Old 07-15-2010, 11:36 AM   #76
Plaka
Brevis illi vita est
Oddometer: 4,609
Originally Posted by CurlyMike
Where did you happen to get your Halls at? Thanks for the offer, but one is in a bunch of pieces from me trying to see whats in there and the other I still might spray and clean and see if it will works ad a back up.
Digikey or similar. Look on the IBMWR tech pages for the honeywell part number and sources. It's a common electronic item and costs a couple bucks.
Old 07-15-2010, 12:58 PM   #77
bgoodsoil
Dare to be Stupid
bgoodsoil's Avatar
Oddometer: 4,607
Honeywell 2AV54 according to Motorrad Elektrik.
'85 BMW r80G/S--Another G/S on the road--Central America on a Shoestring--Nova Scotia on a Shoestring--Never Leave a Man's Behind
Proud SmugMug User Support ADV: Don't give those cheap bums your discount code
bgoodsoil is offline   Reply With Quote
Old 07-16-2010, 09:22 AM   #78
carockwell
Oddometer: 250
Oak Oakleshen will rebuild your standard Hall bean can for $150. My apologies if this was posted previously.
carockwell is offline   Reply With Quote
Old 07-18-2010, 01:17 PM   #79
wirewrkr
the thread-killer
wirewrkr's Avatar
Oddometer: 4,295
Hall Sensors
I get mine from Newark Electronics, about $12 or so.
I think I bought 5 last time and they cut me a deal. Been awhile.
These are used on all BMW bikes from 81 -2005
I don't know if they are used on the 1200 hex head engines.
The fun part is the mechanical riveting.
www.wirewerkes.com
KILL YOUR TELEVISION !!!!
Old 08-28-2010, 03:31 PM   #80
LasseNC
XSessive!
LasseNC's Avatar
Oddometer: 1,072
Is a Boyer setup simple to do? I have my R60 and I just want to get something simple to replace my points setup.
Alternatives like Omega seem more costly and complex.
Old 08-28-2010, 04:19 PM   #81
Plaka
Oddometer: 4,609
Yes. Remove points plate complete w/ points. Put in baggie. Remove advance unit and put in same baggie. Give area where points plate was removed a spritze of carb cleaner to remove oil. Bolt in Boyer plate in place of old points plate. Install Boyer rotor in place of old advance unit. Tie Boyer elec. module under frame tube in front of seat w/ zip ties. Plug boyer points plate into existing harness as well as wires from electronic module. Time it with timing light (not static). Put baggie with old parts under seat. You can swap back in 10 minutes by the roadside if the Boyer ever flakes out. Carry your little static light and proper feeler gauge to set the points and static time it.
Old 08-28-2010, 10:03 PM   #82
Beemerboff
Oddometer: 2,332
Moto Bins still have the basic Boyer non digital version at a real good price, and as it replicates the "Curve" on a points system is should work OK.
There may be a measurable gain with fancy systems on a dyno, or on full house race bikes, but in the real world guys who have fitted fancy crank mounted systems back to back with a stock system , switchable on the fly, report no noticeable change as they switch between the systems.
Adelaide Hills, Australia. 93 R100 GS, 77 R75/7 ,70 BSA B44VS, , 86 R80 G/S PD, 95 BMW Funduro F650 ST
Beemerboff is offline   Reply With Quote
Old 08-28-2010, 11:59 PM   #83
LasseNC
XSessive!
LasseNC's Avatar
Oddometer: 1,072
On the spot Plaka, thanks!
Times are GMT -7.   It's 04:48 AM.
