Old 07-13-2010, 03:28 AM   #46
Lornce
Lost In Place
Lornce's Avatar
Oddometer: 18,250
Originally Posted by StephenB
Yeah, looked at that but the "A" hi-comp pistons are not a good match to the "C" Nikasil barrels, too loose.
Ah ha.
I'm forgetting the dimentional differences between A, B and C cylinders. What were they again? A couple of tenths of a thou?
It's been a while since I looked at that stuff...
Old 07-13-2010, 03:35 AM   #47
Plaka
Brevis illi vita est
Oddometer: 4,614
Originally Posted by Lornce
Ah ha.
You have to match them. They are tolerance grades. The largest possible A piston will fit in the smallest possible A jug. Etc. Mix grades and if you get unlucky you will either have interference fits and a seized engine or too loose fits and broken rings.
Old 07-13-2010, 04:16 AM   #48
Lornce
Lost In Place
Lornce's Avatar
Oddometer: 18,250
Yeah, I know all about the why's. But do you know the numbers? The actual production tolerances ascribed to each "grade"?
Old 07-13-2010, 04:30 AM   #49
Plaka
Oddometer: 4,614
I imagine they are in my SNAB book. The inspection tolerances are in the service manual which gives the relative differences between them.
Fortunately the engineers marked the jugs and pistons A, B or C so you don't have to worry about it. Very handy.
I know the routine you are thinking of playing. I don't recommend it with a "points" guy. They're fearful sorts (no offence to the OP, but really)
Old 07-13-2010, 06:27 AM   #50
StephenB
G(/)S ... what else!
StephenB's Avatar
Oddometer: 2,044
Ah ha.
A B and C pistons are nominally 1/100mm (4/10 tho) apart: A 93.96, B 93.97, C 93.98 I believe. But (big but) last time I checked my "S" piston it measured 93.88 (with 93.96 being nominal), but I could have bodged that measurement. It was clearly rattling in the C barrel, you could have thrown a couple of tho's through the gaps ...
Barrels have a tolerance band of their own. Mixing and matching A B and C pistons and barrels is of course possible as long as the piston-to-cylinder and other relevant tolerances/clearances are in spec. It's all in the Clymers or Haynes's ... you must have one of those.
Some of the above is fact, some is fiction, some is my personal imagination and some is just simple truth. [me]
... i'm not touring around the world, but neither are most of the guys i see running overloaded spam cans ... [bmwblake]
Stephen Bottcher
Ontario, Canada
'72 R75/5 The Blues
www.stephenbottcher.net
StephenB screwed with this post 07-13-2010 at 06:35 AM
StephenB is offline   Reply With Quote
Old 07-13-2010, 06:29 AM   #51
StephenB
StephenB's Avatar
Oddometer: 2,044
I am interested in the routine you're mentioning that would make "points" guys shudder. Never met one but I'd love a good scare !
Stephen Bottcher
Ontario, Canada
'72 R75/5 The Blues
Old 07-13-2010, 07:46 AM   #52
Lornce
Lost In Place
Lornce's Avatar
Oddometer: 18,250
Somewhere...
Thanks, Steph. That's the sort of thing I was wondering.
byam, a couple tenths of a thou here or there won't matter too much with the pistons as long as the rings are well spec'd.
awaiting the purist storm de merd
Old 07-13-2010, 08:04 AM   #53
Stagehand
Imperfectionist
Stagehand's Avatar
Oddometer: 27,210
Always measure the pistons anyway. I got a pair of C's that were well over 93.98, so had to send them back. Too big even for the hogged out used barrels.
Unintentional psychokinesis.
Stagehand is offline   Reply With Quote
Old 07-14-2010, 02:49 AM   #54
advNZer?
advNZer?'s Avatar
Oddometer: 2,947
can someone summarise their thoughts on why the motorad electik is superior to the stock can?I need to either replace the Hall sensor or think about an alternative(89 R 100 gs)
aka BMWST?
advNZer? is online now   Reply With Quote
Old 07-14-2010, 05:33 AM   #55
Renner
rockin' the toaster
Renner's Avatar
Oddometer: 2,330
ease of maintenance
other significant differences are ball bearings vs. bushings and solid state ignition advance vs. centrifugal advance.
I went through a spare can last night, it's not as difficult as one might think.
http://www.motoelekt.com/alpha.htm
http://robfrankham.co.uk/bike/replac...ect_sensor.htm
Renner screwed with this post 07-14-2010 at 05:39 AM
Renner is offline   Reply With Quote
Old 07-14-2010, 05:45 AM   #56
bgoodsoil
Dare to be Stupid
bgoodsoil's Avatar
Oddometer: 4,645
The part of the stock can that's failure prone is the hall sensor. If it goes you can't replace it without power tools so a lot of people carry an entire spare can on their bike. That's a $300 piece of electronics bouncing around in your panniers for years. Rick's alpha ignition uses a big snap ring and a commonly available hall sensor from Honeywell. Most Radioshacks will have it.
Also, the stock can uses springs and bob weights for the advance. They can get dirty or sticky and affect the advance. Rick's is an electronic advance.
The stock can is really half-electronic rather than a full electronic ignition.
Rick's system uses the stock ICU which is the same ICU on most Volkswagen Jettas. You should be able to get a spare from most auto parts stores.
'85 BMW r80G/S--Another G/S on the road--Central America on a Shoestring--Nova Scotia on a Shoestring--Never Leave a Man's Behind
Proud SmugMug User Support ADV: Don't give those cheap bums your discount code
bgoodsoil is offline   Reply With Quote
Old 07-14-2010, 06:02 AM   #57
CurlyMike
Formerly SaddleSoar
CurlyMike's Avatar
Oddometer: 1,010
+1 on all of that. Plus these bikes mechanically will last a life time, electronically not so much. I am a self professed cheap bastard and I think most if not all of Rick’s upgrades are worth the money if you ride everyday and need to rely on your bike. I have been super pleased with my new bean can and the new diode board is very impressive looking and works great. My charge light doesnt even come on at stop lights anymore. Small things like LED brake lights help as well, because what I understand is that those regular lights draw a bunch of current. My next purchase will be the Omega 450 Alternator and maybe new coils. I figure after that, the bikes good for another 40 years of riding. I have 2 old Hall cans, one is in pieces and one intact, wish I knew someone who could convert those to the points in a can version (which I have just as a back up) reasonably...
Giving the horses and the wife a break from riding...
CurlyMike is offline   Reply With Quote
Old 07-14-2010, 07:39 AM   #58
Stagehand
Imperfectionist
Stagehand's Avatar
Oddometer: 27,210
I thought the Hall sensor was actually the robust part. It was everything else in there that went all warbly. Thats why Rick kept the Hall part and changed everything else.
A spare Used one might be $300 but a brand new one from BMW is $500. Rick's is half that, brand new. Plus his advance is now only susceptible to heat, rather than heat and every other possible intrusion.
Is it really the Halls that go bad? I couldve swore the springs and advance and all that crap went bad first.
Old 07-14-2010, 08:39 AM   #59
bgoodsoil
Dare to be Stupid
bgoodsoil's Avatar
Oddometer: 4,645
I've always heard it's the hall sensor. roadsacallin's bike went dead because of the hall sensor.
Isn't that why Matt's trying to put 2 hall sensors in your can?
Old 07-14-2010, 09:14 AM   #60
Lornce
Lost In Place
Lornce's Avatar
Oddometer: 18,250
The advance units can gum up and stick open causing high-idle issues, easily cured with brake cleaner and silicone lube. Happens fairly often on high mile bikes.
The hall effect transistors *can* fail on and off as they thermally degrade over time. That *can* become a show stopper. A fairly rare occurance.
I'm curious to know about the guts in the replacment marketed by ME. Most everything he sells is mfg'd in Taiwan, and there's nothing wrong with that. But I've yet to see a Tiwanese electronic ignition on the market for airheads.
Times are GMT -7.   It's 12:52 AM.
