Old 03-29-2010, 02:29 PM   #1
gronk OP
HIGH ANGLE RIGGER
gronk's Avatar
Location: Very High Above Ground!North of The 49th parallel
Oddometer: 341
'89 BMW R100GS Turn signal relay?
Who can tell me what I can replace my burnt out turn signal relay with?I have rear running lights .Wehrle BMW #1 244 392.2 the relay is the original and finally died after 500,000km or so.I'm hoping there is a TRIDON or Bosche aftermarket, the Stealership wants almost $50.00!!! Thanks Gronk
gronk is offline   Reply With Quote
Old 03-30-2010, 09:12 AM   #2
Grider Pirate
Grider Pirate's Avatar
Oddometer: 1,686
http://www.advrider.com/forums/showt...al#post5247712
post # 66
Please don't tell Mom I'm a pilot. She thinks I play piano in a whorehouse.
http://griderpirate.smugmug.com/
http://www.youtube.com/my_videos?feature=mhum
Grider Pirate is offline   Reply With Quote
Old 03-30-2010, 02:02 PM   #3
gronk OP
HIGH ANGLE RIGGER
gronk's Avatar
Oddometer: 341
The answer is!!
TRIDON EP35 thanks to airheads .org for a VW/AUDI oem part number which gave me TRIDON EP35. It works perfect,$11.00 plus tax sweet. Electronic and it will handle LED.
Old 03-30-2010, 02:04 PM   #4
gronk OP
HIGH ANGLE RIGGER
gronk's Avatar
Oddometer: 341
Pic
Old 03-30-2010, 04:36 PM   #5
Phreaky Phil
Oddometer: 1,930
Are these for GS or G/S ? My 92 GS with the switches on each bar and a seperate cancel switch has to have the BMW indicator module as far as I know
Phreaky Phil is offline   Reply With Quote
Old 03-30-2010, 05:30 PM   #6
gronk OP
HIGH ANGLE RIGGER
gronk's Avatar
Oddometer: 341
Works in R100 GS 1987-1990 I believe ,turn signal switch on left control only.There are options for newer bikes but I don't have 4 way flashers so a 3 pin relay works. TRIDON does have a relay for your bike and it works in K bikes also.
Old 03-30-2010, 08:00 PM   #7
bmwrench
Oddometer: 2,362
The "K" style flasher is used from 91 on. If you have K-style switches, you have a K-style relay.
bmwrench is offline   Reply With Quote
Old 03-31-2010, 04:15 AM   #8
Infracaninophile
Finding My Way..
Infracaninophile's Avatar
Oddometer: 7,521
Since I've never owned a "K" bike, what exactly are K switches? Is this the style where the turn signals are actuated from both the left and right sides like my 93? I never knew this was called by that name before.
T.
Infracaninophile is offline   Reply With Quote
Old 03-31-2010, 04:21 AM   #9
gronk OP
HIGH ANGLE RIGGER
gronk's Avatar
Oddometer: 341
Yep that would be K style switches,you need the 4 pin relay.
Old 12-01-2012, 02:56 PM   #10
some_guy
some_guy's Avatar
Oddometer: 144
I'm in the process of...simplifying my wire harness and found this useful. Just wanted to say thanks.
some_guy is offline   Reply With Quote
Old 12-03-2012, 07:02 AM   #11
Uncle Pollo
happy cachiporra
Uncle Pollo's Avatar
Oddometer: 48,552
I use a regular cheap auuto parts store relay .
Uncle Pollo is offline   Reply With Quote
Old 12-05-2012, 08:02 AM   #12
LBourque
G/S nut
Oddometer: 225
Kisan Industries
Try Kisan Mfg. They have several kinds of turn signal relays. Needed one for the LED conversion on my 81 R80 GS. Programmable if need be.
LBourque is offline   Reply With Quote
Old 11-12-2014, 07:15 AM   #13
bevhoward
bevhoward's Avatar
Oddometer: 3
Thanks for the thread... helped me.
My search for the same answer also came up with the reference pdf at
http://www.tridon.com.au/downloads/d...e.aspx?D=45149
...which has turnsignal pinouts and schematics for a variety of different flashers... for example, the ep34 looks identical, but the voltage pin polarity is reversed from the ep35. (see page 9 and 10)
Hope that this information is helpful,
Beverly Howard
bevhoward is offline   Reply With Quote
Times are GMT -7.   It's 05:38 PM.
