Thread Tools Rating: Thread Rating: 9 votes, 5.00 average. Display Modes
Old 03-25-2010, 08:52 PM   #1
Hodakaguy OP
NorthWest Adventure Rider
Hodakaguy's Avatar
Oddometer: 2,093
Clark 4500HP 12 Cylinder Engine - Piston/Liner Replacement Pics
Just got back from working on a 4500HP Clark 2 cycle, 12 Cylinder Natural Gas Fired Engine/Compressor Unit. We had to change out a couple cylinder liners, Pistons, Rods ect.
I took a few pictures to share in case anyone else likes large industrial engines.
Here's one of the Units, My co-worker standing in front of the cylinder heads taking some pics. You can see the three compressors that the 12 cylinder engine drives. The reciprocating motion of the crankshaft is transformed via cross heads into linear motion to drive the compressors. These compressors compress natural gas.
Taken from the top of the cat walk from one of the units, looking at the unit that's being worked on.
Cylinder heads. 6 Cylinders on each side. You can see the air intake manifolds for both banks.
Here's a shot of my ugly mug...
Here you can see the oil cooler along with some of the coolant/oil lines. This unit is massive!
Here Dean is standing in front of the mechanical oil pump, look at the size of the block on this bad boy
Here I'm standing in between two of the three double acting compressors that the engine drives. You can really see how big they are in this shot. On the ground you can see a cylinder head in the bottom left corner of the pic.
Here I'm standing next to a new chrome cylinder liner, we just finished prepping this liner for install.
Installing the new liner.
Looking into the block. You can see the intake and exhaust ports. A co-worker is cleaning inside the crank case, gives a good reference to the size of the crank.
Piston with the Master Rod attached.
Piston with the Link Rod attached. Only the master rod attaches to the crank shaft, the opposite link rod attaches directly to the master rod via a link pin.
Here the piston crown is separated from the skirt. The pistons are a 3 piece unit. Look at the size of the crank pin bearings!
New parts getting ready to be assembled. Master Rod with Hanger, Link Rod, Link Pin, Piston Pin ect.
Assembled piston on the piston stand.
Spare Turbo Chargers
Thought you might like a look.
Hodakaguy
NV 2012 - In Memory of the Crewmen RR: CLICK HERE
Adventure Is Out There - NV RR: CLICK HERE
Riding Through History - NV RR: CLICK HERE
And Then There Were Four - OR RR: CLICK HERE
My VW Syncro Westy Build Thread: CLICK HERE
Hodakaguy screwed with this post 03-26-2010 at 04:27 AM
Hodakaguy is offline   Reply With Quote
Old 03-25-2010, 09:18 PM   #2
andruboz
Serial overfiller
andruboz's Avatar
Oddometer: 5,412
cool. got a .wav file of it running?
A good folly is worth whatever you pay for it.
andruboz is offline   Reply With Quote
Old 03-25-2010, 09:22 PM   #3
fz6kd7
Oddometer: 790
pretty cool
is that a compresor a gas distribution line? or something else
just glad i wasn't the one in the engine block
bet thats fun to start back up
fz6kd7 is online now   Reply With Quote
Old 03-25-2010, 09:24 PM   #4
AKjeff
AKjeff's Avatar
Oddometer: 5,271
Thanks for sharing those, I love big engines.
"We can choose to know better or choose to be bitter." OldRoadToad
AKjeff is offline   Reply With Quote
Old 03-25-2010, 09:28 PM   #5
EvilGenius
1.5 Finger Discount
EvilGenius's Avatar
Oddometer: 20,319
Whats the advantage of giant piston engines over a similarly rated turbine engine?
"Try turning that burn into torque. Then we're getting somewhere. Riding the potato to work seems quite impractical." - anotherguy
"Never bring a Nerf gun to a shovel fight." - My Brother
EvilGenius is offline   Reply With Quote
Old 03-25-2010, 09:52 PM   #6
Reryder
Onward through the fog...
Reryder's Avatar
Oddometer: 1,399
Nice job. Looks like they are cleaner than big diesels to work on.
'77 Harley Ironhead 6,000 miles across Oz
http://advrider.com/forums/showthread.php?t=527966
Reryder (AKA Hopper)
1977 Harley Sportster
81 BMWR100RS
01 HONDA VFR800
99 SV650
Ancient Harley 45, Snortster (Sporty engine in a Norton), Norton Atlas, Honda 350/4, Ariel HS scrambler
Reryder is offline   Reply With Quote
Old 03-25-2010, 09:53 PM   #7
CGH
Polluting the ether
CGH's Avatar
Oddometer: 22,558
Very cool.
Third-rate poster.
CGH is offline   Reply With Quote
Old 03-25-2010, 10:47 PM   #8
Hodakaguy OP
Hodakaguy's Avatar
Oddometer: 2,093
Sorry, no vid
Hodakaguy
Old 03-25-2010, 10:51 PM   #9
Hodakaguy OP
Hodakaguy's Avatar
Oddometer: 2,093
Originally Posted by fz6kd7
pretty cool
Yeah it compresses/pumps natural gas for a main line gas pipeline.
Getting in the crank case of this engine is no problem at all, you have to be a lot more flexible on some of the smaller engines.
Hodakaguy
Old 03-25-2010, 10:53 PM   #10
Hodakaguy OP
Hodakaguy's Avatar
Oddometer: 2,093
Depends, Reciprocating engines will handle a wider range of differential, the diffenerence between the suction and discharge pressure on the unit. It's also more fuel efficient than a turbine. There are quite a few +'s and -'s to each, depending on where/what application they are going to be used in.
Hodakaguy
Old 03-26-2010, 01:11 AM   #11
Anorak
Woolf Barnato
Anorak's Avatar
Oddometer: 34,133
Thanks for the photos. That's really cool. I'm still as fascinated by big machines as I was at six years old.
'Gonna get me a six pack...push people off the highway!'
"they live off the carrion of our mutual distrust and bribe us with symbols that equate hatred with manhood."
"I mean at the end of the day, I was addicted to Starting Fluid for Christ's sake!"
"Yeah, that guy sure is terrible at touching moms"
Anorak is offline   Reply With Quote
Old 03-26-2010, 03:27 AM   #12
adam_c_eckhardt
done with Chemistry!
adam_c_eckhardt's Avatar
Oddometer: 5,270
What is the RPM when it's operating?
adam_c_eckhardt is offline   Reply With Quote
Old 03-26-2010, 04:24 AM   #13
Hodakaguy OP
Hodakaguy's Avatar
Oddometer: 2,093
300RPM
Hodakaguy
Old 03-26-2010, 04:46 AM   #14
Barry
Just Beastly
Barry's Avatar
Oddometer: 7,351
That is flat bad assed !
Very cool. How many days were you there for that job ? How many man hours does the book call for on that pup ? Why not a 4 stroke???
Barry
Tail of the Dragon at Deal's Gap... Avoid it now, do a trackday.
Do not do business with Myrtle West Cycle... Not a reputable vendor by a long shot.
Barry is offline   Reply With Quote
Old 03-26-2010, 04:53 AM   #15
mmitchell57
Vulcan Halfbreed
mmitchell57's Avatar
Oddometer: 2,193
You think I could borrow one of those "spare" turbo's for my bike?
Projects - www.Goomra.com
1969 CB350 - Restoration Project
1962 Ford Fairlane 500 - Restoration / DD project
mmitchell57 is offline   Reply With Quote
Thread Tools
Times are GMT -7.   It's 07:43 AM.
