Old 09-17-2013, 08:03 AM   #13216
schnabba
Oddometer: 1,917
good grab! Glad I didn't ride to work today just to get bruced... haha!
Yeah Benny - not only does it have a nice diesel, it ALSO has an awesome hood scoop.... a few people on "Fuelly" have been posting their mileage (some person in sweden, and a few others).
Still trying to figure out how to make the lunch on wed - I have a meeting that backs right up to lunchtime.
- walker
"If you don't like my driving, then stay off of the sidewalk!"
schnabba is offline   Reply With Quote
Old 09-17-2013, 09:11 AM   #13217
mmonce
Oddometer: 561
Humor tag for schnabba
Hopson Road
mmonce is offline   Reply With Quote
Old 09-17-2013, 09:13 AM   #13218
mmonce
Oddometer: 561
Originally Posted by STBNE View Post
damn... thats a nice Subie...
+1 agree
Old 09-17-2013, 09:14 AM   #13219
mmonce
Oddometer: 561
Originally Posted by canuck76 View Post
Even in the dark it looks like a nice bike, mmonce!
Sent from my SCH-I535 using Tapatalk 4
Thanks. She puts a smile on my face when she is running good. Lately, I have been smiling.
Old 09-17-2013, 09:15 AM   #13220
mmonce
Oddometer: 561
Originally Posted by schnabba View Post
Just wish the EPA wasn't a bunch of tools and would let them import that wonderful diesel motor they have.... same torque as the six cylinder, peaks at 2000 RPM, gets 43+ MPG ... adds a little cost to the purchase, but you get it back in fuel savings if you drive a lot.
Same problem with the worlds best offroad vehicle....The Diesel Toyota Landcruiser, not available here in the States.
Old 09-17-2013, 09:17 AM   #13221
canuck76
canuck76's Avatar
Oddometer: 162
Unless you are brand loyal check out the VW TDI's (Jetta / Passat) they are around the 43+ mpg and start at $26k out the door. Love mine.
Canuck76
2006 BMW R1150GSA
Eventually, socialists run out of other peoples' money
canuck76 is offline   Reply With Quote
Old 09-17-2013, 09:32 AM   #13222
lonewolf97
lonewolf97's Avatar
Oddometer: 2,397
My diesel doesn't get no where near 43 mpg. But it can pull a lot and carry two bikes in back at the same time. 1999, 7.3 L turbo. I only drive it a mile a week ( to church on Sunday )
Sent from my Galaxy Nexus using Tapatalk 2
I'd rather be lost in the woods, than found at home.
lonewolf97 is offline   Reply With Quote
Old 09-17-2013, 10:57 AM   #13223
RidingDonkeys
Purveyor of Awesome
RidingDonkeys's Avatar
Oddometer: 8,935
I am loving my diesel. I got 22mpgs pulling a trailer full of lumber from Greensboro to Southern Pines on Sunday.
Sent from the voices in my head and transcribed by their drinking buddy...
Sit Stay Ride: The Story of America's Sidecar Dogs
More info at www.sidecardogs.com
Clinging to sanity, one motorcycle at a time.
RidingDonkeys is offline   Reply With Quote
Old 09-17-2013, 02:01 PM   #13224
schnabba
Oddometer: 1,917
I had one (MKIV Golf TDI) for 200,000 miles / 12 years and can probably tell you more about it than you want to know... I was also member number 3608 on freds in the old days. (1998).
Loved it except for:
- soft german winshield glass pits badly over time, looks almost sandblasted (and the windshield is a stressed member of the body, not the easiest to replace)
- headlight lenses went cloudy (I fixed that)
- window regulator attachments broke in both front windows (recall repair though)
- headliner will sag (foam layer under the fabric dry rots and deteriorates over time, then fabric will come loose)
- rear sunroof drains will come loose (glue fails between the surgical tubing part and the plastic connector... both sides did)
- replaced main power relay (109) <-- original one had poor soldering on the board, could have fixed it myself, but just replaced it, they're cheap. Known issue.
- rubberized trim coating begins to peel in year 4-5 (cosmetic only)
- fabric on side door panels will come unglued in year 8 or so
- various airbag sensors failed (easy fix, just annoying)
- dashboard developed squeaks over time (I don't care, some people do)
- foam that seals air vents will dry rot and start blowing out the vents in the dash (lots of german cars do this, not sure what it is about the foam they use).
- headlamps a pain to replace, easier to remove the grill and bumper and pop the headlight
- diesel batteries are expensive, that car went through 3 of them.
- glow plug harness will cause a CEL, but is still OK (later models measure resistance for a bad glow plug per plug, mine was across all 4)
- crazy vacuum system controls too much stuff, hoses and T fittings will crack (I just replaced them all @ 150,000, easy enough)
- stock water pump has plastic impeller that will disintegrate... oh, and the timing belt runs the pump, so if that slips, it's an interference motor, those cylinder heads are $$$. Replaced water pump with better unit at 100,000 (was already leaking)
- front sunroof drains clogged up, water all over the floorboards (my fault for not cleaning them out)
- sunroof control stopped working (no big deal, inexpensive spares on ebay)
- right rear window regulator faulty, built in "pinch protection" would roll the window back down after you rolled it up. Sometimes took 4-5 tries. Needed a new regulator/motor, I'm too cheap so I just put up with it.
- rear window washer rusted out of the wiper blade assembly, tube fell down in the hatchback
It was an interesting little car. A good portion of the above was expected, common problems known in the forums, even back in 2000. For the picky people, they hated it. Some of the other problems people had, I never did... glovebox never broke, center console never broke, driver door squeak was never there, EGR never clogged the intake (well, because I removed it is why), clearcoat on the front fenders never failed, car alarm randomly going off due to bad sensors never happened, shifter was always smooth (replaced fluid with better fluid, helped a lot)...
it was a love / hate relationship with that car. Never took it to the dealer, I can do all that work myself, so the known issues I was prepared for, and they were well documented by the time they showed up on mine. I might get another VW at some point. Just not in the near future.
- walker
schnabba screwed with this post 09-17-2013 at 02:56 PM
Old 09-17-2013, 02:01 PM   #13225
schnabba
Oddometer: 1,917
Hopson Road
hahaaa! (EPA bastards)
- walker
schnabba screwed with this post 09-17-2013 at 02:08 PM
Old 09-17-2013, 02:03 PM   #13226
lonewolf97
lonewolf97's Avatar
Oddometer: 2,397
hahaaa! (bastards)
Who?? Us or them?
Old 09-17-2013, 02:29 PM   #13227
schnabba
Oddometer: 1,917
Originally Posted by lonewolf97 View Post
Who?? Us or them?
edited "EPA bastards" .... I only call you guys that when you use obscure clues... c'mon, you know that!
- walker
Old 09-17-2013, 03:25 PM   #13228
NCStephen
Riding NC
NCStephen's Avatar
Oddometer: 3,057
Off Hopson Rd
03 BMW K1200 RS
03 Honda RC51
74 Honda CB750 K4
76 Pillion Rider Ver 1.0
Give a holler, get a smile.
NCStephen is online now   Reply With Quote
Old 09-17-2013, 03:56 PM   #13229
mmonce
Oddometer: 561
Originally Posted by NCStephen View Post
Off Hopson Rd
Good quick grab
Old 09-17-2013, 05:11 PM   #13230
NCStephen
Riding NC
NCStephen's Avatar
Oddometer: 3,057
Down in the Highwoods, by the Poplars they say there were some Cyprus in this Place but I didn't see any.
NCS
03 BMW K1200 RS
03 Honda RC51
74 Honda CB750 K4
Times are GMT -7.   It's 10:02 AM.
