03-29-2010, 04:08 PM
#1 |
Oddometer: 4,813
Hey guys,
After posting a few stupid questions like how to fix and oil sender (replace it), and why my monolever is leaking...duh its the washer I figured I would just start a thread to ask each stupid question and stop cluttering this fine forum with one liners.For anyone else with stupid questions, feel free to hijack, we all have them, so might as well ask. ------------------------------- Problem:The bike when revved stays revved for a short time then settles down, why the delay...the KLR just drop instantly??? My Solution: Caused by a Vacuum leak...errr me leaving the vac line on one side disconnected.... as well as a loose center cap on the Bing 32mm carbOther solutions: sticking advance (it is mechanical), poor carb synching (many, many sub-plots in this one), sticky throttle cable(s), sticky choke cable (s), sticky choke(s), aging poorly ignition canister ------------------------------- Problem: Oil all over the mono-lever??? Solution: Bad washer on the drain plug(s), thread seal. Shock was leaking, replace shock Other Solutions: surface between FD and drive is seeping, replace $2 paper gasket, replace o-rings in brake housing ------------------------------- Problem: Speedo is toast?? Solution: Send to Wirespokes, or other place to get fixed Other solution: VDO guage, Vapor, GPS speedo, $300 new gauge. ------------------------------ Problem: Alt light does not come on with key Solution: No continuity between slip rings (3.4ohms) bad rotor, or worn brushes. --------------------------------- Problem: Very harsh ride with stock front shocks Solution: Install Racetech Cartridge emulators FEGVS3301 The Raven screwed with this post 04-07-2010 at 06:09 PM |
03-29-2010, 04:41 PM
#2 |
Dare to be Stupid
Oddometer: 3,881
could be a sticky advance. Did it do this before the work you've done?
'85 BMW r80G/S--Another G/S on the road--Central America on a Shoestring--Nova Scotia on a Shoestring--Never Leave a Man's Behind Proud SmugMug User Support ADV: Don't give those cheap bums your discount code |
03-29-2010, 04:43 PM
#3 | |
airhead or nothing
Oddometer: 7,976
OK, the lag in the idle drop means somthing is wacky...
It could be:
"punkrocks what it's all about" - J. Strummer Quote:
03-29-2010, 04:44 PM
#4 | |
Oddometer: 4,813
Yes it did, thinking back. |
03-29-2010, 04:45 PM
#5 | |
Two Wheel Addict
Oddometer: 1,971
#6 | |
Oddometer: 4,813
Ok so it could be caused by mis-synced carbs....I need to make some more ATF sticks to sync them.
03-29-2010, 05:02 PM
#7 |
Dare to be Stupid
Oddometer: 3,881
I like the $4 carb sync tool.
I did the shorting method until I developed a heart murmur and this weird nervous tick from shocking myself
03-29-2010, 05:07 PM
#8 | |
Knows all - tells some.
Oddometer: 12,965
I always thought of that as a cheap high.Raven, learn to do the shorting method and you can synch your carbs anywhere, any time. Also, a lot of time on older bikes the cables drag so check them out by disconnecting them and seeing how free they truly are.
- "The turd follows the fart as surely as the rain follows the plow." Emily Bronte |
03-29-2010, 05:11 PM
#9 |
Oddometer: 4,813
Solved....see first post
03-29-2010, 05:19 PM
#10 |
Dare to be Stupid
Oddometer: 3,881
I keep the shorting stalks on the bike just in case. I wrapped the bottom half of one of my tire levers in splicing tape so I can use it as a shorter and not zap myself.
03-29-2010, 05:27 PM
#11 |
Oddometer: 406
from a beginner...it's too rich
youre too rich at idle...from another noob, of course, so take it with a grain of salt
03-29-2010, 07:23 PM
#12 |
combustophile
Oddometer: 1,569
next question?
03-29-2010, 08:21 PM
#13 |
Finding My Way..
Oddometer: 7,506
You've still got some Texas air stuck in the carb somewhere. You need to let it out. Your bike misses the west and won't ever run properly east of the Mississippi River. Move west.
T. |
03-30-2010, 04:04 AM
#14 | |
Oddometer: 4,813
I could still smell texas on her, I must give her a bath
03-30-2010, 04:23 PM
#15 |
Oddometer: 4,813
I have a cracked rear muffler mount, better to remove the rear subframe and weld it, or do it on the bike? Almost think it would be easier to just remove the rear subframe.
Fixed the kickstand today, welded on a BIG round washer, I think it matches the headlight I need a speedo, where is a cheap place to find one...does anyone have one they want to part with? |
