Old 03-26-2010, 01:06 PM   #1
TheCowboy OP
back in the saddle again
TheCowboy's Avatar
Oddometer: 606
F800GS Spark Plugs
I give up, I got the airbox off.. where the *%^&$ is the spark plugs???
MadCowboy!!
TheCowboy is offline   Reply With Quote
Old 03-26-2010, 01:09 PM   #2
TheCowboy OP
TheCowboy's Avatar
Oddometer: 606
Oh yeh, and while I'm at it... anybody checked the valve clearance on theirs yet? what is the clearance and how do ya get to the valve train?
Thanks in advance...
Old 03-26-2010, 01:18 PM   #3
lawe
lawe
Oddometer: 141
You need to remove the battery also. And then You need a long spark plug socket because they are deeeeep down.
Lars
Umeň, Sweden
BMW F650GS -05, F800GS -08
lawe is offline   Reply With Quote
Old 03-26-2010, 01:28 PM   #4
TheCowboy OP
TheCowboy's Avatar
Oddometer: 606
Battery was out, whole airbox off, where are the plugs?
Old 03-26-2010, 01:42 PM   #5
TheCowboy OP
TheCowboy's Avatar
Oddometer: 606
I don't wanna break nothing - how does them covers on top of the plugs come off? just pry them off? I'm skerred to try unless I know fer sure..
confusedCowboy
Old 03-26-2010, 03:41 PM   #6
TheCowboy OP
TheCowboy's Avatar
Oddometer: 606
I see they hid them pretty good... careful taking the caps off the plugs... they are long and PLASTIC.. could easly break one of the electrical tabs off trying to pull the caps out.
Also, if you have never pulled the complete airbox off - watch out at the rear of the airbox where the three small air hoses attach... the fittings are PLASTIC and you can snap one off without even trying... I did...
The one I broke was the middle one which brings filtered air into some gizmo below the box on the left side (I think it has somthing to do with the emissons system.. I just plugged it with a small car carb filter so it still gets filtered air...
Hey, it's a learning process...
enlightenedCowboy
Old 03-26-2010, 10:55 PM   #7
Birdmove
Birdmove's Avatar
Oddometer: 1,791
Ain't high tech great?? Why my hopelessly out date Royal Enfield Bullet takes me fifteen seconds to check the valve adjustment, and five seconds to swap spark plugs.
(forgive me, I couldn't help myself).
But seriously, the F800GS are supposed to be very good bikes. I have my eye on a used F800S.
jon
Jon in Keaau, Hi. USA
2008 SYM HD200 (wife's ride)
2009 Kymco People 150 and coming soon, another dual sport mc
Birdmove is offline   Reply With Quote
Old 03-27-2010, 03:30 AM   #8
raider
Big red dog
raider's Avatar
Oddometer: 1,582
jon
I'm not pickin' on you mate, just poking fun at the sentiment...
Your Enfield has valves that are easy to adjust because they frequently need adjusting. My grandfather had some kind of 1920s-vintage Scott, and it had little windows in the crankcase so that you could change big-end bearings by the side of the road. He frequently had to use this feature. That does not make the Scott's easy-access crankcase a desirable feature!
14 R1200GS Adventure
raider is offline   Reply With Quote
Old 03-27-2010, 05:09 AM   #9
TheCowboy OP
TheCowboy's Avatar
Oddometer: 606
I've had my F800GS for about 1.5 years now and have put 27,000 miles on her and nothing has went wrong except for the rear wheel bearings. HOWEVER - I am never comfortable with this bike because of it's HIGH TECH... I am a low tech person - I love my 53 chevy pickup because I can almost stand inside the engine compartment to work on the engine - and I love my DR650 because it is so damn simple and reliable... I understand it.
So let's just say when I want to go for a ride (everyday) I feel a whole lot better jumping on my DR then I do my Beemer
TheCowboy
Old 03-27-2010, 04:43 PM   #10
sospelotudo
motochorro
sospelotudo's Avatar
Oddometer: 106
There is a factory tool that makes removing the coils (plastic thing over the spark plugs) easier to remove. You could also use spark plug boot pliers, the ones that look like needlenose except they have a ring formed by the ends. And yes, I have broken an airbox nipple too...
(Tobacco free since 12/01/10!) Failure. Shit, I'll have to try again.
sospelotudo is offline   Reply With Quote
Old 03-27-2010, 06:30 PM   #11
TheCowboy OP
TheCowboy's Avatar
Oddometer: 606
Thanks, I'm gonna order that tool - unless it costs an arm and leg like every other BMW part...
I epoxied (putty) a poly tube into the broken nipple, let her set fer a while and re-installed the airbox - worked perfect - runs like new.
TheCowboy
Old 03-28-2010, 05:31 AM   #12
sturgeon
sturgeon's Avatar
Oddometer: 946
http://www.marcparnes.com/BMW_Plug_Tool.htm
sturgeon is offline   Reply With Quote
Old 03-28-2010, 06:19 AM   #13
DockingPilot
Hooked Up and Hard Over
DockingPilot's Avatar
Oddometer: 9,848
Those are "coil packs" Cowboy. Youll find them on most newer engines, including the KTM LC8.
Were your valves out of spec yet ?
Frank Reinbold
"Every bike I ever had, was the best bike I ever had, when I had it"
DockingPilot is offline   Reply With Quote
Old 03-28-2010, 06:35 AM   #14
RicH2
Ric H2
RicH2's Avatar
Oddometer: 2,855
Two words: "Shop Manual"....a parts manual might be nice too.
67 Kaw 120ss - 69 Bushwacker - '74 Kaw H2 - '77 RD400 - '66 Black Bomber - KLX250sf - '10 R1200R - '14 Bonneville T100 SE
RicH2 is offline   Reply With Quote
Old 03-28-2010, 07:14 AM   #15
justplainray
ucancallmeray
Oddometer: 260
Hey Cowboy...
it doesn't have sparkplugs or valves to adjust.
The dilithium crystals are housed in a sealed flux capacitor chamber. With dual teutonic phase coupling.
justplainray screwed with this post 03-28-2010 at 04:58 PM
justplainray is offline   Reply With Quote
Times are GMT -7.   It's 11:11 PM.
