Old 08-09-2014, 08:32 AM   #1621
opticalmace
opticalmace's Avatar
Oddometer: 165
Originally Posted by JohnCW View Post
So you sit behind a big truck and feel safe that people will see the truck. Yes they're far more likely to see the truck/van or car than some piddly small motorcycle, that's the very trouble. The only thing a driver waiting at the intersection or worse the driver coming from the opposite direction and wanting to turn across the traffic will see, is one bloody great big truck. They make their decision that as soon as the truck passes they will turn, they are committed and act, straight into the following 'invisible' motorcycle. Even at a two second gap your essentially invisible behind a large vehicle to anyone forward of the vehicle. Cars not seeing a motorcycle because it is 'hidden' (both real and illusion) by the vehicles in front of it is one of the major reasons for motorcycles getting taken out. A beginner rider is far safer out in the open, riding defensively, with attention given to maintaining their own high visibility to forward traffic.
The merits or otherwise of a statement "always keep power on the back wheel in corners" was debated to death in the thread on MSF and trail braking. I see no value in covering it again.
I guess I just interpreted it differently. For the first, one thing that comes to mind is that maybe it could be advantageous in certain situations to match the pace or at least timing of a vehicle in an adjacent lane that is going through an intersection with you for the visibility. The latter, in the context of it being a thread for beginners, I don't think they would be concerned about trail braking anyway... but I suppose taking out that first word would be appropriate.
opticalmace screwed with this post 08-09-2014 at 08:52 AM
opticalmace is offline   Reply With Quote
Old 08-09-2014, 01:01 PM   #1622
MauiCowie
MauiCowie's Avatar
Oddometer: 266
And leave extra room in front of you when following a vehicle you can't see through or around (like a truck.) If something happens in front of them that causes them to slam on their brakes you will have little notice of it.
Where's the "any" key?
MauiCowie is offline   Reply With Quote
Old 08-09-2014, 01:12 PM   #1623
catweasel67
Oddometer: 8,856
+1 I'd double the minimum gap (2 second) to at least 4 or more. Bear in mind that the 2 second gap is based on a rolling stop - and if that van, as Maui says, comes to an unexpected, and complete stop, you're gonna need a lore more than 2 seconds.
All those multi-vehicle pile-ups you see on TV - this is the main reason why they happen.
catweasel67 is offline   Reply With Quote
Old 08-09-2014, 02:06 PM   #1624
Toddv
Oddometer: 699
If I'm behind a vehicle I can't see through or past I drop back beyond the standard safe distance. I also use the whole lane to watch for threats from either side in the form of vehicles on side streets waiting to pull out or those turning left from the onciming lane(s). When I see one I gravitate towards the side of the lane that they would expect to see a car in first. Example, I see a car ahead on the left waiting at the end of a side street, I ride the left side of the lane. I also make myself as visible as possible to whatever I perceive the biggest threat to be, of course not without taking everything into consideration. You never want to make yourself invisible to one threat to be more visible to another or you just shot yourself in the foot. Play it like a game.
www.aikenbrushandbobcat.com
Toddv is offline   Reply With Quote
Old 08-09-2014, 04:42 PM   #1625
JohnCW
Oddometer: 1,361
Yes, I was taking a shield to mean in front, and it could mean surrounded by "big vehicles". So is a new rider safer sitting among a pack of vehicles on a multi-lane road, or quickly accelerating pass them if possible to position himself in the open gaps between the 'packs' of traffic? No doubt which place I think is safer (and less stressful), especially for an inexperienced new rider.
From the moment a new rider heads out on the road he/she will have to accelerate through some corners, hold a steady throttle in others, roll of the throttle in others, or brake in some corners. Depends upon so many factors. The advice to "always keep power on the rear wheel, especially in corners" is likely to get you killed if followed.
Anyhow, it wasn't the points themselves as to why I commented. It was the overall theme of the post e.g. why are you guys discussing these things, what did they teach you, I know because I went to a class. I wanted to draw the authors attention to the fact that he may considerably benefit from discussing these concepts.
JohnCW screwed with this post 08-09-2014 at 05:19 PM
JohnCW is offline   Reply With Quote
Old 08-09-2014, 04:55 PM   #1626
Spike Paddy
Space Cowboy
Spike Paddy's Avatar
Oddometer: 119
One thing I didn't take to immediately and I've seen a lot from what I assume are new riders is messing around trying to find neutral at a stop light or while parking. I had been riding for maybe a month or so before one of my buddies told me a little bit of throttle + gently shifting up from first is the best way. Such a simple trick but nobody told me that at the riders course. Having a great feel for neutral makes riding in the city so much easier.
Spike Paddy is offline   Reply With Quote
Old 08-09-2014, 05:53 PM   #1627
JohnCW
Oddometer: 1,361
With the engine idling, just 'toggle' the clutch in and out a very small amount right on the take up point while 'clicking' the gear lever (not a constant press) down. Do this quickly to go to the bottom, and back one (light on). If you do it right the gears will just click into place as the transmission moves. If it grates you're releasing the clutch to much.
JohnCW screwed with this post 08-09-2014 at 06:41 PM
Old 08-10-2014, 12:16 AM   #1628
catweasel67
Oddometer: 8,856
+1
Neutral's pretty hard to find on my bike at times and this almost always works. What's harder, for me at least, is remembering that it works
Old 08-11-2014, 05:22 AM   #1629
mjc506
mjc506's Avatar
Oddometer: 119
So why leave the bike in neutral!?
Leave it in 1st, then all you need to do is throttle on and clutch out to avoid the muppet who nearly stops behind you.
mjc506 is offline   Reply With Quote
Old 08-11-2014, 05:32 AM   #1630
catweasel67
Oddometer: 8,856
You make a good point about not selecting neutral until it's safe to so do but there are plenty of times when I (maybe not you) prefer to be in neutral.
To name but a few: traffic lights, roadworks, border crossings, the list goes on and is long.
If you never feel it necessary to select neutral and either let the bike idle or even turn it off for a few minutes then you're a lucky bugger.
Old 08-11-2014, 05:39 AM   #1631
390beretta
Oddometer: 1,216
I never, ever sit at a light, whether I'm first or in a line of cars, in neutral. My bike is also pointed at an escape route should someone not be stopping in a timely fashion behind me.
I came into this world kicking, crying and covered in someone else's blood. I have no problem leaving the same way.
390beretta is offline   Reply With Quote
Old 08-11-2014, 10:32 AM   #1632
Spike Paddy
Space Cowboy
Oddometer: 119
There's some long red lights out there, keeping it in first is hard on the arthritis in my hands. Especially when there's a lot of them on my way outside of the city. I'll take the risk of being rear ended if it means giving my hands a break and being able to stand up and stretch for a minute.
Old 08-11-2014, 02:09 PM   #1633
IheartmyNx
Ihave2draft
IheartmyNx's Avatar
Oddometer: 3,858
Always, always stage to one side or the other of a lane when stopping.
I see riders all the time stop square in the middle of their lane...
In traffic, or 1st on line.
It's your lane alright, but is it worth your life?
Hard to see things in a court of law if you're buried.
It's hard to make a sandwich when the meat slips out the side...
Everyday IS 3/11!
Everybody's always talking out the side of their mouths about our "dependency on foreign oil", what about our dependency on cheap china crap? Who exactly again is killing our dollar?
IheartmyNx is offline   Reply With Quote
Old 08-11-2014, 02:18 PM   #1634
IheartmyNx
Ihave2draft
IheartmyNx's Avatar
Oddometer: 3,858
The best defense (There is no "offense" or "defense" BTW) for this ^^^^ is in the right hand.
GTFOOTW. If you see you're in a situation like this, remove thy self with a twist.
"Yes officer, I was speeding." "I found myself in an unsafe situation and yes you stupid pig, I removed myself from it."
OMG, a situation where "speeding" can save a life? What is this world coming to!?
Everyday IS 3/11!
IheartmyNx screwed with this post 08-11-2014 at 02:25 PM
Old 08-11-2014, 02:33 PM   #1635
Spike Paddy
Space Cowboy
Oddometer: 119
I always stay towards the left, but it's more of a habit I picked up because a lot of red lights wouldn't go green for me on my first bike. I'm always paranoid of whoever is behind me though, mostly because when I started riding I hadn't quite gotten the hang of taking off until day 3 or so and I was always worried I'd get run over while starting my bike back up.
Times are GMT -7.   It's 09:34 PM.
