Old 03-28-2010, 04:42 AM   #1
Kaw4Life OP
Busted Adventurer
Kaw4Life's Avatar
Oddometer: 6,467
F800GS Cruise Control
Does anyone know if a throttle control setup will work with this combo of hand guard and bar weight? If so how well does it work? I am hoping for the type that mounts on the end of the bar like the Kaoko Cruise Controls.
... for every mile of road, there are two miles of ditch. - MZcountryboy
... which part you focus on is up to you.
Kaw4Life is offline   Reply With Quote
Old 03-28-2010, 08:07 AM   #2
WoodWorks
House Ape
WoodWorks's Avatar
Oddometer: 2,204
That looks like the Touratech handguard and the standard OEM bar weight. If so, the Kaoko, which is what I have, works fine with them.
David
David
I'm tryin' ta think, but nuttin' happens!
--Curly
WoodWorks is offline   Reply With Quote
Old 03-28-2010, 11:16 AM   #3
Nemesis
just ride the damn thing
Nemesis's Avatar
Oddometer: 422
No pics of mine available but the Wunderlich throttle lock as shown in the link works just fine with the Touratech handguards on my F800GS.
http://www.wunderlichamerica.com/mm5..._Code=F800GS-X
"I can tell you with no ego, this is my finest sword. If on your journey, you should encounter God, God will be cut." - Hattori Hanzo
"Every normal man must be tempted at times to spit upon his hands, hoist the black flag, and begin slitting throats " - H. L. Mencken
Nemesis is offline   Reply With Quote
Old 03-28-2010, 12:14 PM   #4
markymcd
markymcd's Avatar
Oddometer: 882
no offense to Wunderlich but I've owned that one and the Kaoko and the Wunderlich sucks in comparison.
www.adventuredecals.com
markymcd is offline   Reply With Quote
Old 03-28-2010, 05:50 PM   #5
Kaw4Life OP
Busted Adventurer
Kaw4Life's Avatar
Oddometer: 6,467
Sweet !!!
Thanks guys, I will order one tonight!
Old 03-28-2010, 07:58 PM   #6
M N B
would rather be riding
M N B's Avatar
Oddometer: 1,148
Originally Posted by Kaw4Life
Sweet !!!
Kaoko makes three models. Make sure you order the correct one.
IIRC (don't quote me), the variants are:
barkbusters
OEM guards (ie: the guards made for the 800gs, not the 1200gs)
No guards.
I THINK the OEM guards is OEM/Touratech, not sure (I have OEM guards). It should be obvious which one to order if you look at the descriptions.
2014 Ducati Multistrada 1200 Pikes Peak MNB Touring Edition
2009 BMW F800GS
2011 Husqvarna TE310 - 2003 Husqvarna TE610e
2007 HD Road King FLHR
1997 BMW K1100LT Special Edition
M N B is offline   Reply With Quote
Old 03-29-2010, 03:12 AM   #7
Kaw4Life OP
Busted Adventurer
Kaw4Life's Avatar
Oddometer: 6,467
Noted, thanks for the input.
Old 03-30-2010, 12:34 AM   #8
gr8ridn
gr8ridn's Avatar
Oddometer: 405
If you have the Touratech plastic hand guards the standard (stock) Kaoko CC is the one that works. I have this setup and it has worked out perfectly. For me the key was getting the friction setting just right with the included hex key. It now adjusts easily just using my outer finger and yet does not drift off like when it is too free. You will like it.
2014 R1200GSAW
Racing Blue, Premium Group, DWA
gr8ridn is offline   Reply With Quote
Old 03-30-2010, 11:45 AM   #9
GSranger
blacksheep
GSranger's Avatar
Oddometer: 83
I have the Wunderlich and it works great. I don't know what makes the Kaoko better?
GSranger is offline   Reply With Quote
Old 03-30-2010, 12:39 PM   #10
WoodWorks
House Ape
WoodWorks's Avatar
Oddometer: 2,204
What makes the Kaoko better for me is that I engage it on and off it the same direction as I roll on and off the throttle. In other words, when I decelerate while gripping the Kaoko, I disengage the lock. The Wunderlich works in the opposite direction, which means that you could be in a situation where you suddenly need to decelerate, and the Wunderlich would be working against you, i.e., locking the throttle ever tighter. That design makes it something of a safety hazard, IMO. I can't imagine what the design engineers at Wunderlich were thinking.
David
David
--Curly
Old 03-30-2010, 03:32 PM   #11
Kaw4Life OP
Busted Adventurer
Kaw4Life's Avatar
Oddometer: 6,467
Thank you all for your input!
Next question.
How do I retrofit KLR650 directional controls on a F800.
Old 03-30-2010, 04:09 PM   #12
markymcd
markymcd's Avatar
Oddometer: 882
David
Bingo! David's got it... also the Kaoko has wider spaced threads for engagement and disengagement so you don't have to 'spin' it as much.... plus the knobs are bigger and wider spaced so it's easier to roll it off and on.
Old 03-30-2010, 04:30 PM   #13
GSranger
blacksheep
GSranger's Avatar
Oddometer: 83
David
Oh... I wish someone told me that about 5 months ago. Thanks for squaring me away
Anyone want to trade Wunderlichs for Kaokos?
Old 03-30-2010, 07:24 PM   #14
dukedar
60 easy payments!
dukedar's Avatar
Oddometer: 340
I might take you up on that! except I have the OEM BMW handguards...
Anyone have issues getting the Kaoko to work with the BMW guards?
See my post here: http://www.advrider.com/forums/showthread.php?t=564379
Shameless BUMP
Darren
'09 BMW F800GS
dukedar is offline   Reply With Quote
Old 03-30-2010, 07:37 PM   #15
WoodWorks
House Ape
WoodWorks's Avatar
Oddometer: 2,204
I don't see it mentioned in your post, Darren, but do you have the Kaoko throttle lock specifically configured for the BMW OEM hand guards (model #CCF900), and not the standard model #CCF700?
David
David
--Curly
Times are GMT -7.   It's 07:44 AM.
