 09-01-2014, 06:56 PM   #17658
schnabba
Oddometer: 1,877
Yep - that is the Japanese Motorcycle Manufacturers specification for an oil used for engine lubricating AND a wet clutch... can't have too many friction modifiers with a wet clutch.
http://www.oilspecifications.org/art...MA_JASO_MB.php
Rotella meets those specs. Reason I use it over a motorcycle specific oil.
- walker
"If you don't like my driving, then stay off of the sidewalk!"
schnabba is offline   Reply With Quote
Old 09-01-2014, 07:03 PM   #17659
schnabba
Oddometer: 1,877
Rotella meets JASO DH2 and JASO MA. Reason I use it over a motorcycle specific oils at higher prices.
Plus, I used it in the VW TDI for 200,000 miles (10,000 mile oil change intervals), so it was easy to just buy more and use it in the motorcycles as well.... also figured because of the nice soot control / acid resistance for the diesels, it would work in a motorcycle better if I got lazy and didn't feel like changing the oil
- walker
schnabba screwed with this post 09-01-2014 at 07:10 PM
Old 09-01-2014, 07:19 PM   #17660
STBNE
Yamaha ADVenturer
STBNE's Avatar
Oddometer: 6,995
you've got me there...I'm clueless...however amongst the XS1100 crowd the supertech is the right stuff...it has no friction modifiers...we also have the wet sump clutch...
OK I looked at my container here at home it says on the back "where a SAE 20w50 that meets API,SN,SM or SL is specified...so according to the JASO standards...we are good here...why spend so much more when this does essentially the same for substantially less $$$. Its Pennzoil/Quaker State like I said before...
Go Your Own Way
STBNE screwed with this post 09-01-2014 at 07:55 PM
Old 09-01-2014, 08:32 PM   #17661
wb57
wb57's Avatar
Oddometer: 7,463
Going to dig into it further, but take a look at this page:
API SN is the most current designation for cars.
JASO MA is motorcycle specific.
http://en.wikipedia.org/wiki/Motor_oil#JASO
'11 Kawasaki Versys
Old 09-01-2014, 08:42 PM   #17662
schnabba
Oddometer: 1,877
if your clutch doesn't slip, use it!
That is the real problem with friction modifiers - they make some wet clutches slip.... never had a problem with mobil 1 on some bikes, but simply swapped to JASO MA certified just because.... the earlier link I provided explains better than wikipedia about the JASO MA / MB specification.... there is the quality level (which is your API service grade rating in the picture there).... and then:
needs to meet certain limits in "Dynamic Friction Characteristic Index (DFI), Static Friction Characteristic Index (SFI) and Stop Time Index (STI) should be within the following limits according to the JASO 904:2006 friction test" The link shows what those are, and then also talks about the sub classification of MA1 vs MA2 (whatever... we are not that picky with our bikes).
- walker
schnabba screwed with this post 09-01-2014 at 08:51 PM
Old 09-01-2014, 08:42 PM   #17663
schnabba
Oddometer: 1,877
Reminder: change your oil and grab the current tag!
Originally Posted by schnabba View Post
Tag
- walker
Old 09-01-2014, 08:46 PM   #17664
STBNE
Yamaha ADVenturer
STBNE's Avatar
Oddometer: 6,995
No clutch slippage with the supertech...
Sent from my DROID RAZR HD using Tapatalk
Go Your Own Way
Old 09-01-2014, 08:56 PM   #17665
schnabba
Oddometer: 1,877
then carry on! ... and grab/move the tag!
- walker
Old 09-01-2014, 08:57 PM   #17666
Dracula
Deus ex machina
Dracula's Avatar
Oddometer: 1,613
I order Mobil 1 20W50 V Twin from Amazon, but can use any oil, have a dry clutch The thing on the older design valve / tappet engines (like the boxer), a percent of Zinc was needed to lube some valve related stuff.. I forget all details but had long ago read which oils have it. I used Castrol 20W50 regular dyno for first 20k miles on this bike. I can still use it today, but change the synthetic every 6,000 miles so it's worth the peace of mind. When I had bikes with wet clutch I always used MC spec oil as I was too afraid to run into issues contaminating the clutch plates.
I have personal opinions, but don't agree with them.
North Carolina To Albuquerque via California
NY to Alaska and back
Dracula is online now   Reply With Quote
Old 09-02-2014, 02:40 PM   #17667
BHW
BHW's Avatar
Oddometer: 4,135
I've been using Rotella T full synthetic in bikes for years....and never had any issues. I think the last jug I bought from WM was about $23. I used to buy the "no additives version" of Mobil 1 from WM years ago for $21 a jug, but it jumped up quite a bit in price, and I migrated to Rotella after hearing so many people testify about using it.
2003 Aprilia Tuono
Alcohol, Tobacco and Firearms should be a convenience store, not a government agency!
BHW is offline   Reply With Quote
Old 09-03-2014, 05:27 AM   #17668
STBNE
Yamaha ADVenturer
STBNE's Avatar
Oddometer: 6,995
new tar???
this shinko 712 is 1 year old and has only 4404 miles...it looks close to being toast to me...considering my vintage Yamaha rally upcoming...700 miles round trip on the slabs and maybe 400 miles of weekened twisties riding...if its dry then I'd be okay but if its raining then this isnt any good...Folks over on the Yamaha forum saying to change it...65 bucks and no shipping seems like cheap insurance to me....what do y'all think??
Go Your Own Way
Old 09-03-2014, 05:31 AM   #17669
RidingDonkeys
Purveyor of Awesome
RidingDonkeys's Avatar
Oddometer: 8,810
Looks good enough to me for another 500+ miles. Then again, I'm known to push the limits on a tire.
Sit Stay Ride: The Story of America's Sidecar Dogs
More info at www.sidecardogs.com
Clinging to sanity, one motorcycle at a time.
RidingDonkeys is offline   Reply With Quote
Old 09-03-2014, 05:41 AM   #17670
STBNE
Yamaha ADVenturer
STBNE's Avatar
Oddometer: 6,995
500 miles more no problem...but I am looking at a minimum of 1100 miles over 4 days...my feeling is if I bring this tire I will miss some riding...65 bucks is cheap insurance....so I'll err on the side of caution...but i wont throw away that tire....
Go Your Own Way
Times are GMT -7.   It's 09:01 PM.
