Old 03-25-2010, 03:14 AM   #1
Sergeant Joe OP
Sitrep=Snafu
Sergeant Joe's Avatar
Oddometer: 242
Airhead fork oil?.
Ok, so I use ATF fluid (about 15-20 weight) in my R65ls, it's ok but somtimes I wish the front was a bit stiffer(on the bike ).
So I was reading up in an old bike book from the 1970's that it was common practice to use motor oil of around the 20w-50 rating, so cold the oil will give the feel of a 20 weight fork oil however once it heats up it will climb to a 50 weight fork oil and will still lube all the inner bits (out of gutter please ).
Now if I do this I should get the better less spongy feel over bumps and aruond corners one would think?.
What say you, the older set of riders from the day, should Igive it a go?.
Sergeant Joe is offline   Reply With Quote
Old 03-25-2010, 04:59 AM   #2
carpetburn
Oddometer: 111
when i put atf in the forks of my 75/6 it was terrible and hard, i find a 10wt good, what are your fork springs like? i use atf in my matchless forks but they were made in 1952
carpetburn is offline   Reply With Quote
Old 03-25-2010, 08:37 AM   #3
jtwind
Wisconsin Airhead
jtwind's Avatar
Oddometer: 3,450
I've never had any issues with using the fork oil the BMW suggests. It's usually 5 or 7.5 weight. I used 10 weight in my r100gs, I think BMW suggested the 7.5 but many folks suggested 10 and it did work well.
JT
www.northwoodsairheads.com
www.jefftrappwindsors.com
"Between two explanations, choose the clearest; between two forms,
the most elementary; between two expressions, the shortest."
Between two motorcycles the simplest (DW)
Eugeni d' Ors (1881-1954); Spanish writer.
jtwind is offline   Reply With Quote
Old 03-25-2010, 08:46 AM   #4
Beemerguru
Beemerguru...G/S guy
Beemerguru's Avatar
Oddometer: 635
How many Ks on the bike?? Sounds like the springs are gone.
Greg Hutchinson
BMW Club of Northern California, Ambassador, BMW MOA, Vice President Vintage BMW Club
http://gregsgssite.shutterfly.com/
Beemerguru is offline   Reply With Quote
Old 03-25-2010, 09:37 AM   #5
Stagehand
+/- V TDSPP
Stagehand's Avatar
Oddometer: 19,941
I thought ATF was only about 5 or 7w. 50w in the forks? Sheesh, I thought mine were stiff as a board at 15 or 20w! That would be in the PD, and I am really working hard to crush those things.
I would say that there is certainly something going on there... springs or something... you a big guy?
What to do... What to do...
Stagehand is offline   Reply With Quote
Old 03-25-2010, 02:36 PM   #6
Sergeant Joe OP
Sitrep=Snafu
Oddometer: 242
Good,thanks guys, I new 50w sounded a bit much .
Now I'm thinking it may be the springs, I can test this by placing car valve springs on top of the fork springs to see if this stiffens there travel some.
as for oil I may just stick to penrite ATF, and yes I am a bigger guy (not fat just built well, like a brick shithouse as one of my mates puts it ).
Old 03-25-2010, 02:41 PM   #7
dduelin
Oh boy that was close
Oddometer: 950
Why don't you test the springs by pulling them out and measuring them for spec length? Sacked springs with car valve spring spacers are still sacked springs.
I like BelRay 10wt.
Honda ST1300
Honda NC700X
Honda CH80
Dave
dduelin is offline   Reply With Quote
Old 03-25-2010, 05:24 PM   #8
The Raven
The Raven's Avatar
Oddometer: 4,813
I hate to hyjack a thread, but what's suggested for my R80g/s?
The Raven is offline   Reply With Quote
Old 03-25-2010, 05:30 PM   #9
Stagehand
+/- V TDSPP
Stagehand's Avatar
Oddometer: 19,941
AS JT said, usually somewhere around 7.5w. Maybe a little thicker if that seems too plush.
Old 03-25-2010, 05:38 PM   #10
Airhead Wrangler
More tacos than you
Airhead Wrangler's Avatar
Oddometer: 5,123
If your forks are getting up to 200 degrees then you might need to figure out WHY they're doing that. That's not normal.
R80ST Gets The HPN Treatment
Ducati Pantah 500SL Rebuild
Seattle to TDF on an airhead
WTB R100R Mystic sidestand and mount.
Times are GMT -7.   It's 04:43 AM.
