Old 03-27-2010, 12:37 PM   #1
110Mike OP
Lug in my Kop
Oddometer: 98
Airhead wheel bearing greasing tool
Hi Airheads
I would like to grease my R100RS`s wheelbearings.
Saw a couple of references to a greasing tool to insert in the wheels, giving a couple of good squirts.
Even saw a pic. It is a tube with a grease nipple at one end, closed the other end and o-rings acting as seals.
I would like to make one of my own.
Does anyone have a set of dimensions I can work from please?
Airhead regards
Mike
110Mike is offline   Reply With Quote
Old 03-27-2010, 06:47 PM   #2
robsmoto
Motorcycleton
robsmoto's Avatar
Oddometer: 330
I got my wheel bearing greasing tool from Cycle Works. It is only $24 - see -
http://www.cycleworks.net/index.php?...products_id=48
robsmoto is offline   Reply With Quote
Old 03-28-2010, 09:38 AM   #3
bmwhacker
Still on 3 wheels
bmwhacker's Avatar
Oddometer: 4,409
I got mine from Cycle Works also....works great. The process involved in removing /5 wheel bearings at each service interval is dicy at best. This tool is not meant as an alternative to a removal / inspection.... but if you know your bearings are good, it is a great, quick way to grease the bearings. For $24.00 it is a great buy.....figure the time machining / fabricating your own and $24.00 is pretty cheap.
http://jupiterhack.blogspot.com/
Living proof you shouldn't play with matches
ABC# 1992
Old 03-28-2010, 09:48 AM   #4
crazydrummerdude
Wacky Bongo Boy
crazydrummerdude's Avatar
Oddometer: 7,635
Well, I actually was going to ask the same question sometime soon, too.
I like making things. I've got lathes. I've got bar stock.
If anyone has some dimensions/pics, I'd appreciate it.
crazydrummerdude is offline   Reply With Quote
Old 03-28-2010, 09:57 AM   #5
caponerd
Kickstart Enthusiast
caponerd's Avatar
Oddometer: 1,980
Will they work on /7 or later bikes? Wheel bearing maintenance is one of my weak points.
caponerd is offline   Reply With Quote
Old 03-28-2010, 05:38 PM   #6
robsmoto
Motorcycleton
robsmoto's Avatar
Oddometer: 330
According to the Cycle Works website, the tool works for bikes up to 1984. After 1984 the bikes had sealed bearings (i.e., no periodic greasing).
For what it is worth, the late Fred Taush once told me that the wheel bearings in his 71 R60/5 were original at 600,000 + miles. He used the bearing greasing tool each time he replaced tires.
Old 03-29-2010, 11:54 AM   #7
Wirespokes
Beemerholics Anonymous
Wirespokes's Avatar
Oddometer: 8,195
I've got one of these and love it. And it's really pretty simple so I don't see it taking much to make one up. I'll try to remember to dig it out tonight when I get home if no one's posted dimensions first.
It's only needed on the right side bearing (the captive one) in the rear wheel.
And I belive it that bearings could last 600K - they're way over-engineered for the job and if greased and preloaded correctly should last forever.
Old 03-29-2010, 02:04 PM   #8
Grider Pirate
Grider Pirate's Avatar
Oddometer: 1,686
Link to Duane's bearing page
... and http://w6rec.com/duane/bmw/wheel_bearing/index.htm has more than you ever wanted to know about the tapered roller bearing setup.
Please don't tell Mom I'm a pilot. She thinks I play piano in a whorehouse.
http://griderpirate.smugmug.com/
http://www.youtube.com/my_videos?feature=mhum
Grider Pirate is offline   Reply With Quote
Times are GMT -7.   It's 08:56 AM.
