Old 03-29-2010, 09:31 PM   #1
Prairie Beemer OP
Oddometer: 52
Airhead shifter gasket
Busted out my 78 R60/7 this weekend after parking it for the winter. Runs like a top, but whack-a-mole oil leaks continue. Does anyone know how to remove and replace a leaky gasket where the shifter enters the transmission? I read a post on this somewhere, but I can't find it.
Prairie Beemer is offline   Reply With Quote
Old 03-29-2010, 11:43 PM   #2
OldAndBusted
Needs a little work...
OldAndBusted's Avatar
Oddometer: 385
there was an article in the last BMWMOA magazine about removing a seal from the input shaft of the transmission without opening the transmission. it involved drilling a hole in the seal and using a slide hammer with a screw attachment on the end of it to dig into that hole and yank the seal out. might work on the shifter seal too. just gotta be careful of everything behind the seal. they're not too thick.
OldAndBusted is offline   Reply With Quote
Old 03-30-2010, 01:39 AM   #3
Beemerguru
Beemerguru...G/S guy
Beemerguru's Avatar
Oddometer: 995
Get seal, lean bike over on the right side against the wall, remove shifter, large screwdriver or small seal puller and remove old seal, clean up, install new seal, install shifter, bring bike back upright.
5-10 minutes max.
Greg Hutchinson
BMW Club of Northern California, Ambassador, BMW MOA, Vice President Vintage BMW Club
http://gregsgssite.shutterfly.com/
Beemerguru is offline   Reply With Quote
Old 03-30-2010, 05:39 AM   #4
boxerboy81
Stay Horizontal
boxerboy81's Avatar
Oddometer: 2,570
5-10 minutes max.
That's it. No need to drain the oil that way.
boxerboy81 is offline   Reply With Quote
Old 03-30-2010, 06:55 AM   #5
Pelicanglider
Oddometer: 231
Just did this on my '77 R100. Pop out, tap in. Just make sure you get the right size. I used the parts fische on the Max BMW website and I got one too large (28mm instead of 26mm). Went a little crazy waiting for the right size. I'm OK now.
Pelicanglider is offline   Reply With Quote
Old 03-31-2010, 10:48 AM   #6
OldAndBusted
Oddometer: 385
geez i hadn't even thought that the shifter shaft just comes right out on those bikes. i'm used to my /2 where it's inside the case. yeah you can just pry it out with a regular seal puller.
Old 04-01-2010, 03:04 PM   #7
Prairie Beemer OP
Oddometer: 52
You can only imagine how thrilled I am to learn this can be done from the outside.
Thank you, my friends.
Old 04-01-2010, 03:23 PM   #8
BrianK
F'in' half ass lookie boy
BrianK's Avatar
Oddometer: 858
Just did it the way Beemer Guru describes, it works a treat. I put a bit of silicone seal on the outer diameter of the seal, SOP for me but YMMV.
Maybe it's just because I had the problem myself, so I'm noticing them, but I've seen a slew of inquiries about this seal/process recently. Tough winter for shifter seals, I guess.
BrianK is offline   Reply With Quote
Old 04-02-2010, 07:25 AM   #9
Beemerguru
Beemerguru's Avatar
Oddometer: 995
Must be something in the air...I just did my 6th rear main seal in the last month
Greg Hutchinson
Times are GMT -7.   It's 07:51 PM.
